temperature voice command don't work
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by aanimate, Oct 13, 2005.
  1. aanimate
    aanimate New Member
    25
    HI!
    I just noticed something in my Prius 2005. When I say "warmer", it gets my command and says "raising temerature" but the temerature numbers on display don't change.
    Anybody have the same problem?
    Thank you.
  2. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    I'm surprised you get a response of "raising temerature", as "warmer" is not a voice command on my American Prius.
    Try using "Raise Temperature".
  3. aaf709
    3,862
    2022 Prius Prime
    It seems to work for me to say something like "Temperature 75 degrees."
  4. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    Yes, that's legitimate too. You should also be able to shortcut that by simply saying "75 degrees".
  5. aanimate
    aanimate New Member
    25
    "Raise Temperature" is recognized also but it doesn't change numbers. Only when I say a specific number then it changes.
    So when you say" Raise temperature" does your prius changes temerature numbers on display or only increasing the fan speed?
  6. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    I've tested this before, but just confirmed it again -- it raises the temperature in 2 degree increments.
  7. mmccking
    mmccking Junior Member
    83
    San Jose
    I concur with Wayne
  8. aanimate
    aanimate New Member
    25
    I guess something is wrong with my car command.
    THank you!
  9. djasonw
    djasonw Active Member
    962
    123
    Coconut Creek, FL
    I can't remember the last time I used the voice commands. They're just a novelty. I press the up temp button and in two seconds, the cabin warms up. Why bother pressing voice command, saying your command and waiting for a response? Only reason would be to impress your friends/relatives. Sometimes I use the SAT commands instead of cycling through them.
  10. legendsguy
    legendsguy New Member
    31
    Kalamazoo, MI
    Is this voice command only available on Prius with certain level of options. I haven't seen anything like this on ours. I often say "I love you" but the car never answers back!
  11. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Voice command is included with the NAV system.
  12. legendsguy
    31
    Kalamazoo, MI
    Oh..No wonder the car won't answer when I speak to it. :lol:
  13. DanP
    DanP Member
    256
    And then, of course, there are those times when a request of, say, "77 degrees" results in showing post office icons.
  14. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    The voice command is handy for going from a low temp setting to a much higher temp setting or vice versa. At least it would be if it would consistenly recognize the command properly.
