Backup alarm
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bobkat21, Oct 12, 2005.
  1. bobkat21
    bobkat21 New Member
    99
    Elwood IL
    anyone out there know how to shut off the backup alarm? if so please sharethanks :huh:
  2. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    Hi bobkat21
    Here's the "DANCE" to disable the backup buzzer:
    1. Sit in driver's seat - POWER ON (No passenger or heavy object in passenger seat);
    2. Set the Trip/ODO to ODO, NOT Trip A or Trip B; Cycle through even if ODO already showing;
    3. POWER OFF;
    4. POWER ON to "Ready"; and WITHIN SIX SECONDS;
    5. Press and HOLD the Trip/ODO button FOR 10 SECONDS OR MORE, then WHILE STILL HOLDING THE Trip/ODO button;
    6. With your FOOT ON THE BRAKE, shift from P(Park button) to R, then back to P; then release the Trip/ODO button;
    7. The speedometer will show "b on" or "b off" where you'd normally see the odometer reading. (If you followed the steps successfully!)
    8. Press the Trip/ODO button to toggle the beep on or off;
    9. POWER OFF
    Note: If your 12-volt battery is disconnected or discharged, this setting will revert to the factory standard (beep on).
    It's a little tricky but will work.
  3. Spunky
    Spunky New Member
    469
  4. bobkat21
    bobkat21 New Member
    99
    Elwood IL
    that was to funny good one spunky I liked that one
  5. waiting
    waiting New Member
    I'm not an old lady either but I'm waiting for the day when I can use it as an excuse for my chronic forgetfulness! But in all seriousness, I turned the back-up alarm off last week, and am already thinking about turning it back on because a couple times the car went in opposite direction from what I expected. The alarm wouldn't be so terrible if it weren't for the obnoxious alarm-clock-like sound. BTW, anyone know how to change it to something more pleasant?
  6. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    To borrow from Henry Ford, you can make it sound like anything you want, as long as it is nothing, or that annoying beep.
  7. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    I think the main problem with the factory backup beep is that it comes from the speakers in the car and can't be heard OUTSIDE, behind the car. You're in stealth mode and the dog/cat/granny/child can't hear you coming.
    I got a real backup beeper at Radio Shack and wired it in to a backup light circuit (directions here on PriusChat). It's loud and obnoxious and the person or animal behind the car knows something is happening. Then I turned off the interior beeps.
    Salvage09 and waypeter like this.
  8. Bandwife
    Bandwife New Member
    Thanks. for the "dance" I just did it and no more annoying beep.
    Genius
  9. Kathleen2
    Kathleen2 New Member
    77
    I turned off my back-up alarm because I installed a buzzer in the back that can be heard in the rear inside and outside. It was easy to do and I thought it added a little bit of safety.
    Kathleen
  10. ZumbaAM
    ZumbaAM Junior Member
    Fox Island, WA
    Thanks for the info, unfortunately Toyota took the ability to take disable the tone away from the owners of the Gen IIIs so now I need a trip to the dealer. (Dealer I bought it from, Lassen Toyota, said there was no way to disable it. I think they were just lazy.) I'm a pilot and when you hear that kind of alarm in a plane it's always bad news. Don't want to hear it every time I back up--not an emergency. I might consider keeping it if it wasn't so loud and annoying.
  11. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Yeah it's useful to have that audible feedback to know whether you've selected D or R, but a single beep would be enough already. :)
  12. Salvage09
    Salvage09 Junior Member
    Pasadena CA
    Take a look on this blog- Scan Gauge II Question | PriusChat You can buy an OBD scan gauge on Ebay for about $10.
