2005 issues and a wierd one
Discussion in 'Gen 2 Prius Technical Discussion' started by wellcraft2006, Jul 19, 2010.
  1. wellcraft2006
    wellcraft2006 New Member
    PA
    ok car was in for tune up died on the way home and then went back in. now the WIERD part... Picked up and the car has roughly 30,000 miles less on the car now...
    any ideas solutions etc. is a 2005 model year
  2. qbee42
    3,079
    Didn't you post this same question in another thread?
  3. wellcraft2006
    PA
    yes unsure where to post so did twice
  4. djasonw
    djasonw Active Member
    961
    123
    Coconut Creek, FL
    Someone drove in reverse to another dealer? It was quite a drive!
  5. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Tuned up where?
    Sounds very suspicious, there is no way the odo could have 'lost' 30K miles. What caused it to die on the way home? Could they have replaced whatever holds the ODO value with a used part? That would be sort of illegal without properly setting the ODO before returning the car to you.
  6. Ron67
    Ron67 New Member
    Hillsborough, nc
    Sure you don't have it on trip? ODO button is used to reset maint indicator.
