Did I damage my axles?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mwok86, Aug 17, 2010.
  1. mwok86
    mwok86 New Member
    203
    usa
    I was driving home in DC (worst roads in the world) on this particular road with lots of steel plates, ungrooved lanes, road gaps, potholes and stones flying from the vehicle in front of you. The road is so bad that pieces of the road are breaking up and vehicles in front of you will send those pieces flying fast.
    Anyways, next thing I know...something really hard hits the rear left tire area and then the tire pressure monitor lit up in the dashboard. I definitely knew one of the tires were hit because it was hard to accelerate.
    When I got home, the rear left tire was losing air fast (but it still had some air). I decided to take a 5 min break (it's 100 degrees) and when I got back...the tire was basically flat...no air.
    I drove to the nearest gas station (about 1 mile) on a FLAT tire (no air)...I drive extremely slowly as to not damage the drums or axle.
    When I took it to the gas station, the mechanic put the jack right of the rear left tire and then patched the tire up.
    Did he jack the correct place AND did I damage anything by driving with a flat (zero air) tire for 1miles slowly?
    Also, I think he filled up the tire without checking any pressure gauges or anything....at this point...I think all 4 tires have different pressure levels.
  2. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    First off, I'd be VERY surrprised if you didn't wreck that tire by driving on it while it was flat. The wheel would be digging into the tire.
    How would we know if he jacked it in the right spot?
    Check the tire pressure yourself...you should be doing that at least once a month anyways.
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
  4. mwok86
    mwok86 New Member
    203
    usa
    Well....he jacked it right after the rear left tire on the right side?
    The tire looks fine...I drove it back after the patch...although it did make a noise.....I'm assuming that it's due to the patch he put in (copper rod thingy that sticks out half from the tire).
    Is there some kind of pressure monitor I can get that will tell me the tire pressure?
  5. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    There's an internal tire pressure monitor, as you already know, but that's only accurate at a very gross level. There's plenty of tire pressure monitors available, you can get one at a gas station or auto parts store. Most common one looks like a pen. Just unscrew the cap on the tire's valve stem, put it on firmly (that's kind of the tricky part, don't worry if a little air leaks out), and read the number on how much of the measuring stick came out.
    I have a bicycle tire pump at home, it works fine on car tires too, just takes a little more pumping to inflate it. For the Prius I find about 10 pumps = 1 psi (it was 16 pumps/psi on my Subaru Outback, which had a slow leak and slowly became faster. when I was adding air every other day I decided it was time to get the tire fixed).
    I would never run any distance at all on a completely flat tire, or even go down the road with less than 10 psi. That's what a spare tire is for. Changing a tire is not something to be scared of. (Okay, enough lecturing).
  6. nerfer
    2,507
    237
    28
    After the damage you did to the tire, I wouldn't worry too much about the mechanic. I would assume he put it on the frame, as long as he didn't go way under the car and put it on the exhaust or something you should be okay. Can't pinch the brake lines, pretty hard to get it on the suspension, I think the biggest danger would be scratching the paint on the side.
    And regarding your title to the thread, driving on a flat won't damage the axles. Not sure about what you hit though.
    BTW - underinflated tires are more likely to get a sidewall leak (due to being pinched) on a bad bump than properly inflated tires. And a sidewall leak isn't repairable, it needs a new tire.
  7. mwok86
    mwok86 New Member
    203
    usa
    If I get a new tire, will I have to get the same brand? Is there a specific tire brand you recommend? I think mines came with Yokoma stock.
    Is there any tire services that will come to your house and change it?
  8. bisco
    52,093
    there are tire services that come to your house, look on line, i think it's tireguys around here. but your tire is probably fine, if it holds air and there is no sign of visible damage, you should be good.:)
  9. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    That is the worse possible place to place the jack. There is a good chance he damaged the flux capacitor. Not to worry though if you stay below a speed of 88 miles-per-hour.
  10. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    As mentioned, the frame is there. But, how can anyone here tell you that the jack was actually on the frame and not on the floor or the exhaust or the plastic of the bumper...etc.
    Is the car shaking at all now? If so you'd probably need to get it balanced. It sounds more like it was a plug he put in then a patch. A patch would require the tire taken off and placed on the inside, then have the tire balanced. A plug is just that, a plug stuck in the tread of the tire. Not needing to take the tire off.
