New Prius in the mountains
Discussion in 'Newbie Forum' started by RichardinNC, Aug 13, 2010.
  1. RichardinNC
    RichardinNC New Member
    Hi everybody:
    Traded our '08 Civic Hybrid for a 2010 Prius this week.
    Up to this point, the Civic Hybrid was the best car we've ever owned but I must say that our new Prius is already outperforming the Civic by a large margin.
    Long grades that completely discharged the Honda's battery only deplete the Prius battery by 2 bars or so.
    Can now climb these grades, with 3 passengers, at 55-60 mph without straining the car.
    AC is much colder.
    Heavier feel, less road noise, much more interior room and storage.
    Went to Chattanooga, TN for a short overnight stay. Filled up before the trip and the indicated fuel economy with two adults and one child was 60.1 mpg driving west.
    Trip back brought it down to 53.5 mpg We let the car idle some with AC running because we were trying to understand where the attractions were and the temp was 99-100 degrees. Even so, the Civic would not gain mpg over 60mph. Seems like the Prius mpg will continue to climb at higher speeds if kept in the proper economy range.
    I'm used to driving the Civic for maximum economy so this may have helped with the Prius mpg. Having said that, the Prius just seems to be a large improvement in all areas. We'll have to see about reliability - the Civic Hybrid was completely trouble free.
    3 people like this.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Welcome to PC and congratulations on your upgrade to the Prius. Keep us posted on your mpg accomplishments in the mountains.
    I just got back from a trip to the Rocky Mountain, Yellowstone and Grand Teton national parks. The Prius was well represented in the mountain areas. I was really surprised at how many I saw, a good mix of Gen II and III. So, not only do they have the lowest emissions but apparently they perform very well in the mountains, as you indicate.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Did it do that when the HCH was new? I didn't know IMA would draw that much power from the battery.
  4. RichardinNC
    Yes - The battery would always deplete to one bar or at least down to the point that the IMA would not kick in. We're talking about long 7-8% uphill grades of several miles. The battery always quickly recharged on the down hill side of these grades.
    The Prius just seems to be more robust and handles these mountains with much less effort. When the Honda hybrid was new I tried to follow a Prius across the mtn. and it ran off an left me - couldn't keep up.
    I still think that the Civic Hybrid is an excellent vehicle but the 2010 Prius that we now own seems to be superior in every aspect.
    We took another short trip yesterday - about 90 miles round trip - with 3 adults and 1 child. Mixed 45mph local roads and 65mph 4-lane with long grades up and down. Did a little better than 50mpg.
    The Civic needed about 20,000 mi or so before the maximum mpg was found. Is this typical with a Prius? Also, the Civic came with low rolling resistance tires which were awful. When replaced with a better tire the mpg went down about 3-4. Our Prius has tires with a more conventional tread and it seems that Toyota doesn't use the LRR tires to boost mpg.
  5. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Prius tires are next gen LRR tires. The OEM tires are pretty good with basically no compromise especially in wet surface.
  6. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    :welcome:
    Glad to have you here.
  7. RichardinNC
    Thanks for that info. The Civic OEM tires were real stinkers - almost no tread pattern and terrible in heavy rain. Also very rough riding when the tread was quite worn - my wife hated them.
    Just manually computed our 2nd fill up. Almost exactly 49 mpg.
    Trip meter indicated 52.5 mpg. I've read that the trip meter is often higher than the actual. Is this the case for most owners?
  8. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Yes, from the posts around here. The odometer shows higher speed than actual (I think by law) so the MPG will come out higher than the actual too.
  9. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    :welcome:
    Glad to see you here. You'll learn a LOT about your Prius by reading on Prius Chat.
    :cheer2:
  10. richard schumacher
    7,664
    1,046
    United States
  11. priuslover08
    priuslover08 New Member
    Kansas
    I took our 08 to Colorado last summer from eastern Kansas. It handled the grades from Denver to Lyons and all around without any problems.
