Build your own seat extenders
Discussion in 'Gen 2 Prius Accessories & Modifications' started by 67_tele, Jul 22, 2010.
  1. 67_tele
    67_tele Junior Member
    CT
    So I'm 6'6 and need to buy some seat extenders. However I've already invested a butt load of money into my drivers seat (doing the height adjustment mod with lumbar and heat) and find $200 for two pieces of metal to be pretty steep in my opinion. Does anyone know how these are made? I can't find anything on the forum, but it can't be that difficult. Has anyone built these extenders are their own?
    Thanks!!
  2. Politburo
    Politburo Active Member
    971
    208
  3. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    I think there are two basic ways to extend the rearward travel of the Gen II Prius.
    1. Weld on an extension of the seat rails as nyprius got a modifier of cars for the handicapped to do (nyprius used New England Wheels, Billerica, MA (about 20 miles NW of Boston) who extended both front seats for around $300).
    Here's my post explaining and showing what New England Wheels did for nyprius:
    2. Get pre-made seat rail extenders made by ExtendMySeat.com:
    PriusChat Shop : Toyota Prius Drivers Seat Extension - ExtendMySeat [ExtendMySeat] - $195.00
    Check out detailed reviews in this thread; and note that the original ExtendMySeat rail extenders had a design flaw which could lead to the extenders snapping; this supposedly was fixed with a redesign of the extenders in October 2009:
    http://priuschat.com/forums/gen-ii-...view-extendmyseat-drivers-seat-extenders.html
    Good luck.
  4. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    www.extendmyseat.com , if holding up well would be much easier than fabbing, setting and welding braces and mounts on. These came out 2 months after doing my seat remount mod. Murphy's Law :)
    That said, after being on the extender braces (I had fabbed) for over a year, they are holding up well ( I'm 180lbs).
    I used a metal shop in Hayward, CA that was willing to fabricate 2 braces from 12 gage steel. They asked for $45 for fab and welding them all mounts to the seat/rails.
    Should be TIG welded (what's used for nice stuff like bicycle frames), not MIG.
    You might be able to use a slightly thicker steel, be careful seat will clear when sliding forward.
    Each is 5" long, 1.5" wide.
    To get the seat rail in the same plane as 'stock', there are 2 slight bends in each brace since the brace attaches under the seat rail, then lays over the mount foot.
    So, at 1 3/4" there is a slight bend for 1 inch, then another bend such that the bottom of the front part of brace is flush with top of back part of brace. Gave shop basic mechanical drawing.
    Each sliding click is about 5/8" and I found 4 extra clicks plenty, so 2.5" remount of seat plenty for me (the 1 3/4" + 1" = 2.75" allows moving rails 2.5" from stock).
    Best to find a shop willing to TIG weld the braces onto the seat rails.
    It's best to bolt the braces and mount feet onto the rails, and attach the rear mounts (I used some epoxy) in the exact place in the car. Once it's set, then they are welded all around. Or you could have it tack welded, recheck fit, fully weld.
    Easier if welding is done with no upholstery on lower or any part of seat.
    You will need to sand, paint and relube rails after welding.
    BTW, the shop only wanted $45 for making the braces and welding. I gave them $80.
    Some shops will not do this work for liability reasons. I found one I like. Of course, there was no papertrail for this job, and I'm fine with that.
    Here's the relocation and weld on the rear mounts -
    Maybe an easier way (like waiting to buy a 3rd Gen Prius which is still better than where mine's at now) but that's what I did. No telescopic wheel means no matching 3rd Gen Prius.
    Looking for good pic of front braces ...
  5. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Closest pic of front brace.
    May find your screw tire jack to come in very handy for setting, installing and removing the seat once the left rear bolt is permanently sandwiched between rail and mount.
    Will need a 14mm flat wrench too ... see post #10 here
    http://priuschat.com/forums/gen-ii-...153-drivers-seat-remount-home-2-5-8-back.html
    extendmyseat brackets, if holding up well would be an easier way to go. They came out a month or two after the mod above. My first mod was to slide seat back further. Still couldn't see well, but reused the braces when building height adjustable seat.
    Good luck.
  6. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    I think it would take sophisticated equipment and knowledge to properly engineer a set of extension brackets - Pro E tools, AutoCad, something like that. Having them fabbed might cost quite a bit with setup costs.
    I think $200 is reasonable for the extendmyseats, if they are sturdy.
  7. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    It's a good thing that the people that designed everything before the 1980s didn't know that.:D
  8. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Ok alright, there's tape measure, calipers, pen and paper too. :p
  9. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Ah .. 67_tele ... where'd you go?
  10. 67_tele
    CT
    Sorry guys, I was in the cape for the past five days and had no internet. Thanks for the heads up on everything. Think I may just buy the extenders. After putting all the time into the height adjustable seat, I'm not ready to tackle another huge project just yet!
