stereo and battery discharge while parked
Discussion in 'Gen 3 Prius Main Forum' started by Richmond, Jul 26, 2010.
  1. Richmond
    Richmond Junior Member
    17
    Seatte
    I was in the cel phone lot at the airport waiting to pick up a friend. I was listening to music for 45 mins through my USB port, but my battery indicator was down to 2 bars. I was cocerned about not being able to restart the car, so I shut the music off. I am not sure how this works in the Prius.
    1. How long approx can I listen to music while parked? Does going below 2 bars mean I may not be able to start the car? Is there any warning (flashing light/sound) if my battery is approaching below-restart levels?
    2. I see some posts implying that I can indefinitely play music, have Ac on, etc., while in park... as long as power/ready is on (so engine can kick in as needed and keep recharging battery). I understand this will lower MPG, but that is better than sitting for an extended period w/o AC or music!
    3. Does tha same battery which restarts the engine also power AC, music, headlights, interior lights, etc? What does the other battery do then...only run (or assist in running) the car when gas engine power is not needed? I obviously don't understand the tech features of this car!
  2. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    The battery meter you see is the hybrid battery. It is not used to start the engine. The 12v battery in the back is. Next time you want to idle and listen to music, just leave the entire car on with the "Ready" light lit up. that way when the battery gets low, the engine will run for a little to recharge, and shut back off.
  3. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    There is an interplay of both the 12V and HV batteries when starting.
    The following is how the Gen II works, and I believe it is applicable
    to the Gen III as well.
    The 12V battery is used first. It boots up the various computers and
    ECUs and the HSD does a quick check on system components. If all is
    well the HV battery is brought on line. Power from the HV battery is
    then used to spin Motor-Generator1, MG1, which acts like a starter
    motor and spins up the ICE.
    If you are in Park and in Ready, you can listen to music and enjoy the
    A/C indefinitely. Yes, the HV battery will slowly discharge. But when it
    gets to two bars the ICE will come on and recharge it up to say, four
    bars, then shut down. How often this happens is a function of how hard
    the A/C runs to maintain the set temperature and whatever 12V
    accessories you're also using. (See below.) The A/C runs directly off
    the HV battery.
    Standing alone, the primary use for the 12V battery is the initial boot-
    up when starting.
    However, when the car is in Park and Ready, all the various
    lights, stereo, windows, GPS, CPUs and ECUs, etc, run on power from
    the 12V battery. But the 12V battery is quite small. It is kept charged
    by a DC-to-DC converter with power from the HV battery when the car
    is in Ready. In the ON and ACC modes the poor little thing stands alone
    and can be relatively quickly discharged past the point when it can
    power the CPU boot-up on starting. This occurs at ~10.5V.
    Hope this helps.
    2 people like this.
  4. Richmond
    17
    Seatte
    Thanks, this is very useful info!
  5. 007
    007 New Member
    157
    Antigonish, Nova Scotia
    So, lets see if I've got this straight. If you at, lets say a "drive-in movie" and on non-hybrid cars you would just turn the key to ACC to power up the radio (to give you sound) so you could sit for a few hours and enjoy the movie. This is never a problem, after several hours the car always starts fine.
    However, with a hybrid, this would drain your battery to the point where the car wouldn't start? (if you listened to the movie on the radio in ACC mode, obviously you would not have the car running for the entire movie). Is that what I'm hearing?
  6. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    All accessories and computers run off the low-voltage 12V system. The only exception is the air conditioning compressor, which runs off high-voltage.
    If the car is READY, the 12V system is powered through the DC/DC converter which reduces the high-voltage from the traction battery to ~13-14V (it needs to be higher to actually charge the '12V' battery).
    The traction battery is normally charging whenever the engine is running.
    If the car is in any position other than N, it can start the engine to recharge the traction battery, if it's getting low. 'N' prevents any power from being taken off either motor.
    In ACC or IG-ON, the HV battery is disconnected from the car. All electrical systems are powered directly and only from the 12V aux battery.
    Every piece of equipment necessary to drive the car is powered up in IG-ON (LED on the power switch glows orange). This requires about 300-400W of power which will flatten the aux battery in less than an hour.
    In ACC mode, the LED on the power switch is green. A limited set of equipment is powered on, so the power draw is lower and the battery will last longer. It's still not a particularly big battery, so try not to turn too much stuff on. With the brake pedal not pressed, each press of the power button goes from OFF > ACC > IG-ON > OFF.
    The battery is relatively small because it doesn't have to start the engine. In fact the car will still boot up with very low 12V battery, but it will often behave strangely once started.
  7. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    The ACC mode turns to off automatically after 1 hour on UK models to prevent the 12v battery going too low.
  8. Richmond
    17
    Seatte
    1. What is the purpose of having this mode...IG-ON?
    2. With first press of power button, I suppose what I get is the ACC mode. The LED if orange that is, the light at the top of the circular power button is orange. The text 'Power' and the icon below it are green. I am able to listen to FM/USB music.
    3. With second press of power button, I suppose what I get is the IG-On mode. The LED remains orange; that is, the light at the top of the circular power button is still orange. The text 'Power' and the icon below it remain green. The fans and AC come on, and all lights on the dash come on (engine, seat belt, HV battery status, etc).
