new brake failure 2010 prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pb1996, Aug 17, 2010.
  1. pb1996
    pb1996 New Member
    Somerville, MA
    Bought a new 2010 prius in June 2010. Have noticed a brief (1 second) period of brake failure (it feels like acceleration) when braking over a speedbump/pothole/etc. This occurs regularly and without fail, and is quite scary. Is this normal, or do I need to look into it further?
  2. richard schumacher
    7,666
    1,047
    United States
    Normal. The tires are losing traction for a moment and it feels like acceleration. It isn't. Be sure to give yourself enough time and distance for braking on rough or slick surfaces.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    What is the build date of your Prius? You can find the information on the driver's side door frame.
  4. Analogkid1958
    Analogkid1958 Member
    119
    61
    Yorktown, IN
    2024 Prius
    The ABS software patch covered under the recall was incorporated into production vehicles started in January 2010, if I recall.
    Also, Toyota instructs that when the ABS engages (or feels like it isn't in this case), KEEP PRESSING - don't try to modulate the brake pedal. It does help; once the wheels are loaded again, braking will return to normal.
  5. pb1996
    pb1996 New Member
    Somerville, MA
    manufactured in 2/10. If this 1 second brake failure is "normal", than how long was the brake failure after hitting a bump before the recall? I can't help but feel that this "normal" pause in brake function is less than safe.
  6. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    pb, there are many many threads debating this during the recall brouhaha. My take is that if you have an emergency, you brake hard and the regen cuts out in favor of friction. You do have ABS and such which can result in longer stopping distances (but more reliable).
    If not emergency stop, you know when it will occur, brake sooner, then let up at the bump, and it quickly becomes normal feeling. My wife had this happen and said the brakes are weird on bumps. I said don't brake on bumps. She got the hang of it and ours is fine. We will not get the recall flash, as I don't want more friction braking.
    The gen2 drivers found and studied this on their 04 models waaay back, and it was accepted as normal until the 2010 got caught in the recall debates.
  7. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    I can't help wondering how many people who report this phenomenon have hyperinflated their tires to increase MPG. Stopping power depends on the area of the contact patch, which I assume varies inversely with tire pressure.
    I'm not criticizing higher than recommended tire pressures, but I am curious about its relation to these brief but startling episodes of ABS action.
  8. Sassan
    Sassan New Member
    33
    Troy, MI
    I noticed this phenomenon on larger bumps in my 07 mazda3. think its just a traction issue.
  9. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Good point!
  10. pb1996
    pb1996 New Member
    Somerville, MA
    i have not changed my tire inflation since I received it from the dealer.
  11. fuzzy1
    10,603
    You haven't changed it -- but have you checked it?
  12. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Underinflated tires have a smaller contact patch as only the edges, not the center are contacting the surface. This is the cause of edge wear. The gap in the center also pools water which promotes hydroplaning. My 2006 at 45psi was less squirrelly on wet pavement when braking.
  13. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Are you saying that while braking properly you lose literally a FULL SECOND of time in which you have no braking?
  14. pb1996
    pb1996 New Member
    Somerville, MA
    it feels like 1 full second, but maybe it is half a second. I guess what I'm wondering is, is this how it is supposed to feel after the recall/patch, or is this how it felt before the recall/patch. In other words, did my car somehow get overlooked in fixing whatever the braking problem was?
  15. qbee42
    3,081
    It feels the same before and after the patch, only the length of the dropout is reduced. This makes a comparison very subjective, which is hard to do with typed words. It's like saying "How blue is blue to you?"
  16. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Yeah, after hitting the bump, the moment he leaves the ground the brakes don't work :rolleyes: :D
    FYI, places not to apply the brakes:
    1. on a bend
    2. on a rough surface
    3. on a bumpy surface
    3. on icy or oily surfaces
    If you encounter any of the above, it is advisable to brake before you get there or if it's too late then steer (smoothly/gently) only.
    This applies to all vehicles not just the Prius. IMO the Prius is just doing what any othe ABS equipped car does when the driver is doing what he shouldn't.
  17. web1b
    web1b Active Member
    817
    52
    I think calling it "Brake failure" is overstatement since the brakes are working and you can still stop the car. However, if the car has the recall fix at the factory or wherever, I don't think you should be feeling the sensation like the brakes aren't working properly after a bump.
    That is a known problem that Toyota made a fix for.
    Simply take it back to the dealer and have them check it under warranty.
