Newbie is skeptical about 12v battery/mileage relationship
Discussion in 'Gen 2 Prius Technical Discussion' started by mlbex100, Aug 10, 2010.
  1. mlbex100
    mlbex100 Junior Member
    49
    22
    South Bay
    Three Touring
    I'm a newbie. I've had my used 2005 Prius since Saturday, and I've been lurking on this board since yesterday.
    I've seen several posts where poor mileage (in a Prius, anything less than 40 is "poor") is being blamed on the condition of the 12V battery because the car must use excess energy to charge it.
    I don't believe it. Relative to the power it takes to move an automobile, charging a battery that is mostly charged already (it had enough juice to start the car after all) should be trivial. One poster suggested that the low voltage output might be causing the control systems to run poorly (I forget the details), but you'd think that sensors would detect that.
    Recharging the drive batteries could be a significant drain. I hope they hold their charge for a day or two.
    BTW, my posted mileage according to my car's gauge is about 46 mpg, with mixed freeway and town driving. I'm still training my foot, but around here, you need to move or get out of the way... creeping along can get you in several kinds of trouble.
    My commute is 5 miles each way; I hope this doesn't kill my mileage too much.
    And I already get a charge out of getting the high mileage.
  2. cthindi
    cthindi Member
    177
    85
    Connecticut
    With 5 Mi commute each way you are not going to get much more than 46 MPG.
    Have you been on longer trips? How much did you get on those?
    Pumping air up to 40 Psi could add about 2 MPG. IMO Toyota recommended pressure is on lower side. Treadwear was much higher on the sides when I bought my 2005 with 73000 Mi on it.
    With my 42 Mi one way commute and driving the car at about 70 MPH I am getting 50 MPG in summer and 44 MPG in winter in Suburban New York.
    First 4-5 Miles of my commute average around 30 MPG.
  3. mlbex100
    49
    22
    South Bay
    Three Touring
    I haven't had it long enough to compare long trips to commutes. Some time later, I'll reset the meter and just commute for a week.
    I sure hope I can beat 30mpg that you're getting on the first 5 miles. I could just about match that in the '01 Camry that I traded in (well, not quite - the Camry only got about 22 in town).
  4. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The discussion of 12v batteries causing MPG loss is when a cell gets shorted. The Prius charging system provides a constant voltage (about 14v) which in a good 12v battery limits the charging current to below 2 amps decreasing to a trickle if fully charged. A shorted cell reduces the battery voltage and significantly increases the charging current. Since the charging system can provide up to 100 amps (which, at 12v is a loss of almost 2 horsepower), it can reduce your MPG noticeably (up to 10% when cruising).
    JeffD
  5. mlbex100
    49
    22
    South Bay
    Three Touring
    So the generator might be providing a constant 100A x 12V (1200W) and there is no sensor to detect this?
    That 1200W has to go somewhere. Generally, 'unused' Watts get converted into heat. That is close to the amount of heat generated by a household plug-in room heater (1396W max, I think). You'd feel that kind of heat unless it is happening under the hood instead of on or near the battery.
    Experience seems to have proven that a bad 12V battery can significantly reduce mileage, but I'm still skeptical that it is caused by the current drain used to (attempt to) keep it charged. Still, if my mileage tanks, I'll check the 12V battery first.
  6. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    Anything (constant charging due to a defective battery) that causes the gas motor come on more than needed for forward motion "wastes" gas...ie decreases mpg. Another good example is the AC running more during very hot weather. Small percentages of 50 MPG are much bigger numbers and more noticable than the same percentages of lesser MPG readings in other vehicles. The prius uses most of the tricks in the book to wring every ounce of energy from the gas. In total these strategies equal the best hybrid mpg around.
    :welcome:
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Also just to add to what has already been said, just because the 12v started the car, it does not mean it is healthy. In a regular car your 12v takes a beating when it turns the starter over. Therefore if the car starts, your battery is in pretty good shape. Otherwise you click click click. However in the prius, the 12v flips a couple relays and that's it. If the brake has no pressure, then it draws a bit of power to pump them up and then flip 2 relays to connect the HV battery. The HV battery is what is responisble for spinning the motor that starts the engine.
    Also, have you ever hand spun a brushed motor generator? With no load it spins really easily. Add a load, even a little bulb, and you have to work for it. Now have you ever pushed a car in neutral? It takes a lot of energy to get it moving, however once it is moving it takes almost no energy whatsoever to keep it going. Good 'ol physics, it is acceleration.
    So everytime you glide, you can be drawing almost no power or you can draw that + wasted charging current.
    I think the other guys have taken care of the rest. Hopefully you see the light. :)
  8. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    There is no generator.
    If the 12V battery has a shorted cell, it will be noticeably warm after the car has been run for awhile. That's easy to detect.
    The battery is in the rear passenger side of the hatch, under the floor. Easy to get to if you lift out the hatch floor, then the cargo container.
    -MOST- people who get poor mileage in a Prius do so because of short trips and/or "zippy" driving. Once the car is warmed up mileage is phenomenal. It takes 10 min or so to -fully- warm up a Prius. A little longer in winter.
    You can test this using the MFD. Once you have driven for 10 min reset the MFD (second screen bottom right). Then watch the calculated mileage. It will be much higher than what you will see doing this when it's cold.
  9. hill
    8,897
    Don't worry about the aux battery giving you / NOT giving you a mileage hit. Your 2005's aux battery is roughly 5 years old. Get rid of it. They're prone to die on you when nearing 5 years. Switch to an optima. Same size, better price, more power:
    http://priuschat.com/forums/gen-iii...shooting/68837-12-volt-battery-elearnaid.html
    There are tons of threads here regarding increasing your mileage. Following their advise you WILL get a charge. The tricks & traps of better mileage I've learned here over the years has helped me a TON:
    My next goal is to hit 80mpg on one tank. Several folks here already have done it. And it DOES give you a charge ... OCD speaking
    :p
  10. snead_c
    667
    58
    Hendersonville
    Please report to us when you reach 80 :rockon:
    Charlie
  11. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Try rebooting, search andyprius, do the speedlimit, drive more than 5 miles OR live with 46mpg.
