A magic spark
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by andyprius, Sep 5, 2010.
  1. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    In reconnecting the neg. grd . lead from the 12V battery I got a very beautiful spark, intensely white and mutidirectional. Is this a capacitor discharge from that brake booster box ( loaded with capacitors ) or is it something else. How can it be prevented?? Of course the car was OFF :cheer2:
  2. qbee42
    3,079
    Even when off, many of the Prius systems still draw some power. The brake capacitor bank in particular can pull a pretty good current.
    To avoid a big spark you have three options:
    1) Don't disconnect the battery.
    2) First reconnect through a resistive path, then make the direct connection.
    3) Connect very quickly. It will still spark, but not as much.
  3. andyprius
    2,212
    188
    Since I installed the battery cut-off switch it is not a problem, I just wondered if the Toyota techs bleed this off first. Maybe shutting down the SKS to eliminate the parasitic current. ??
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    I noticed the same thing too when I removed the negative cable a while ago to sand down the - battyery cable to chassis contact and grease it.
    When re-connected surprising spark there in standby.
