No start due to P3106, ECM -> HV ECU communication failure?
Discussion in 'Generation 1 Prius Discussion' started by cowlove, Jul 14, 2010.
  1. cowlove
    cowlove New Member
    Seattle
    2002 Prius
    The motor on my 2002 prius stopped while driving, and will not start. The car will not go into READY mode, but still allows slow operation on battery power. When powered up, the car usually makes one attempt to spin and start the motor, but there is no spark.
    The trouble code listed is P3106, listed as the HV ECU complaining about no communications from the ECM. I made sure the ECM is getting good power and DC signals according to the service manual, and then replaced it with another used module, but the problem persists. I'm now about to investigate the serial data link and wiring between the HV and the ECM, as well as speculatively replace the HV ECU. Good thing gen 1 computer modules are cheap and readily available on ebay. :)
    Has anyone heard of this specific failure? Does anyone have any hints for investigating the serial data bus? It looks like a pair of unidirectional RS422-like serial links, each over a shielded pair. HTE-/HTE+ and ETH-/ETH+. I was going to put a scope on the ETH pair and see if the ECM is even trying to speak to the HV ECU.
    Any other hints?
  2. bwilson4web
    16,380
    You are at risk of discharging the traction battery to such a low value that it will have to be recharged. This can be pretty ugly.
    Do not rule out a problem with the connector the HV ECU. It is located under the passenger side floor. Water, debris or corrosion might also lead to the symptom.
    We really need more codes and the options are limited:
    • Toyota Service Center - usually for +$100, they will do a one time code read. However, the quality of this service varies and one user has reported very poor results with a North Carolina dealer.
    • Graham Miniscanner - provides up to three stored codes per controller for the engine, HV ECU and battery ECU along with live data of over 50 data elements. I rent these for do-it-yourself projects.
    • Auto Enginuity - at $400 and your laptop, it isn't perfect but it reads all codes and many more data elements. It has problems with a few larger data fields but it is head and shoulders above over the counter scanners.
    • Techstream Lite - at $1,200-1,500, I haven't tested it but this is pretty pricy for a do-it-yourself.
    • Over-the-counter scanners - little more than expensive junk. They can handle one code, seldom know how to find the other controllers and are limited to the emissions mandated fields.
    Because it happened as one event, I suspect a broken wire or corroded connector but the ambiguity group is too large.
  3. cowlove
    cowlove New Member
    Seattle
    2002 Prius
    RE: discharged traction battery. Indeed. That was my first challenge. The motor quit at the exact top of a mountain pass, so the battery was nearly discharged to begin with. Limping off the freeway and a few days' worth of start attempts, tinkering, and moving it around the yard left it completely discharged.
    Luckily, I have a 36V->360V DC/DC converter that I'd cobbled together as part of a DIY plug-in conversion for this car. It's been on a back burner for a while, but I dusted it off and trickled an amp into the battery for a few hours, and it's good to go. Plus, moving the car around back behind the house after recharging the traction battery now officially counts as my first PHEV trip, eh?
    RE: scan tool recommendations and dealership diagnosis. Thank you for the advice. I did tow it to the dealer for analysis, and despite me explaining that I was going to tinker my way through this problem, and specifically requesting a printout of all available info, including sub codes, other ECU trouble codes, and freeze frame info, they only had the gross overview paperwork that reported P3106 when I went to pay and pick up the car. They claimed they could not retrieve the more detailed paperwork or records, but did offer to run a diagnosis again for another $100. I was very frustrated, took my car, and went home.
    RE: HV ECU connections- I'll do this. I had exposed the HV ECU in preparation for the replacement, and wiggled and inspected the connectors, but nothing jumped out as bad. I was so sure that it was a bad ECM that I didn't do much more diagnosis while I was waiting for the replacement ECM to arrive from ebay.
    The failure happened at the exact peak of a mountain pass, about when I let off the gas pedal. I figured the high-current ignition and injector circuitry in the ECM would have been at unusual peak thermal stress for the 10 minutes of max RPM abuse coming up the pass. Combined with the P3106 code, I was pretty certain the ECM was just dead.
    Anyway, I will keep you posted what I find. Thanks for the concise and expert advice!
    Jim
  4. cowlove
    cowlove New Member
    Seattle
    2002 Prius
    Solved. WHEW!
    I spent a few days trying to figure out why multiple ECM's all failed to communicate. I put a scope on the serial communication lines, and although the HV ECU was chattering away at the ECM, the ETH+/ETH- lines were completely dead. Same thing with multiple replacement ECM's. I poured over the power supply and DC signal lines, looking for bad grounds, bad connections, everything.
    Turns out it was a bad fuel tank vapor pressure sensor that was shorting out the ECM's 5V sensor power supply wiring. (Pin VC on the ECM.) This irritated the ECM enough where it wouldn't even boot. Possibly some internal logic or processor in the ECM uses the same power supply, which is shoddy if it's true. Anyway, I disconnected the faulty sensor, and the car sprang to life.
    If the sensor Vcc is as critical to other ECU modules as it is to the ECM, checking for a healthy sensor power voltage (Typically pin "VC", specified as 4.5 to 5.5) should be a top step in troubleshooting any suspect ECU.
    3 people like this.
  5. bwilson4web
    16,380
    Did you pull the connector at the tank?
