2010 Prius Starts By Itself !!!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PenalCode16, Jul 18, 2010.
  1. PenalCode16
    PenalCode16 New Member
    sonoma
    I just got my new 2010 Prius and very happy with it, but I have experienced three different times when the darn car started by itself. I seriously doubt that I left the car on. Each time, the car has been sitting out in the hot sun with temperatures in the high 80's to low 90's. The gas engine has gone from off to definitely on. It happened again today and I went over and looked at it the dash read "Ready" and all systems were "go" on the dash. One of the times I could have sworn the car turned itself off (I was in shock so not 100% sure).
    Is it possible that the battery needs to be cooled down and so the engine is turning on?
    Maybe a related problem but I have also experienced that the car will start with the key 4 miles away. Is this suppose to happen?
  2. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    There is nothing normal about what you are describing.
  3. derkraut
    derkraut Member
    299
    28
    SAN
    Doesn't make sense to me. If you stop the car and press the power switch to shut the computers down, there's no way it should start by itself. Since it's under warranty, take it to the dealer.
    Regarding your 2nd sentence---how can you tell from 4mi away that the car has started????
  4. PenalCode16
    sonoma
    My father in law was driving it, and I was 4 miles away with the key in my pocket (and talking to him via cell phone).
  5. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Sounds like you're not turning it off with the start/stop button. Perhaps you are confusing the Park button with Start/Stop.
  6. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    +1... The car is definately not off when you are leaving. It will not just start.
    Only other explanation is you have a remote start enabled which will screw everything up.
  7. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    You know how when you start the car you press the on/off button? Well, when you stop the car, you need to press the on/off button.
    You need to read the manual, or even the quick start guide. if that's too much then watch the DVD that came with the car.
  8. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    DVD:confused: I got no stinking DVD
    Is that UK thing
  9. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I got a DVD! :D
  10. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    In regard to the vehicle starting with the key 4 miles away, is it possible that the second Smart Key System fob is actually in the vehicle?
  11. Airbalancer
    892
    73
    Cobourg, On, Canada
    Could OP be hearing the solar fan starting and stopping
    I do not know if OP has a solar roof
    So the car was running and he got in drove away without a key :confused:
  12. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    Once the car is started...you can drive it without the key. this is purely safety. Imagine your smart key running out of batteries while youre driving in the middle of the freeway. My suspicion is that the OP is simply not pressing the power button to turn off the car when he leaves. Before you leave the car, make sure everything on the dash is off. The only thing that should be lit up when you leave is the ODO and the clock. the "Ready" light should be gone.
  13. silverfog
    silverfog New Member
    152
    Raleigh,nc
    Or could the remote A/C have been pressed? I admit I was confused by this when, after pressing the remote for longer the usual, the lights came on and it sounded as if the engine was running.
  14. johnlawson57
    johnlawson57 New Member
    Solana Beach
    My wife reports that she unlocked our new 2010 in the normal manner by grabbing the door handle. She opened the door and the Prius "booted" up. That is the Prius splash screen on the instrument display came up and the car was on! Is she nuts, or do I have some other problem?
  15. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Are you sure she saw the splash screen, or did she just see it on?
    My guess is it was not turned off. I am unaware of a "screen saver" or anything where the display goes out, and would show the splash at a later time.
  16. socratesthecabdriver
    283
    31
    greece
    mabe the momentary switch has fault
  17. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    This sounds a bit more like confusion that car fault. I may be wrong, though.
  18. Michaelvickdog123
    Michaelvickdog123 New Member
    332
    US
    Com'on. This has got to be a joke? :eek:
  19. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    The OP has not been back since July... I'm thinking someone wasn't turning OFF the car.
    Unless he/she is back with a new nickname, now that he/she has learned to operate the car (I would).
  20. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    211
    San Diego, California
    It has become self aware
    Wonder and Pipglitch like this.