    Should I be seeing the LED turn green?
    4. Third press, I return to everything off...no light at all...on the power button or dash.
  9. jastin1987
    jastin1987 New Member
    san diego
    really? are you serious? i'm scared now!
  10. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Up, sorry!
    Yesterday I got my car handwashed (left with 6 bars HV) and when arrived, the carwash guy returned me the car with 2 bars level, and lower MPG! It was in a below-grade-park, warm weather and ICE, and not more than 1 hour and 10min time between leave/pick...And they have a very small area for wash/park.
    Since the time spent in washing normally does not pass 15-20min, my thoughts went to:
    "Oh no! They left in on D during the washing!"
    Can I judge that from my observations?
    Or simply they ran the car for a mile in EV to park after washing?!
  11. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    I suspect that the car was left in READY the whole time...
    Not to worry.
    Two bars is roughly the point at which the ICE comes online and
    recharges the HV battery up to 3 or 4 bars and shuts down.
    Many of the folks at parking lots, car washes, and repair shops,
    etc, don't understand the Prius. They think that like a regular car,
    if the ICE isn't running, the car/motor is shut down.
    I once left my car at a repair shop for ~10 days. When I left it, it had
    a near full tank of gas and 50.2 MPG lifetime over ~50K miles.
    When I got it back the lifetime MPG reading was ~38.6, and the gas was
    down to 3 pips :eek:
    I think that the car was in READY all or a significant part of the whole 10 days!
  12. telmo744
    2,181
    769
    Portugal
    I've just made an experience, after driving to the same SOC (6 bars), left it on Ready (with P) in my garage...and took about 15 minutes to drop 1 bar to SOC of 5 bars.
    I think they left it in D, because time of washing was about those 15 min...
  13. macman408
    1,179
    367
    Yes, but the battery bars don't all represent the same amount of charge in the battery; bar 6 is around twice as big as the others. Additionally, because of hysteresis (which keeps the bars from flickering on and off if you're right near a border), there could be as much as four times the charge going from bar 6 to bar 5 (assuming you're right at the top edge just before it'd switch to 7 bars) as there is charge going from bar 5 to bar 4 (assuming you start where bar 6 ends as you discharge).
    Specifically, if you start at bar 6, you can charge the battery up to 66.5% without hitting bar 7, then down to 55% before it switches to bar 5. But then the battery only has to drop to 52% to switch to bar 4.
    Look at the image here. Basically, as the SoC changes, the display will keep showing you the same bar until you pass the end of that bar, and only then will it switch. So after it switches to bar 4 from dropping to 52%, you have to charge up to 54.5% to get bar 5 back.
    Most likely, they left in in Ready and P the whole time; that's more than enough to discharge the battery, especially if you throw in moving the car around a couple times.
  14. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    So you have a pokey little 12 volt or a huge big 200v battery that could power your house, but people still insist on using the 12 volt?
    Just because you always listened to the radio in Acc mode in the past on non hybrid cars doesn't mean you have to now. With a hybrid you can sit in comfort with the a/c running and listen to the radio and barely use any fuel in an hour or more. Or you can leave the car in Acc mode, get hot and listen to the radio and run the risk of running the battery flat after 60 minutes.
    Each to their own I guess. :rolleyes:
  15. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Grumpy, I pretend there IS no other mode than READY. That works fine.
  16. Sergio-PL
    Sergio-PL Member
    160
    46
    Poland
    Hey... don't tell me that just listening to the radio on ACC mode with lights, console lights off, without power-hungry accessories in the 12V sockets will flatten fully charged 38 Ah AUX battery... Same sized battery is used to start normal, petrol Yaris and it doesn't get flatened within an hour of listening to the music.
    I would not recommend to do it in IG-ON mode, which _will_ flatten this battery quite short. Prius should be used either ACC or READY modes.
    IG-ON if you ask is quite useful if you had to record mileage for your records and don't want to start entire car (enginge starts immediately without 10s lag if outside temp is below freezing).
    So if you are in well ventilated place, away from other people (not to put exhaust gases directly at somebody else or window) you can play radio on READY with A/C on. If not (like in the car cinema) better stick to ACC mode (first after POWER BTN without brake) with all lights off and 12V sockets empty.
  17. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Am I and I am not saying that. The 12v will be fairly well discharged after an hour and in a Yaris it will be charged up again pretty quickly. In the Prius the charging is slower so if you make a habit of short journeys and listen to the radio in Acc mode often, then yes you will run the battery down quicker.
    Do it once in a blue moon and you'll have no problem.
  18. Sergio-PL
    Sergio-PL Member
    160
    46
    Poland
    You are right :). Discharging it once will not be a problem. Do it few times between long trips the same. But doing it every day will surely destroy battery.
  19. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Glad this topic came up- today's my first day at work with the new Prius...
    I usually spend my 30min lunch breaks sitting in my car catching up on current events via AM radio (WCBS 880 & WFAN 660). I'm hoping 30min in ACC mode with just the radio on and everything else off in a brand new car will not deplete the 12v battery? :eek:
  20. bisco
    51,562
    this is a very confusing thread.
