electric motor tech
Discussion in 'Gen 3 Prius Technical Discussion' started by practica, Aug 26, 2010.
  1. practica
    practica Junior Member
    43
    Raleigh, NC
    The one type of wear on the drive train I find nothing about is design of the electric motor-generators. One issue is the bearings, which might be moot because of sealed grease bearings used in lots of motors, which can last years running 24/7.
    Another issue is brushes connecting the fixed electric power to rotating parts. These are consumable graphite in some motors, requiring periodic replacement. There are fancy electronic induction ways, with high frequencies, which can now be used to eliminate contact brushes thanks to available solid state electronics -- such as Dyson uses in its expensive vacuum cleaners. Other motors use metal contact brushes. Use of permanent magnets can also eliminate brushes, if used in the rotor -- but I was under the impression they are used in stators -- very possibly ill-informed. I did see a reference that at least one of the motors has permanent magnets, though to what effect I don't know, could just save weight. Electric motor design is an engineering specialty, with many different designs for different applications.
    I'm just curious what the design of these motors is and what sort of maintenance long term might be required with them. They replace mechanical items on regular cars which wear out, such as gear shifting transmissions etc. There's lots of experience with that old stuff to know what to expect, but these electric motors remain a mystery.
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    There are a few pictures at http://priuschat.com/forums/gen-iii...79-does-2010-drive-system-work-backwards.html. I have some higher res (8 mp) ones that I took at Prius Connection SF and if you let met know of a site where I can upload (and you can view) unreduced photos for free, let me know. (Need a pro account on Flickr for that.)
    There are a few details in the PDF at http://priuschat.com/forums/gen-iii-2010-prius-main-forum/60002-prius-technology-video.html.
    I don't see any brushes and think that MG1 and MG2 on every generation of Prius have always been brushless. There are plenty of brushless motors out there. Go look at any fan.
    There's some more info if you search for "trans" at Prius links. Most of it is for previous gens though.
    I don't know of any maintenance needed on the power split device other than fluid changes.
  3. hybriddriveguy
    98
    63
    Sanford NC
    As far as I am aware, all hybrid vehicles use 3 phase ac induction motors that are brushless. The bearings have not been an issue in the 10 years they have been on the road. Most problems have been related to shorted stator windings.
  4. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    There are no brushes. The Prius uses a permanent magnet AC electric motor. An A/C motor uses many coils on the outer ring of the motor to spin a magnet connected to a drive shaft. A microprocessor sends energy to each coil one after another that makes the drive shaft spin one way or the other.
    This makes it easy to spin the motor both ways and the only parts that can wear out are the bearings to hold the drive shaft in place. The real name of the drive shaft with the magnetics is a rotor. Here is a good link that shows the basics.
    AC motors
  5. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    It's not an inductive AC motor, per se. Inductive AC motors use induction to cause current in the rotor. The rotor current makes it an electromagnet that interacts with the stator electromagnets.
    The Prius uses permanent magnets in the rotor, so there are no rotor windings to induce current in. The stator gets 3-phase AC power from the invertor (or generates 3-phase AC power) at varying frequencies. Induction AC motors have low starting torque (from 0-speed), so they'd be a bad idea anyway. Since no current is supplied to the rotor, there are no brushes. The only parts to wear out are the bearings.
    In the terms of the motor business, it's a permanent magnet AC motor powered by a variable frequency drive. The amazing thing is how they got two VFD's (totaling over 100 hp) in a box the size of a 12-pack.
  6. teeasal
    teeasal New Member
    420
    ON, Canada
    Wouldn't permanent magnets looses it magnetism over time?
    Well, come to think of it. Hi-fi speakers use permanent magnets too. The set of speakers in my family room was purchased almost 30 years ago and they still sound fantastic!
    I'm just wondering how can permanent magnets last so long? When a magnet attracts and moves another metallic object, isn't it actually having "work done" and erergy used up from it? How can permanent magnets seemingly last forever? Isn't this against the law of physics?
  7. qbee42
    3,081
    Adding to this, the type of motor used in the Prius is a hybrid synchronous permanent magnet motor. The "hybrid" part of the name means that the motor works as both a permanent magnet motor and as an induction motor. At lower power levels the permanent magnet dominates, providing more efficiency. At higher power levels induction becomes more important. This allows for higher power levels when needed, while still maintaining good efficiency for most driving.
    No, it doesn't violate any physical laws. Think about this for a minute. Anything you pull away from a magnet had to be put close to the magnet in the first place. The object being pulled gives up potential energy as it is lowered into the magnet. It gains potential energy as it is pulled away. The gains and losses are exactly equal.
    Some permanent magnets do lose magnetism over time. This is not because of conservation of energy, but because of physical changes in the material. For example, heating many magnetic materials will allow their particles to twist and cancel out the internal magnetic fields.
    2 people like this.