    As for a pressure gauge, there are lots out there. Analog and digital gauges. I find this style the easiest to get on the valve without loosing to much air from the tire:
    Slime/5-60 PSI brass dial tire gauge with bleeder valve (20049) | Tire Gauge | AutoZone.com
    But my suggestion to you is next time put the spare on and run the flat tire over to have it repaired.
  11. stream
    2,977
    452
    Long Island, NY
    Good point... :p
  12. timo27
    timo27 Member
    316
    52
    Baltimore, MD
    I believe the proper point to jack the rear is just in *front* of the wheel--could that be what he did? If he did it to the rer, look under and see if there is obvious damage (indentations) to the floor pan. If not, I wouldn't worry too much. Your biggest problem is probably damage to the rim and the tire.
    FWIW, I keep an electric pimp in the car, to fill up thand also the spare. They cost about $30 and can save the day.
  13. lolder
    lolder New Member
    Hard to detect sidewall damage can occur by running flat. On freeways running flat is one of the most common causes of vehicle fire from high speed driving which you didn't do. Don't run flat again. Get an air gauge and read the manual about tire changing. If you can't do these things yourself, subscribe to a road service.
  14. jferris33
    jferris33 Junior Member
    Maryland
    Better keep an eye on that pimp, you never know what they are going to do.
  15. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    An electric pimp can keep a whole stable of blow up dolls working all night.
  16. jburns
    829
    111
    Archdale, NC
    Is there enough head room for his hat?
  17. fuzzy1
    10,520
    The jack points are marked on the underside of the car, and are noted in the manual. You will have to go find and learn those spots, and then decide if that is where he placed his jack.
    How can you know? Some of the damage would be visible only from inside, when the tire is dismounted from the rim.
    I won't even drive across my driveway on a completely flat tire. It is much cheaper to avoid the risk by immediately changing to the temporary spare. And if the tire shop is a mile away, it is also faster to change to the temporary and drive at street speed than to creep slowly on a flat.
  18. mwok86
    mwok86 New Member
    203
    usa
    Yes, I'm hearing some noises from my rear tire...I think it might be the "tire plugs" the mechanic installed. I'm just worried that he might have jacked the wrong location and that the frame is starting to creak etc.
    On another note, can anyone check whether the "exhaust pipe" (I think carburetor) is "low" in their Prius? Like, it is not "attached" directly to the base...instead, there is space between the "base" (floor) of the car and the top of the carburetor.
    When I was traveling, something hit the rear tire and whatever it was "clanked" for a couple of seconds in the rear left side of the prius....as soon as the clanking stopped, the TPMS sensor came on. I'm thinking that it hit the underneath components too. Unfortunately, I tried over 4 different routes....all of their are very poorly maintained roads....there is now way to avoid them.
  19. nerfer
    2,507
    237
    28
    There is no carburetor in the Prius, and it wouldn't be under the car if there was one. Maybe you're thinking of the catalytic converter. There should be a small gap (inch or two) between the exhaust/catalytic converter/muffler and the car, because that gets pretty hot and needs to be cooled without heating the bottom of the car unnecessarily (the battery is above that). It should be firmly attached and not making a lot of noise when you drive however (it would have a very loud engine noise if it was coming apart).
    Jacking the car in the wrong location won't damage the frame. You're supposed to lift it via the frame. Generally you put it in front of the rear tire, not behind it, but I think that's more to even the load on the two tires on the right side.
    Your best bet is to take it to a dealer or a mechanic you can trust and just have them look it over. They won't make any changes without asking you first, but will know more by a quick look than we can by guessing from your descriptions.
  20. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    I would replace the tire. Too many opportunities for the sidewall of the tire to be compromised from driving on it flat. You'll know there's a problem when the tire blows out on the highway at 70MPH...not worth trying to save $100 by not replacing the tire.
    Things you have learned here:
    1. When you hit something on the road, and you say the car is sluggish and the TPMS light goes on. Stop the car and look at the damage.
    2. Never drive a car with a flat. Toyota provides roadside assistance, and they could have plugged the tire that way right in your driveway. Could have called them, and sat inside and watched TV while you waited for them.
    3. When patching a tire, you want a PATCH, not a plug. A plug voids a tire's warranties for treadwear as well as the speed rating on the tire. A patch requires the tire be removed from the wheel and patched from behind.
    The issue here is not only that the tire was driven the mile to the gas station...it was also driven home. Plus if air escaped fast enough to instantly display the warning light...I wonder if it was really something that could be patched in the first place.
    How many miles on your car? You can probably get away with just one tire...but you have to buy the same model tire as is already on the car.