  12. RichardinNC
    We may have experienced the beginning of this problem. IMA battery depleting more quickly that in the past - Fuel economy not quite as good - Slightly slower top speed when climbing our longest 7-8 deg. hills - Struggling to maintain what had been average mpg, etc.
    On the day we bought the Prius we were in Gainesville, GA to have the software patch done on the Civic Hybrid. Arrived an hour before the service apt. and stopped by the Toyota dealer that is about 1/4 mile away. Looked at a new Prius, had Civic serviced and returned to the Toyota dealer. Drove out in a new Prius about 2 hours later.
    I still think that Honda makes some of the best cars around. Hope they can deal with this problem in a way that is fair to the customers. When we bought the Civic Hybrid the full tax credit was still in place and gas prices took that big spike soon after. The approx. $4,000 premium to get the hybrid was amortized in about 12 mths because our other vehicle gets around 20 mpg. Since we had over 70,000 mi. on the Honda when traded, we were looking at the typical "trade or drive till it dies" situation.
    I hope the Prius lives up to its reputation. Met a gen II owner at church who can't say enough good things about their Prius.
    One question: Another Prius owner started a conversation with us at a restaurant and said that, aside from the larger gas engine, the other big improvement for gen III is a battery array with cells that can be replaced individually. I'm sure somebody here knows about this - Used the search but may not be calling this by the correct name. Thanks everyone.
  13. richard schumacher
    7,664
    1,046
    United States
    Agreed, Honda is an excellent manufacturer. My GF's conventional Civic is a great small car; if there had been no Prius I probably would have bought one.
  14. F512M
    F512M Member
    415
    Laguna
    Congrats!!!
  15. fuzzy1
    10,406
    You are mixing gauges.
    Speedometer shows speed, and reads high for legal reasons.
    Odometer show distance, and does not have that speedometer bias, especially after the class action odometer-bias lawsuit against Honda. Mine read very slightly low last year, I haven't rechecked this year.
    GenIII MPG reads high for other unknown reasons. It needn't be that way, as many GenIIs and other car models have demonstrated.
  16. prius4driver
    prius4driver Junior Member
    74
    Sublimity, Oregon
    2018 Prius
    This is the first time I've heard of the speedo reading high--but does explain why the print out on the reader board things indicating your speed read a little lower than what I thought I was going. How much low are they? I've slowed down with th Prius--and may be going slower than I think! How do you check your odometer accuracy, fuzzy1?
  17. fuzzy1
    10,406
    I use highway mileposts over long distances, with numerous samples and crosschecks to detect and discard the misplaced posts and 'busted' sections caused by road realignments.
    While I distrust GPS trip tallies due to numerous measurement artifacts displayed on my hiking units, many other readers here do trust them.
  18. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  19. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Having worked with GPS receivers, they are perfectly accurate in a vehicle environment. The only caveat is the refresh rate, which is 1Hz usually. However they make 10Hz units with only civilian channels too.
    I generally check my speed on long trips with GPS. I find when you get to the higher speeds, the actual speed varies more greatly. For interstate driving, 82-83 is 80 (units of mph).
  20. fuzzy1
    10,406
    My GPS concern is with the trip odometer functions, not the speedo. With the later it is much easier to detect and mentally filter out bad readings.
    I should have saved a particularly bad example from a long-ago trip on Highway 20 through North Cascades National Park, with a Garmin III. Between terrain obstructions, overhead forest canopy, a poor constellation, and possibly multipath interference, the breadcrumb route was awful with many large lateral deviations from the actual road. One jump was nearly a mile off the road, many others exceeded a quarter mile. A trip distance along the displayed zigzag path was clearly much longer than the actual path of the car.
    A newer 60CSx does better with the canopy, but can't fix the other impairments. I barely used its trip odometer, but saw several online complaints about its odo accuracy.
    My latest GPS is an automotive unit, which does an excellent job concealing these off-road jumps. But while acting as navigator this weekend, with far more time to watch it than a driver can possibly afford, I caught it snapping to the wrong intersection several times.
    Unfortunately I missed an opportunity to re-record the North Cascades highway, and compare all three units with the mechanical trip meter, earlier this month.
