heater box damage
Discussion in 'Gen 2 Prius Technical Discussion' started by suemand, Aug 2, 2010.
  1. suemand
    suemand New Member
    CT
    My dealership says my "heater box" is damaged and needs to be replaced. My carpets are soaked. The insurance company says its not covered - I do have broken off parts. Anybody ever had this problem?
  2. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    Do you have any more details? Was this car in a accident?
  3. suemand
    suemand New Member
    CT
    No accident - we thought the a/c drain was plugged, but the dealership said there was a hole in the heater box - had to be quite a hard blow to break the plastic. Don't know how it happened, but all the water from a/c drips right into the cabin - when I say the carpets are soaked, I mean really really soaked - squishy wet. I'm trying to dry it out - but if the ins won't pay, I can't do $3000 to replace the box - any suggestions?
  4. jelloslug
    813
    55
    Greenville, SC
    Can you see the hole? If so get some clay type two part epoxy (think Mighty Putty) and plug the hole.
  5. suemand
    suemand New Member
    CT
    Thanks - I'll do that - this stuff is waterproof?
  6. richard schumacher
    7,682
    1,063
    United States
    $3000 sounds awfully high. Get a second opinion from another dealer. If the 2nd opinion is equally high perhaps it could be patched [uhh, kinda like jelloslug suggested], maybe by an independent shop.
    If it is not repaired or replaced I think you should not use the A/C at all. The condensed water would eventually destroy things. It might be OK used for heat only.
  7. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    Get a plastic floor mat with a raised edge.
  8. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Where exactly is the hole? Could you post a picture?
    There is a recent thread where someone pulled all carpets and floor boards to dry/replace with photos and reference to a salvage part dealer. Do a search. Good luck! :)
  9. jelloslug
    813
    55
    Greenville, SC
    Yes, it's waterproof once it's cured.
  10. qbee42
    3,081
    $3,000! That sounds a tad high. Do they throw in an new HV battery for free?
