how can charger hv battery back
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ali3d2004, Aug 10, 2010.
  1. ali3d2004
    ali3d2004 New Member
    iraq
    please help
    I left my car without driving for a period of approximately 5 months
    And now I can not drive a car because of low HV Battery Back
    How can I charge the battery charger is there and what is his name and type of Charger
    Knowing that I live in Iraq have brought the car from the U.S.
    There is no repair center in Iraq for prius
    ???Where can I find a HV battery charger WITH PHOTOS
    Ali form iraq
    thanks
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Hello and welcome Ali.
    First off, you "can not drive" because the car will not start up (go to ready mode)? If that is the case, it is your 12volt secondary battery that needs charging. That is the most common problem seen. Pretty unlikely that it is your HV battery.
    A standard battery charger will charge the 12volt battery (in the rear of the car). See Owners manual.
  3. ali3d2004
    iraq
    thank you..spiderman
    how can i charge this battery .. can you send me photos
    wen I can find owner manual
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It is the same as any other car. Go to the Middle East equivalent of walmart and buy a battery charger. Or take it to any auto dealership and have them jumpstart it for you. I highly reccomend smart jumper cables to be used to prevent against reverse polarity and sparking.
  5. ali3d2004
    iraq
    I live in Iraq and does not have centers for sale we can you send me a picture of the charger and is there a substitute for the original Charger
  6. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    There is no original charger.
    If any other vehicle has a dead battery, it is an identical process to jump start it using these:
  7. 10priusII
    10priusII Junior Member
    22
    stockton
    We should refer to manual!!
  8. ali3d2004
    iraq
    thanks..2k1toaster
  9. ali3d2004
    iraq
    have experience from another car charger for an hour because I did not ... What is the most successful solution!!!
  10. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You are confusing two things.
    Do this:
    1) Connect jumper cables
    2) Wait like 10 seconds
    3) Push brake pedal, push power button. Make sure car goes into READY mode
    4) Disconnect jumper cables
    5) Walk away for an hour OR put into drive and drive around OR put into drive, put one foot on the brake and the other on the gas, and force charge it
  11. ali3d2004
    iraq
    My car has not been operating for five months and does not have the charger
  12. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    THE ENGINE IS YOUR CHARGER!!!
    The battery you jump is to get the car into READY. After that, the engine takes care of the battery. Even at 1bar, the HV battery (the picture) is still at 40% charged which is fine.
    Your car has 2 batteries. The one you jump to get it into READY mode, and the big big one that charges from the engine.
  13. ali3d2004
    iraq
    sorry!! my english language is not good
    Is it possible to send me pictures illustrative
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    At this point:
    Just reconnect the cables in the car to the battery.
    Reconnect the jumper cables to the battery.
    Press the start button with brake applied.
    Assuming the Ready light appears, your car will operate normally.
  15. ali3d2004
    iraq
    Do you mean by car charger or through the 12-volt charger
  16. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    make sure you have gas in the car
  17. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
  18. ali3d2004
    iraq
    Where can I buy high-voltage Battery charger
    Hello
    Is it possible to help me to find stores that sell high-voltage Battery charger in any country in the world
    This image Charger
  19. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    Re: Where can I buy high-voltage Battery charger
    what do you mean high voltage? all battery chargers are either for 12V batteries or 6V motorcycle batteries.
  20. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    That is the special hybrid battery charger. But why do you need it?
    Wayne
