06 Prius, cant get over 41mph average.
Discussion in 'Gen 3 Prius Fuel Economy' started by go_prius, Aug 3, 2010.
  1. go_prius
    go_prius Junior Member
    Kansas
    Well just got the car a couple months ago, and my best tank was about 41.2mpg or so, I have put 42/40 in the tires, "pulse and glide" tried anything I could find on here, tried just going about 55-60 on the freeway, everywhere. in town is not any better. Everythings kind of hilly, but I have friends around here with a VW's jetta, a civic hybrid, and Joey has a geo metro, they all easily get 40-45 in this area, so I don't think its the land, what could it be? the car rides fine? the only things I haven't really checked are the oil and air filter, but their is a "Jiffy Lube" sticker on the inside that says I have a while to go before I need a change, I believe it was just changed before I got it. Could the type of oil/oil level or air filter be causing this? any help would be greatly appreciated, thanks!
  2. go_prius
    Kansas
    OOps I meant MPG
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  4. go_prius
    Kansas
    My bad, as obvious as it is I'm new here, Wish I could fix my typo, and put it in the right threads, so if a mod reads this please do that for me, Thanks :)
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    That's the problem right there. Change it with synthetic and make sure it is filled up to the correct level.
    Can you describe your typical trip? Distance, highway, city, etc...
  6. fingas
    fingas Junior Member
    63
    Orange County
    Strange, I was getting 52mpg average on my '07, then went down to 46mpg after I upgraded to 17" wheels.
    posted from my HTC Evo
  7. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Don't crawl away from stoplights and stop signs. Accelerate smartly, quickly up to speed, then ease off a little bit.
  8. bwilson4web
    16,326
    The easiest way to attract their attention is to hit the little "flag" icon to the lower left. Just describe the problem and soon enough, the magic will happen.
    GOOD LUCK!
  9. richard schumacher
    7,664
    1,046
    United States
    And he's not kidding. The oil could easily be grossly overfilled, or they may have used the wrong weight. Go check the level now. (Always check it yourself before driving away from every oil change. This will catch common stupid mistakes before they become expensive.)
    Short trips and very hot weather will reduce MPGs, but *do* use the A/C. (The battery system draws its cooling air from the cabin; if you're not comfortable then neither is the battery.)
    Was the car a Toyota certified used, or was it inspected by a Toyota dealer before you bought it? If not almost anything could be wrong.
    Do you ever shift into "B"? If so, don't. You're about 500 miles from the nearest terrain where "B" might ever be needed.
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Not strange. Larger wheels are heavier & tend to reduce FE. The replacement tires may not be LRR which will be another hit. Your new tires may also be underinflated. Fill to max sidewall pressure to get some of the lost FE back.
  11. bac
    bac Active Member
    863
    52
    Pennsylvania
    That's what we need to know.
    My commute went from 40 minutes of 2-lane roads to less than 15 minutes of nearly all interstate @ 75-80mph.
    I was averaging 54mpg. I now average around 45mpg.
    The primary factor is HOW LONG of a trip do you normally take. Sans a block heater, all autos have to warm up. As they do, fuel economy is not on par with that of a warm engine. My Prius seems to generally get around 25mpg in this 5-minute warm-up stage.
    With less than a 15 minute drive, over 1/3 of my commute is sans a warm engine. That is the primary reason why my mileage went down so much. If you have a similar commute, I'd expect similar numbers.
    By the way, this has nothing to do with the Prius. All autos suffer from poor mileage during this initial warm-up stage.
    -Brad
  12. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
    I had a Gen I that when traded in could only manage 25-30 mpg. Dealer conclusion: battery growing weaker requiring the ICE to "pick up the slack". Surely not in your case I hope.
