Towing - U-Haul trailer with motorycle?
Discussion in 'Gen 3 Prius Main Forum' started by hbark, Aug 26, 2010.
  1. hbark
    hbark Junior Member
    56
    Bucks County, PA
    Has anyone ever towed a small U Haul trailer with their Gen III Prius? We're going to NC in October, and I was thinking of towing my bike behind us. Has anyone ever done anything like this? I'm not even sure the Prius has the capacity to do this.
    Would appreciate any feedback -- thanks.
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Toyota's official stance is that the Prius is not recommended for towing. The power train and GVWR aren't calculated w/ towing in mind.
    That said, some have used VERY small trailers and a Class 1/2 hitch. You can get Curt hitches (1.25" receiver) for about $120 at some websites. I bought mine at Discounthitches.com and installed it myself. Problem is, the lighting adapters compatible w/ our LED tail lights are another $75ish - I didn't buy this because my hitch is used to carry a wheel-chair carrier and, eventually, a bike carrier.
    So long as you don't exceed the gross vehicle weight rating for car and trailer combined, you shouldn't be putting anything except your MPGs at risk. It's been done before and others will claim you're just fine.
  3. Ricklin11
    Ricklin11 Junior Member
    65
    N. Oregon Coast
    Uhaul trailers are very heavy. The trailer will weigh more than the bike, unless it is a light bike.
  4. hbark
    hbark Junior Member
    56
    Bucks County, PA
    Thanks. I think I'll skip this idea. Oh well. :(
  5. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Good call. Plus, I wonder how insurance would treat an accident if they knew Prius is not approved for towing.
  6. Goodair
    Goodair New Member
    48
    SGV
    Tongue weight might be a little too much for 1 1/4" hitch, you will definitely need to install a brake controller as well for going downhill.
  7. 2to4
    2to4 Wherever we end up
    67
    Southwest, Indiana
    I see you made the right decision ... not towing the bike. It is right on two counts.
    1. The Prius was not designed to tow anything.
    2. Motorcycles were not designed to be trailered.
    The only better decision you could make would be to ride the bike to North Carolina. ;)
    This pic shows the view we had as we rode through the Valley of the Ten Peaks in Alberta, Canada. Even a Prius view can't match this one.
  8. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
  9. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Washington State, (Near Portland)
  10. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    That cradle is cool but requires a class three hitch. I don't think there is one for the Prius. As mentioned it has no tow rating. I think it's fine for a class 1 or 2 and a bike rack weighing 150 loaded with bikes or something but not much more.
  11. roxanne22
    roxanne22 New Member
    chicago
    I have not yet experienced to tow a trailer to my motorcycle though I already travel with my trailer. Know why? Because Uhual trailer was so heavy. And I think my motorcycle cannot carry it.
