Wanted: Prius V OEM Rims
Discussion in 'Gen 3 Prius Accessories and Modifications' started by elevatus, Aug 26, 2010.
  1. elevatus
    elevatus New Member
    Seattle, Wa
    If you have a Prius V and are ditching your OEM rims, let me know. I would be willing to buy or trade some new TRD rims for them. Someone sent me a link for some rims that look just like the OEM's I've added (pic) below. I'm definitely open to options like those as well.
    I have a 2010 Prius IV.
    Drop me a line,
    Jess
    Here is the style I am looking for (OEM or aftermarket):
    Here is a pic of the TRD rims:
  2. cosx
    cosx New Member
    I have 3 OEM wheels and tires (with the plastic "cover") that I would sell. I'm keeping the 4th as a "real" spare tire (rather than the standard donut it came with). All 3 are mounted and inflated to 35psi. They don't have the TPMS installed. They are the 15" ones that came off a package 3, Generation III 2010 prius. I'm in Arizona.
  3. elevatus
    elevatus New Member
    Seattle, Wa
    Can you drop me a pic or two of the set you have?
  4. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    The OP wants the 17" OEM, not the identical 15" that he already has.
  5. charlotteprius
    charlotteprius New Member
    Charlotte, NC
    I realize you are looking for OEM rims but also know that there are good aftermarket options out there. Attached is a picture of my 2010 II with ICW Racing aftermarket wheels. These can be purchased for about $115 each on Tirebuyer.com. Note that the 17" wheel package is heavier than the 15" OE package by about 10 lbs. which reduced my MPG by about 2. I'm sure that the OEM 17" tire/wheel is heavier too but I don't have the numbers...I put on the OE Bridgestone Turanza 17" tires and they are heavier than the 15" and of course generally speaking a 17" wheel will be heavier than the 15". Full disclosure...I work for the company that owns Tirebuyer.com.
