"Park" gear
Discussion in 'Gen 3 Prius Technical Discussion' started by tt2ride, Jul 29, 2010.
  1. tt2ride
    tt2ride New Member
    Brentwood, CA
    While the Prius is moving in the Drive gear, can a driver accidently move the gear shifter to Park? Just wondering how Prius prevents this. Thanks.
  2. maximus96
    maximus96 Junior Member
    Bay Area, CA
    you'd have to accidentally push the P button as there is no way to get into Park from the shifter as far as i know, but i've only had my prius for one week...
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    If you accidentally press Park at speed then the car will just go to Neutral. I know as I did this myself when I thought I was pressing 'Auto' on the a/c.
    Apparantly pressing Park below 10mph will engage park and is not recommended for the good health of your transmission or wallet!
  4. tt2ride
    tt2ride New Member
    Brentwood, CA
    How about the Reverse gear? Will you be able to shift into it while driving? Everything is so electronic and I am still overwhelmed with the features in the car. I can just sit in there for hours playing with everything :)
  5. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    Reverse is the same as Park if you're traveling above a few mph the car will immediately shift to Neutral if Park or Reverse are pressed/selected. No damage is done. In fact the quickest way to Neutral when moving is by pressing Park since when shifting to Neutral you must hold the lever for a second or two. Park shifts instantly to Neutral.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    post was redundant, removed
  7. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    here is a operation schema, unfortunately it is in Czech language, but Google translate will help in case of need.
