When to use the "B" position?
Discussion in 'Gen 2 Prius Main Forum' started by blades, Aug 2, 2010.
  1. blades
    blades New Member
    24
    Frankfort, KY
    When is it appropriate and beneficial to use the engine brake, or the "B" position on the shifter? I live in a rather hilly area and have been playing with it lately, when coasting down long hills where the speed limit is 35, it helps to keep the speed lower without using the brakes so much.
    Assuming this is appropriate use of the B position, are there any compelling reasons to NOT use it that I should know about?
  2. Patrick Wong
    18,200
    6,501
    The B position will cause the gasoline engine to rev up. The energy used to spin the gasoline motor becomes frictional heat loss and cannot be recovered.
    I usually leave the gear selector in D until the traction battery SOC gauge on the MFD shows eight green bars. I would then shift to B.
    Once the gauge shows eight bars, even if you don't shift to B you'll note the engine speed increase. This is because the hybrid vehicle ECU does not want to overcharge the traction battery.
  3. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Patrick,
    I could use some additional clarification.
    Does "B" only just spin up the ICE?
    I've somehow come to believe that when in "B", regen is also enhanced.
    Yes/No?
    Further, my experience is that if you forget to drop out of "B" at the
    bottom of the hill, you can happily drive all the rest of the day,
    unawares that staying in "B" restricts the HSD's use of electric only
    drive -- not really EV because it's the computer's choice not the driver's --
    and results in significantly reduced FE/MPGs.
    Again, Yes/No?
  4. blades
    blades New Member
    24
    Frankfort, KY
    Thank you for the explanation, Patrick.
    It could be argued that using the brakes will also result in unrecoverable frictional heat loss as well. Is it the lesser of 2 evils, or is there more to it than that?
    I did notice that the batteries were charging when I was in B, but I didn't take note of the state of charge of the batteries at that time. I will have to pay closer attention to that.
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Regen is enhanced over using the Disc brakes, but not over D mode.
    You can't use Cruise Control in B, so you can realize you are still in B that way.
  6. Patrick Wong
    18,200
    6,501
    I would agree with both of the above statements as edited. When in B, regen is enhanced compared to being in D and coasting. However regen is best when in D and braking moderately.
    Remaining in B while driving around is the logical equivalent of leaving your normal car's automatic transmission in Low gear and driving around (except there's no regen with a normal car, of course.) The result in both cases is poorer mpg compared to leaving the gear selector in D.
    When you are in D and apply the brakes moderately, most of the braking force will be regen, not friction. The braking will be friction when your speed drops down to a single-digit number, or you are doing a panic stop.
    2 people like this.
  7. blades
    blades New Member
    24
    Frankfort, KY
    I'm lost: how can the B position achieve enhanced regen over using the disc brakes, when you are normally in D mode anyway? :confused:
    Is there some form of regen that takes place when braking, that is different from the normal deceleration regen that takes place?
    Sorry for the n00b level questions, but I find this a very interesting discussion so far. ;)
    Edit: I just read Patrick's post. I thought "regenerative braking" was merely another way of describing "decelerating". I didn't realize that the act of braking actually caused regen. Very interesting stuff!
  8. dogfriend
    7,512
    1,190
    Carmichael, CA
    Regenerative braking = converting forward momentum into electrical energy (using MG2) and thereby slowing the car down.
    Friction braking = using the brake pads on the rotors to slow the car by dissipating the forward momentum as heat energy.
    The Prius software attempts to use regenerative braking as much as possible, automatically blending regen braking and friction braking when it needs to, and switching completely into friction braking in the event of a panic stop (ABS only functions with friction braking) or when the braking force from MG2 is no longer enough to slow the car (under approx 7 mph).
  9. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    In D mode, when you take your foot off the gas, you are using MG1 to give the illusion of engine braking, this does mild regen. Once you put your foot on the brake, it uses MG2 as more serious regen.
    B mode goes straight to MG2 regen, but because it also makes the engine an air pump, it does less regen than just hitting the brakes in D mode.
    On a long down hill, the only place I recommend B mode, you can over charge the HV battery such that all you have left is Disc Brakes, using B mode adds engine braking to delay that.
    3 people like this.
  10. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Or if the battery is full, which is when you want the B position so you don't need to ride the friction brakes until you burn them out on a long downhill.
  11. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
  12. richard schumacher
    7,664
    1,046
    United States
    Don't over-think this. The purpose of "B" is to help avoid burning up the brakes. Don't try to use it to manually manage the battery state-of-charge because you will almost certainly do it worse than the car itself does, and fuel economy will be reduced.
  13. ML Diggs
    ML Diggs Junior Member
    71
    Portland Oregon
    Thanks, Richard. I was wondering about that. I do regularly drive into the mountains and coast down 8-10 miles of 4-6% grades. The SOC always gets to fully green in these situations. Does the battery NOT have a charge controller? I have a solar panel and battery for a trailer, and that had a charge controller so the battery wouldn't over charge. I would hate to overcharge the battery and fry it with this kind of driving pattern, but moving to B seems like an awfully low tech way to protect the battery on such a high tech car. I figured I would use B like I use 3 on my Silverado--namely, when I don't want to wear down by brake pads by braking for 10 miles. Usually, however, just coasting and anticipating is enough to avoid friction braking.
    So, can the HV battery be hurt by constant charging and little depletion, or does it just get full and disregard the excess?
  14. BAllanJ
    667
    78
    Kingston Ontario
    it won't overcharge but it will switch to friction brakes to slow after that and they will then fade if the hill is long enough... I think of B as usefull when I would use a low gear on a downhill in a regular automatic except that if I'm not at a full battery I may delay B until it is full.
  15. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The computers will always protect the battery, but when they quit charging to do so, you will lose the regenerative braking.
    For most drivers, B is a 'frill,' but if you drive down long slopes, it is a safety feature.
  16. qbee42
    3,079
    A minor addition to the above: when the battery SOC gets to the high limit, the controller will first switch to engine braking. Think of it as an automatic shift into B mode. If that still isn't enough, only then will friction brake be applied.
    The advantage of switching to B mode early is to forestall getting to the high SOC limit. I've never had this be a problem on a 6% grade at highway speeds. At lower speeds it can be an issue due to lower aerodynamic drag.
    At no point will the battery controller *ever* allow the SOC to get dangerously high or low.
    2 people like this.
  17. dogfriend
    7,512
    1,190
    Carmichael, CA
    I'm hoping this was just a typo. :madgrin:
  18. qbee42
    3,079
    Perhaps more of a Freudian Slip. I knew eventually my true feelings about B mode threads would color my response. ;)
  19. blades
    blades New Member
    24
    Frankfort, KY
  20. JimboK
    2,817
    188
    49
    Chesterfield, VA
    You're most welcome!
