Does Prius III has anti-roll bars?
Discussion in 'Gen 3 Prius Technical Discussion' started by youzigo, Aug 12, 2010.
  1. youzigo
    youzigo Junior Member
    Taiwan
    Does Prius III have anti-roll bars?
    1. Is Prius III equipped with anti-roll bars? Japan and American Toyota websites say that Prius is equipped with front anti-roll bar but without rear anti-roll bar. However, both of motertrend and cochranetoyota webpages say list that Prius owns rear anti-roll bar as well as front one. Which one is true?
    2. The rear suspension system of Prius is torsion beam style, not independent style. Some people say that anti-roll bars are much more helpful to independent suspension structure than torion beam. So is it worthy to add an rear anti-roll bar to reduce the rolling while cornering?
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
  3. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    I would love to put a rear anti-roll bar on my car. I had one on my MkIV GLI and GTI (both had beam rear suspensions) and they made cornering even more entertaining. ;)
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    For the title I was expecting whether there was a rollcage inside the cab. I guess I am more use to anti-sway. I would think a stiffener would be more beneficial to the Prius, no?
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I took a look at mine and it doesn't look right to be an anti-roll bar The way the ends are flattened and the way it is bolted it wouldn't resist torsion very well.
    If I had a Prius sized BBQ-spit like the shop in the photo does, I could give you a more definitive answer. But, from what I can see looking under my 5.5 inch ground clearance car, the bar is there to provide some side to side rigidity like aftermarket strut tower braces do in the front.
    The official name for the bar in the picture is
    "REAR SUSPENSION BRACE SUB-ASSEMBLY" which also indicates it's a brace, not an anti-roll bar. That name is from the 2010 Toyota Repair manual
    Toyota lingo for anti-roll bar is "Stabilizer Bar"
    A little background on twist beam rear axles. The manufacturer can design as much anti-roll stiffness as they want into the axle itself. The lack of an anti-roll bar doesn't mean they skimped.
    If anyone does add anti-roll stiffness (bar or otherwise) to the rear of a FWD car, be sure you don't add too much. You won't know you added too much until someday when you back off the throttle in a hard fast turn and then get to watch the rear of your car become the front of your car.
    douglasjre likes this.
  6. mmichaell
    mmichaell Member
    241
    chicago
    I did that with my Civic a long time ago actually - put on rear bars that were a little too thick, took a turn too fast and almost slammed sideways into a parked car. After that I had to adjust my tire pressures to compensate, so didn't have that problem again (but then I didn't drive it that crazy again either). Cornering was really nice though, esp. with sticky summer tires.
    mc
  7. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    If you stiffen the rear end on a front wheel drive car you will get understeer under accelleration.
  8. chrisj428
    680
    144
    35
    Vernon Hills, IL
    :cool: Exactly!
    That's what made on-ramps so much fun in the GLI. Watching that little ESP light winking all the way up.
  9. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Gen2 has rear stabilizer and Gen3 doesn't.
    Following is a copy of my post.
    FYI,
    Following figures are Iconic Prius rear suspension with the stabilizer bar and Auris rear suspension.
    I think Auris's one (same as 2010 Prius) is stiffer eliminating to add an independent stabilizer bar.
    Ken@Japan
  10. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Ken, can you find out what the bar in front of the Gen3 rear axle is? It doesn't look like an anti-roll bar, it looks more like a chassis stiffener like a strut brace but I can't be sure without getting under the car.
    The bar shows in these pictures from another poster's thread.
    http://priuschat.com/forums/gen-iii-2010-prius-main-forum/68549-photos-taken-bottom-of-my-prius.html
  11. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
  12. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    TRD rear sway bar (22.6mm) from Scion XB [2008+] works, I have one on my 2010.
    Forgot to get some pics when I had it on the lift, so these will have to do for now. Also, any aftermarket front and rear sways for an 08+ XB will work on the 3rd gen's. Also, a stock front sway bar from a current body style Rav4 will work and is 2mm larger (26mm) then 3rd gen stock front sway bar (24mm).
    3 people like this.
  13. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Thanks for the x-reference info:cool:
    Are those muffler clamp looking mounts TRD parts too?
    What difference have you noticed, other than less lean and most likely quicker steering response? Have you pushed it hard enough in a corner to see how your car acts when it's pushed past the limits?
  14. josh2008
    365
    144
    Princeton, WV
    Yes those are the parts included in the TRD installation kit. I autocross my Prius, so it gets pushed to the limits. With the RSB and Tein H-Techs (I also have some custom interior x-bracing) you can get the car to oversteer. It has totally changed the feel of the car,I love it.
  15. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    If the car is stock, adding a rear sway isn't going to help as the rear tends to slide already (stability control will knock the car back in its place if you slide it too much). If you have a bigger front bar (which the car could use due to its massive bodyroll), then yes it would be a good idea to put a rear bar to compensate.
    Do you force charge your battery when you autox? I hate how the battery is depleted after the first run!
  16. josh2008
    365
    144
    Princeton, WV
    I don't force charge as Auto-x'ing already builds tremendous amounts of heat in the inverter/hv transaxle/hv battery. I place the vehicle in inspection mode when I'm in the starting grid. I run in inspection mode with B mode and PWR mode activated. Oh and the RSB does help flatten the entire chassis and does allow the vehicle to turn quicker. Next up is larger front sway bar and front strut tower brace.
  17. cossie1600
    903
    94
    CT
    I don't do it either as I am worried about the same thing. Without the stability control disabled, a snappy car will only lose time when it slides sideways. I found it tough to run without the 15-20hp from the electric motor as they really help.
  18. Bellwilliam
    Bellwilliam New Member
    LA
    huh ? Prius is an oversteering car ?
  19. Bellwilliam
    LA
    I plan to add just rear sway bar. to fix the understeer. thanks for your post. I will order an 08 XB TRD rear sway. I have 2 race cars, can't wait to take the Prius out to track days !!
    do u run staggered tires ? wider on the front, narrower at the rear ?
  20. bwilson4web
    16,121
    On our NHW11, 2003 Prius, I'm running:
    • 195/70R14 - front
    • 175/70R14 - rear
    But I'm doing this for mileage and handling tests. Now that the cooler weather is returning, I'll be able to complete my tests.