  8. teeasal
    teeasal New Member
    420
    ON, Canada
    So a permanent magnet is like a mini planet with gravitational fields, but it's not spherical because of the opposite poles. Thanks.
  9. teeasal
    teeasal New Member
    420
    ON, Canada
    On a lighter note, are "Chic magnets" some kind of permanent magnets, and their magnetism deteriates over timer too?:D
  10. qbee42
    3,081
    It could be spherical, but it's not required. Likewise planets are only spherical because of their large mass. With enough mass, gravitational pull overcomes the physical strength of a planet's material, and it is pulled into a sphere. Small planetoid objects, such as asteroids, are often lumpy and irregular, lacking enough mass to squish themselves into a sphere.
  11. teeasal
    teeasal New Member
    420
    ON, Canada
    No I mean the imaginery lines of gravitaional fields are spherical cause they are all pointing towards the centre of gravity of the object, regardless of the shape of the object; while the lines of magnetic fields are not spherical, somewhat butterfly like (looking at a 2D point of view) going from north pole to south pole of the magnet, even if the physical shape of the magnet is a sphere.
  12. qbee42
    3,081
    Ah, gotcha. Gravity, as far as we know, is a monopole. That makes for some weird things. Magnets, as you point out, have two poles, so we get looping flux lines.
  13. mort
    mort New Member
    Los Angeles
    The usual published half life for neodymium iron boron alloy magnets is about 2000 years. Each year the magnet loses about .035% of it's remaining magnetism.
    -mort
  14. qbee42
    3,081
    My Prius might need new brakes by then.
  15. teeasal
    teeasal New Member
    420
    ON, Canada
    Years ago I was dreaming of designing my own EV/hybrid car. My thinking was that the ICE charges the battery and the motors drive the wheels, like the Chevy volt.
    Except that all the 4 wheels have MG's mounted directly on them. So 4 wheel drive all the time, no gearing friction loses. All drive by wire. Full size spare wheel with spare MG mounted.
    And one more crazy concept: no steering mechanism other than electronic control of differential speed of left and right wheels. You turn right by making the left wheels run faster than the right ones, and vice versa. You can even make the car spin around on the spot with left wheels forward and right wheels reverse.
    Engine can be very small like a 1L atkinson cycle, running all by it's own will even when parked. All it does is charge the batteries.
    The batteries are modular rectangular bars lying in a sub-floor between the ground and the cabin, all shaped like long gold bars sliding in from the side after flipping open a long but narrow door. You can even plug it in at night.
    This was my idea back in the 90's before the Prius was born.
    Am I crazy or is this feasible?
  16. practica
    43
    Raleigh, NC
    In recent decades significant advances were made in permanent magnets making them very powerful compared to previous, opening up entire new application possibilities and reducing the size and weight of many products. For a long time aluminum-nickel AlNico was the strongest one, but now I think it's rare earth Neodymium even stronger.
    Sounds like the Prius motors are way more durable than traditional transmission parts. It's very impressive to eliminate varied gear ratios and gear shifting entirely with electric motors and differentials. What delayed this so long was the cost of the battery involved in making the whole hybrid combination. Who ever heard of a differential breaking, compared to all the repairs on automatic transmissions?
    What the maintenance is on the CVT's going into smaller vehicles now remains unknown. There's not much experience yet. They can't provide the torque on anything but the lighter weight classes, though it has been increased from the mainstay motorcyles at least to the lighter weight cars.
  17. austingreen
    austingreen Senior Member
    13,708
    4,230
    Austin, TX, USA
    You get most of the benefits from a motor in each of the front wheels and and one driving the rear axle. Porsche uses this configuration in their hybrid. You can of course use 4 mgs instead of 3. In small airplanes you turn by braking on one wheel which rotates the other on it. You would want to change the tire angles though otherwise you would have great tire wear. You don't want to mount the mg to the wheel but on the car, the brake should be here as well. This makes it much easier and lighter to change a tire and removes the hassle of wires etc. I don't think steer by wire is legal in the us, but there have been prototypes built.
    Lithium polymer batteries can be thin and conform to just about any shape. Putting them in a sub floor and under seats seems perfectly logical. You will want to have some sort of air or liquid cooling.
    You probably want to turbocharge and direct inject that motor. Ford will soon produce a 3cylinder 1L DI turbo that can produce 120hp. Nissan will soon produce a 3 cylinder 1.2L DI miller cycle (atkinson supercharged) engine. So the small light engines for your generators are there. Even the 3 cylinder 1L atkinson cycle engine from the original insight might meet your requirements.
  18. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Ok. I put up the few pics I took at Prius Connection SF in March 2009 at Picasa Web Albums - cwerdna - Prius Connect.... It includes some pics of the PSD. We got to drive the 2010 Prius a few months before became available to the public. Big thanks to Toyota!
    Enjoy!
    5 people like this.
  19. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    3 people like this.
  20. austingreen
    13,708
    4,230
    Austin, TX, USA
