Rust - Corrosion warranty.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RL Prius, Aug 7, 2010.
  1. RL Prius
    RL Prius Junior Member
    77
    Bay area
    I have a 2010 Prius III(base) purchased last August. Right now it has little over 6,000 miles. I am located in Northern California(San Francisco) Never took the car to the Reno(never seen snow)
    What interesting today is I jacked the car up today to put on a set of TC wheels. During the process, I checked the underside of the car. And I noticed quite a bit of rust is forming in the under carriage. I am quite surprised. Lookover the toyota warranty it said 60 months/unlimited miles (corrosion perforation of sheet metal).
    Questions:
    1) Why rust is developing?
    2) Will it covered by the warranty? what do they usually do?
    3) Should I consider add any protection to protect the underside??
    Suggestion please...
    Sorry I already put the car back together. Will take some pictures if I have time.
    Thanks in advance
  2. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    You will always see surface rust on the underside of the vehicle, its normal. What you want to be looking for is perforation, and the corrosion warranty covers specifically that...
  3. dogfriend
    7,512
    1,189
    Carmichael, CA
    Because your car is doomed (thermodynamically) to eventually become a pile of iron oxide. This is one of the only things that I clearly remember from taking a graduate class in corrosion. You can slow down the process, but both the driving force (energy available for reaction) and the kinetics (speed of the reaction) are favorable for "rust".
    Your environment is better for rust formation (salt water fog is a nice electrolyte) compared to the environment in Arizona, but be thankful that you don't live in Detroit or Buffalo.
    Nah, it won't rust through fast enough unless you go out and splash acid on it to speed up the reaction. That is why it is a "perforation" warranty; even in Buffalo it takes 6 years before the body starts to have new holes in it.
    You might, but it probably isn't rusting fast enough to functionally damage the car before it dies from some other affliction. Spraying it with oil would probably slow down the surface rust on the underside. I know that my Ford doesn't have any surface rust on the parts where the oil leaks from the underside and coats the transmission crossmember.
    Relax and think happy thoughts.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Don't you remember the environmentally friendly commercial Toyota put out during the Olympics where the car faded away into the Earth...? Dude, you bought an green car. :)
  5. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    You can always apply "undercoating" but it will add weight to the Prius and thus reduce its mpg. It's a spray tar that bonds to the underside, but you would need to clean off the existing corrosion for it to stick properly.
  6. Dominic
    Dominic New Member
    Halifax, Nova-Scotia
    from what i was told in quebec, (and it makes some sense)
    Toyota does not recommend undercoating or rust protection on hybrid cars. The reason being is that it could create an unwanted link between circuit and well you know the rest!
    all dealership i've been to in quebec were on the same page when it came to that, however, in Halifax, it was another story. nobody had heard that before except one mechanic who agreed with the previous version.
    what do you guys think? what have you been told?
    thx
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    A problem with tar/asphalt like undercoatings is that unless done perfectly they can trap rust and moisture and your car can corrode away hidden by the undercoating. Once a car leaves the factory it becomes difficult or economically impractical to effectively apply a tar type undercoating. As mentioned, they also add weight.
    There are anti-rust treatments that are more of an oily-waxy treatment with chemicals added to suppress rusting. Krown in the GWN is one with a good reputation according to my GWN contacts. Krown dealers even shoot it into car body cavities by making a small hole and shooting it on with a long nozzle.
    I seriously question the story about Toyota being concerned about an "unwanted link between circuit and well you know the rest". Salty water and slush from salted roads is a far bigger electrical hazard than any undercoat.
  8. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    This absolutely made my morning.
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I was thinking, "It's not a bug, it's feature."
  10. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Normal on all cars but in almost all cases your car's body will rust to hell before the undercarriage, that's why you can see old rusty vehicles that are still functioning.
    Regarding oil I've heard some people regularly spray the bottom of their vehicle with oil to slow the rusting process. Seems environmentally unsound, though. I just don't bother doing anything for better or worse.
