Odd Sound
Discussion in 'Gen 2 Prius Main Forum' started by heimdm, Oct 11, 2005.
  1. heimdm
    heimdm New Member
    31
    When I am going at a low speed usually getting ready to part I hear a slight sound that appears to be coming from the drivers side down low. Any idea what that would be?
  2. dlskier
    dlskier Junior Member
    69
    Manhattan Beach, California
    getting ready to part?
    Describe the noise please.
  3. heimdm
    heimdm New Member
    31
    Well, its kind of like a rattle
  4. jaybee
    jaybee Junior Member
    27
    Atlanta, GA
    Is it kind of a consistent ratcheting sound, like clicking? And heidm asked but you didn't answer. Can you clarify what you meant when you said, when you were getting ready to part? Park?
  5. heimdm
    heimdm New Member
    31
    I meant park, sorry about that. It seems to usually be tied to pressing the brake. It is more of a clicking or "zzz" sound.
  6. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    It might be the brake system. It adjusts the pressure in it's storage tank and there's a little compressor that makes that kind of sound. Typically, you have your foot on the brake when you park. Try shifting to N and taking your foot off the brake (assuming you're level and safe doing this) and then press the P button and see if the sound goes away.
    I don't think it's anything to worry about.
  7. Vespasian
    Vespasian New Member
    126
    Illinois
    My Prius has a rattle near the little window on the driver's side.
  8. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    My Prius has a constant little buzzing sound just above my shoulders. And voices. Sometimes there's voices. :wacko:
  9. SDiego
    SDiego New Member
    60
    San Diego, Ca.
    I noticed that mine does that too. It's normal. Though I did notice that when I first got the car, after I shut it down, I could hear this whine sound, that runs for about 10 seconds or so, then shuts off. I learned thats the transfer pump. Anyways, Latley I noticed that it sounds kinda sandy now. Like if there was pieces of sand or something. I have a feeling that is not normal. maybe the bearings are going out on it.
    we will see.
    It's a 05 with about 7,800 miles on it.
  10. jeromep
    jeromep Member
    827
    Eastern Washington State
    I have about 7200 miles on mine right now and it is doing the same thing. I have a tread out there about my experience so far with trying to get a dealer to acknowledge it. Let me try to find that and link it here.
    :unsure: Well, it appears that the entire topic about my loud hot coolant transfer pump was lost during the recent Priuschat loss. That really sucks. :angry:
  11. richard schumacher
    7,680
    1,059
    United States
    The bees, the bees! And the talking spiders! Aaaah, make them stop!
  12. rick57
    rick57 Member
    572
    Circleville, Ohio
    What ever became of your noise? Did you get a new pump or are they still trying to find the source of the noise? To bad the thread got lost, :( .
  13. simple_in_seattle
    simple_in_seattle New Member
    58
    Lake Stevens, WA
    <div class='quotetop'>QUOTE(rick57 @ Oct 14 2005, 09:48 PM) [snapback]141312[/snapback]</div>
    I have the same noise. Bumping to see if anyone else has a metallic rattle/buzz coming from the driver's side B-pillar area. I've had mine into the dealer 2x and haven't gotten it corrected yet.
  14. BenR
    BenR New Member
    35
    <div class='quotetop'>QUOTE(Bill Merchant @ Oct 11 2005, 02:00 PM) [snapback]139543[/snapback]</div>
    I hear it in my 2006 from time to time, and only when braking. It does sound like a tiny compressor or well-insulated vibratory pump.
  15. simple_in_seattle
    58
    Lake Stevens, WA
    <div class='quotetop'>QUOTE(BenR @ Aug 25 2006, 09:26 AM) [snapback]309246[/snapback]</div>
    Not the braking system..its a buzz in the cabin where the driver's seatbelt connects to the B-pillar.
  16. Half_Orc
    Half_Orc New Member
    17
    I had this problem. The dealer didn't fasten the nut that is holding a plastic flap that is located in front of the rear tires. Maybe you can try to see if any plastic flaps are loose?
  17. simple_in_seattle
    58
    Lake Stevens, WA
    Bump. This noise is driving me nuts.
  18. kmullally
    kmullally New Member
    <div class='quotetop'>QUOTE(heimdm @ Oct 11 2005, 11:10 AM) [snapback]139463[/snapback]</div>
    I took my '07 in to the dealer today for the same noise and the mechanic told me it was the ABS pump and sure enough, even if the car is parked, pressing the brake pedal multiple times will produce this noise. Mine seemed louder than the other two cars he tested but they all made that noise. Kind of annoying but it's not something they will address since they all seem to do it.
