2008 Prius not starting! HELP
Discussion in 'Gen 2 Prius Technical Discussion' started by dan342, Aug 3, 2010.
  1. dan342
    dan342 New Member
    I have a 2008 prius and had to change my drivers side airbag recently. Before it was changed, it started just fine, but now after it was changed and the airbag computer was reset the car doesn't start. It does shift from park to neutral, but not into drive, reverse or B position.
  2. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Do the brake lights come on when you press the brake pedal? This should work in all modes including OFF.
    If not, the brake light switch has stopped working and the car can't tell that you're holding down the brake pedal when you press the power button. Check the 7.5A fuse marked STOP is intact.
    If the brake lights don't come on until you've pressed the pedal quite a long way, the switch needs to be repositioned so it comes on as soon as the pedal is pressed.
    If the brake lights do come on, but the car won't go READY, check the wiring from the brake light switch to the Hybrid Vehicle Control ECU (HV ECU) and to the Power Source Control ECU. This wiring is part of the main Instrument Panel Wire harness.
    Since it will shift out of Park, it's quite likely that the connection to the HV ECU is working properly, but the connection to the Power Source Control ECU isn't. This connection is made between a junction connector J9, in the extreme left of the dashboard, and the wiring harness connector IA3 which is at the top of the extreme left of the dashboard.
    If you find that any of these connectors or wires are damaged I would ask for the wiring to be thoroughly checked over before driving the car.
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Did you disconnect the HV battery before you carried the work out?
    If so, you're sure you clicked it back properly?
  4. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    I would put my money on the 12V battery being weak.
  5. dan342
    dan342 New Member
    After a couple times of taking out and putting back the main fuse it started. But for some reason the airbag light is still on. Any ideas?
  6. richard schumacher
    7,664
    1,046
    United States
    Taking one step back: why was it necessary to replace the airbag? Was the car in a collision?
  7. Patrick Wong
    18,201
    6,503
    My idea is that the SRS ECU thinks there is still something wrong with the airbag system, so you should take the car to a Toyota dealer to have the DTC read. Good luck.
