What does the engine do at 90mph?
Discussion in 'Gen 3 Prius Main Forum' started by kuhne, Aug 22, 2010.
  1. kuhne
    kuhne New Member
    37
    Mexico
    Just a question.
    If you are driving at a steady speed of lets say 80 to 90mph and will be at that speed for a long time, the battery will obviously run out rather quickly and you will be running on gas motor the whole time?
    or does the gas motor recharge the battery constantly so that both engines power the car?
    it seems to be that if its only the gas engine working then its going to be too much stress for 98hp to handle speeds of 90mph.
    Can anyboy explain this to me?
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Whine
  3. qbee42
    3,077
    At any speed the HV battery will run out rather quickly. The Prius is a gasoline powered car: all of the energy to move a Prius comes from the gas engine. The battery is just there as a temporary storage device - think of it as a flywheel and you will get the proper idea.
    Cruising down the highway at speed, all of the power is coming from the engine. Part of it is transmitted mechanically through the PSD, part goes electrically via MG1 to MG2. Regardless, it all comes from the gas engine.
    Even the 76 hp of the Gen II engine is plenty to move a Prius at 90 mph. Most modern automobiles are grossly overpowered.
  4. SageBrush
    11,627
    2,533
    Southwest Colorado
    Yep. Just don't expect impressive fuel economy.
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    100 hp will move the average medium sized car 100 mph. Prius aerodynamics aren't average.
    A Gen 3 Prius has about the best aerodynamics of any production car and will go something like 112 mph on 98 hp, so 90mph is a piece of cake for a Gen 3. That would be roughly 55 hp.
    IIRC, the Gen 2 was limited to 103 mph.
  6. ken1784
    ken1784 SuperMID designer
    2,943
    1,383
    67
    Yokohama, JAPAN
    If you accelerate very quickly to 90mph, the battery power will be used for motor assist.
    The battery level will be maintained at six bars by driving steady 90mph speed.
    Ken@Japan
  7. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    2 people like this.
  8. Prius42
    Prius42 New Member
    139
    Maryland
    That's a pretty cool file! Top speed 115, 0-100 in 30 seconds. I don't think I'll be trying that anytime soon...
  9. kuhne
    kuhne New Member
    37
    Mexico
    I am still rather confused, some of you said that the pries is only powered by the gas motor at those speeds but that other guy from yokohama said that at those speeds the batter doesn't deplete and helps the gas engine the whole time?
  10. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    What he implied was that the battery will maintain a steady 6 bar charge at 90 mph, he didn't say it would be helping the gas engine. There would be no need for it to help the gas engine because a Prius can maintain 90 mph on less than 60 horsepower.
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I thought it was 112mph or something. I know in mine it has been up to 107mph with satellite checked speed on flat/slightly uphill terrain.
    Agreed that modern cars are extremely overpowered, you would be surprised at just how much power the Prius has. It has enough to move you fast in any traffic density.
  12. qbee42
    3,077
    He was explaining that if you stomp on the gas the battery will help you accelerate. The battery is used to provide extra power for short periods of time. Think of it as a Turbo button. Once you back off a bit, the battery stops supplying power and starts to recharge.
  13. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    This page has a great illustration on what will happen to the engines and motors at 90MPH.
    Toyota Prius - Power Split Device
    The ICE will spin 4435 RPM, MG1 will spin at 2192 RPM and MG2 will spin at 5298 RPM.
  14. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    All power comes from gasoline in the non-plugin Prius. As you are cruising at 90 MPH, some boost comes from the battery, then it's replaced. This happens constantly, as the car uses the electric portion to maintain speed so it doesn't have to use fuel enrichment to accelerate (gasoline engines must do this - hence older carburetors had an "accelerator pump"). The car will be slowed by slight inclines (so small you don't notice them), wind gusts, etc. and it uses electric power to overcome those.
    The important thing to remember is that while power can be taken from the battery for this "boost" it is replaced very quickly, from power generated by burning gasoline in the engine. The Prius will try very hard to maintain the charge level of the battery, allowing it to increase or drop, but not for more than a short time, typically a few minutes.
    So your steady state top speed will be limited by the power the engine can generate vs the power needed to overcome inclines (gravity) and air friction. Your -peak- top speed will be limited by the combined power of the engine and battery (we refer to the electric portion power as the power the battery can provide, as that is the limiting factor) vs the air friction and gravity you must overcome (any hills - this could be negative as well if you are going downhill), taking into account the time limit that power can be taken from the battery (until the system won't allow any more).
    But before you reach the -actual- top speed, the Prius systems will shut you down. There is a speed limiter in there.
  15. guinness_fr
    guinness_fr Junior Member
    68
    france
    Well this page is for genII so the genIII numbers would vary a bit but most importantly, the ICE and MG1 numbers will depend on how much power is requested to move the car (e.g. are you going 90 mph on downhill/flat/uphill terrain?). You can actually verify this by setting MG2 at 5298 rpm and moving the ICE around...
  16. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    any time you cruise on the highway, or just cruise in general outside the city (above 45 mph), you are running solely on gas engine. Just look at the energy meter while you're cruising down the freeway, it shows the gas engine. occasionally the motor will kick in to provide extra power on hills and passing, but maintaining a steady speed uses just the gas engine. At 90mph though, your gas engine will be running higher RPMs than at say 70mph so obviously your gas mileage will suffer.
  17. Judgeless
    1,821
    257
    Cleveland, OH
    You are correct. The info on that site is from a Gen II. The Gen III uses the same Planetary Gear and the RPMs might change with the Gen III.
    Everyone is correct. At some times at driving 90MPH you are just running on the ICE, other times the MG2 is assisting. At other times MG2 is generating energy to charge the battery.
    It is false to say at 90MPH going down a step hill that the ICE is providing power to the drive train. This is an amazing machine.
  18. creativeguy
    creativeguy Member
    301
    17
    CA
    I got it up to 100mph once on I5 in CA (because you have to see what the digital speedometer does after 99!) and it was really smooth, quiet, and stable.
  19. kuhne
    kuhne New Member
    37
    Mexico
    What does the digital speedometer do after 99?
    Guys, thanks for the answers. From what I have read I can sumarize it like this, tell me if I am wrong.
    If I am maintining a constant speed (lets say 90mph) in cruise control on a relatively flat highway, it will be all gas engine but if for whatever reason I need an extra kick, weather it be for passing, or because I had to slow down and speed back up to 90mph or because I am in a steep incline, the prius will allways have a 6 bar battery charge ready to help the gas engine and give it more HP so that I can perform these tasks. Then it settles back to gas engine only and the battery charges back to six bars for whenever I need it again?
    Sounds frigging futuristic... can't wait to use this car.
    Does it make any difference driving in ECO, PWR or Normal at those speeds? I read that those modes dont affect you at all when you are at highway driving. It's just mainly for when the car is stopped. at what speeds does power mode and eco mode become irrelevant?
    Thanks!
  20. creativeguy
    creativeguy Member
    301
    17
    CA
    Displays "100", same as the in dash thermometer, though I don't care to see that too often.
