12 volt batteries problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KailuaPrius, Sep 13, 2010.
  1. KailuaPrius
    KailuaPrius New Member
    San Diego
    is it a hassle to replace my 12 volt battery? went to the dealer and he said Toyota doesn't recommend me to replace it myself.
    has anyone replaced it themselves? any info will be helpful.
    Mike
    2008 Prius Gen II
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Here is a complete replacement with an Optima Yellow Top from elearnaid.com, replacement with the stock battery would be even easier.
    Prius 12V swap
  3. boppo
    boppo Active Member
    799
    139
    Owego, NY
    I put the yellow top in mine and it was real easy and simple.
  4. Patrick Wong
    18,210
    6,516
    If you have a reasonable set of metric tools (sockets and box/open end wrenches) then you can replace the 12V battery. This project is a bit more cumbersome than replacing the 12V battery in a regular car, because you need to remove the traction battery vent that runs above the battery and also move the brake power supply which is next to the battery, for service clearance.
    When disconnecting the negative battery terminal you will find it is much easier to remove the cable where it connects to the body. Then swap the negative cable over to the new battery before installing it.
    Note the vent tube that runs from the battery to the body, and feel around so that you know where the tube should be reinstalled (through a grommet in the body.)
    When moving the brake power supply, you don't have to actually remove the wiring harness connector, just unbolt the power supply and move it out of the way.
    MSRP of the correct 12V battery is $139 but you will find that some dealer parts depts charge more, so you may want to call around to see who has the best price in your local area.
  5. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    I put the Optima battery in mine and it was no problem at all.
  6. jreed
    jreed Member
    84
    71
    North Carolina
    I installed the eLearn Aid kit and it took about 2 hours. There were excellent instructions but many steps (approx 30 individual steps). I would do it again over the dealer battery if given the choice.
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Yes, it is more complicated than a regular vehicle, but certainly doable if you're patient
    I used to back off and snug up the negative cable bolt where it attached to the unitbody, did this every spring and fall to ensure a good corrosion-free connection
    My 12 v battery with the VDC Battery Minder charge harness hooked up. The thing outlined in blue is the vent tube
    Speaking of charge, make sure the replacement battery is fully charged before installation! The Prius charge system is anemic at best, and if you do a lot of short-trip ops, the battery will become chronically undercharged
    This will result in much lower service life
  8. vertex
    vertex Active Member
    673
    144
    new york
    2018 Prius Prime
    Battery replacement is definetly an easy DIY job. Purchase on from the dealer, it should run about $130. The Yellow top battery is better, but a little extra work. Seach this site, there are other options as well.
  9. richard schumacher
    7,682
    1,064
    United States
    Only if you want to cobble up your own cable and mounting solution. There is no drop-in aftermarket replacement.
  10. vertex
    673
    144
    new york
    2018 Prius Prime
    I thought that is what I said, buy it from the dealer, otherwise there is extra work.
  11. partsmore
    partsmore Junior Member
    85
    NE
    I changed the battery with an Optima already in my 2010 and installed a battery brain (Batter Minder) from batteriesareus . com
    The Optima d51 is Deep Cycle and will maintain a higher voltage under a load.
    They also sell the XPC-550 for higher capacity for audio and deep cycle demands,
    which I am going to order next for my stereo upgrades, and reduce engine charging demand / load while maintaining higher voltage.
  12. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    Of course not. It cuts into the dealer's potential revenue stream.
  13. partsmore
    85
    NE
  14. lrchome
    lrchome New Member
    Port Richey, Florida
    I bought the 12volt battery from SUN Toyota in New Port Richey Florida for $138 and they charged $12 to install. If you install yourself put 12 volts on the jumper terminals under the hood so you do not lose your computer settings.
  15. korat102
    korat102 New Member
    25
    UK
    Anyone found a non OEM battery available in the UK? They're surprisingly difficult to track down. Seems the usual suppliers only go by voltage and Ah rating. If you inform a sales droid that the thing they suggest won't physically fit and has the wrong terminal posts they look at you as if you're mad.
    My battery seems to have some life in it yet but after 5 years I'm starting to get a bit twitchy about it, especially after I allowed it to drain completely last year!
  16. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    As long as you don't screw up (install the battery backwards). You should be fine...
    If you screw up, however, you can do serious damage.
  17. korat102
    korat102 New Member
    25
    UK
    Changed mine today, the original battery still had some life in it but wasn't holding a charge as well as it used to - better safe than sorry I thought. Tracked down a supplier of the D51 Optima Yellowtop recommended here. Everyone here is well aware of the procedure so I won't bore you with that.
    Something probably worth mentioning is that it's known as an Optima Yellowtop S 2.7 over here in the UK. The SR 2.7 is the same battery with the terminals reversed.
    Only extra work was the new ground lead and a new clamp for the positive terminal which I ordered at the same time from a different supplier. Got problems with the vent tube which I need to look into but apart from that it was a mostly trouble free installation.
    Only issue was the that floor piece didn't quite fit properly so I was forced to trim a little off one of the posts: This battery comes with a hefty plastic strap for carrying it around which doesn't lie flat. Although the floor initially fitted properly, over time it was pushed back up by the strap. Just trimming a few milimetres off the post cured that problem.
  18. okiebutnotfrommuskogee
    1,813
    Tulsa, OK
    Elearnaid removed the carrying strap from the one they sent me before sending it. They explained that it was in the way when the battery is installed in the car.
  19. korat102
    korat102 New Member
    25
    UK
    I considered removing the strap but decided to leave it in place. I thought it'd be quite difficult to heft around much less extract from that little cubby hole without the strap. Did you have any problems getting it in there without the strap installed?
  20. okiebutnotfrommuskogee
    1,813
    Tulsa, OK
    It wasn't a problem at all. I did remove the capacitor bank for the brakes and set it aside while I was doing the battery work. That gave plenty of room for the job.
