Took the Prius apart, and also and interesting finding.
Discussion in 'Gen 2 Prius Main Forum' started by That_Prius_Car, Aug 26, 2010.
  1. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    In a Gen.II or Gen.III?
    Because in the Gen.III if the engine and battery are not wormed up, it will only go to 10mph, but if it's all wormed up and the battery's SOC is at a good level, then 25 is the top speed when the EV button is pushed. You can go faster in EV, but when the car is in EV mode (as in the EV button was pushed) 25mph is the max speed. I don't know about the Gen.II though, because they had EV buttons over-seas.
  2. smartalec89
    smartalec89 The Official Alaskan
    133
    anchorage, alaska
    I was just talking about the Gen II.
  3. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    So the Gen.II can go faster in EV if you have the button?
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Since when did Gen III start using worms? Ah, thats where the green bars come from, green worms. :focus::):cheer2::cheer2:
  5. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    At 43mph indicated you are only going about 39mph because the speedo reads higher than actual speed. I find I can stay in electric only mode up to an indicated 46mph even with oversize tyres (205/55/16) that make the speedo more accurate.
  6. Frankusa94
    Frankusa94 Junior Member
    60
    Ma
    I have seen my 07 do the same… doesn’t make sense… and the ice still kicks on with all green battery bars with press of gas pedal above 15%. City mpg is around 38mpg, above 40mph… mpg is 50mpg+ completely opposite of advertised mpgs…