    I had not looked closely at the ECM but now I'm noticing the vapor pressure sensor has three lines:
    • VC - the one you found shorted
    • PTNK - feeds back to the ECM
    • E2 - appears to be shared with multiple sensor and E2 on the ECM
    Have you eliminated a wiring harness short to ground?
    Does it run with an error light and/or codes?
    Near as I can tell, it is the sensor that detects if the fuel cap is sealed. Any thought of just 'spoofing' the signal or do you plan to replace the sensor?
  6. cowlove
    cowlove New Member
    Seattle
    2002 Prius
    Yes, I disconnected the sensor at the tank. Line E2 is a sensor ground, shared by several sensors. The faulty pressure sensor basically shorts it and VC together, drawing VC down to about .2V.
    I'm driving it around disconnected for now, but I assume this will cause it to fail its ODB2 gastank pressure test cycle next time it runs it, so I will need to replace it before my car is due for its emissions inspection.
    I hadn't thought of spoofing it. I believe that particular emissions test cycle just sees if the gastank can draw (and hold) a vacuum, so just putting in a resistor that returns the approximate vacuum value on PTNK might work.
    Thanks for the spoofing idea. Anyone need 2 classic ECMs and 1 classic HV ECU, by the way?
  7. bwilson4web
    16,380
    That makes a lot of sense (pardon the pun)! I've long wondered how common-mode noise is avoided but now it looks like "BR" (brown) is the universal, signal reference ground.
    The manual says removed the fuel tank. If you do, please take lots of photos.
    Probably a pair of resistors. But I'm also thinking, 'short heating sensor near gas tank' . . . uh hummm.
    If you do get the failed sensor out, perhaps take a Dremel tool to it and see how the short happened? Any possibility of water leaking from the outside battery vent?
    What sort of prices?
  8. cowlove
    cowlove New Member
    Seattle
    2002 Prius
    I grounded the PTNK signal to simulate a good tank vacuum, and this stopped most of the DTC's, but when the car ran the OBD2 evap monitor routine, it failed with a P0450, and left the evap monitor marked incomplete. I'll need to either replace the sensor (ie: remove/replace tank- ugh) or spoof the signal (better) before next emissions check. :(
    Upon reading this link: (can't post link, search for "EVAP VSV Prius Hybrid13.pdf")
    ... I am not surprised grounding the signal did not work. The response expected from the gas tank pressure sensor is fairly sophisticated.
    The ECM applies intake vacuum to the tank, and watches for the pressure to drop from atmospheric pressure to 20mmHg within a certain time limit. Then it removes the vacuum and isolates the tank, and watches that the vacuum held in the tank does not rise too quickly.
    I will devote an hour or so to trying to mimic this response with a little RC delay circuit driven by the signal from the ECM that seals up the tank for this test. I'll post results under a new thread if this works. It could be a fairly useful general scheme for spoofing an ODB2 leakdown test using $1 in parts.
  9. blake9809
    blake9809 Junior Member
    48
    Minneapolis, Minnesota
    2002 Prius
    SE
    I have a gen 1 prius 2002, was a good running vehicle with no codes other than a o2 sensor code because the cat was stolen. Car was running like a prius should, i parked the vehicle for 9 days and came home turned the key and the gasoline engine turns over, fires and runs for 10 seconds then stalls out. On the dash the fuel gauge blinks full then empty, full then empty continuously, the outside temp displays E, the HV battery gauge on dash displays empty. I then checked voltage of HV battery and its 303V, i then checked voltage of 12v battery and it reads 12.6v. When i scan for codes the only code that comes up is a P3106 code and all i know about the code is its a powertrain code.
    Can someone guide me on where to even start to diagnose or fix this issue.
    Bruce Berquist likes this.
  10. ChapmanF
    18,570
    blake9809 has started a thread on this issue, so replying on that thread can help avoid lost and scattered replies.
  11. Bruce Berquist
    Bruce Berquist Junior Member
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    You need to reevaluate the 12v battery and 12v system and all connections and terminals. The 12.6v reading is a healthy voltage but it does not mean that the battery and 12v power signal to the ECU syatem is actually healthy and adequate for booting up the sytem to operate properly.
    I am quite certain that you are going to resist what I tell you, but I recommend that you give it a try, regardless.
    What voltage does the 12v battery have when under the load of ignition starting position?
    That is... with the ignition in the starting position, but without starting the engine.
    If the voltage is under 12.2 volts, you are booting the system with inadequate voltage.
    For the Prius system, this 12v battery test is more important than any other type of load test typically given for ICE vehicle batteries. Two very different animals with two very different needs and requirements for the 12v battery.
    If under 12.2 v you need to install a fresh new 46ah+ battery (not just a CCA based battery).
    The process of "jumping" will most times be inadequate also, since you are passing the signal through the faulty battery.
    A complete disconnect of the old battery, then a solid reconnect of a good battery is what is needed, and this will also hard reset the ECU system for clean recalibration.
    Try it (in this exact way). You might like it.
  12. ChapmanF
    18,570
    That suggestion about the battery has already been made on blake9809's other thread.
    cowlove's issue in this thread turned out to be a faulty sensor that was pulling down the ECM's +5V supply. cowlove found the problem by following the evidence where it led.
