what is city/highway driving?
Discussion in 'Gen 3 Prius Fuel Economy' started by priustexasbob, Sep 5, 2010.
  1. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    not sure where to post this but since the rating is for fuel economy I'd post it here.
    when they reference city/highway driving what are they refering to?
    city - stop and go on city streets only no highway? New York city, Los Angeles etc
    highway - interstate only, no stops?
    how far for each one and at what speeds?
  2. claridiva
    claridiva New Member
    109
    Dallas, TX
    City mileage, as you suggest, refers to stop and go traffic: the type of driving you expect to encounter in any city of really any size as long as it has stop signs, traffic lights, etc. It is the type of driving where you cannot stay at a consistent speed for very long. Of course, this type of driving is typically worse for gas mileage because of the constant stopping/going and possible cutting on/off of the engine. The more smoothly you can drive the transitions from stop and go, the better your mileage. IOW, jackrabbit starting and slamming on the brakes is hard on the car and will hinder your mileage.
    Highway mileage is not restricted to interstate only, but certainly refers to the type of driving here you can maintain a consistent speed with little to no stops (the type of driving where the use of cruise control is optimal). The actual speed itself doesn't really matter, although the higher your speed, the more fuel you will expend.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I'm not sure I understand your question. If you're asking about EPA test cycles and methodology, see http://priuschat.com/forums/other-c...uth-about-epa-city-highway-mpg-estimates.html.
  4. priustexasbob
    356
    86
    arrakis
    2015 Prius c
    thanks for the link, it makes interesting reading and puts a light on the results.
