$1500+ for a 4yo AC compressor replacement?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by laird, Sep 13, 2010.
  1. laird
    laird Junior Member
    25
    oregon
    Sitting here at my local dealer and just got the word that my pump is making noise and fixing the AC in my 06 will run $1522.
    Does this sound right?
    Alan
  2. Patrick Wong
    18,210
    6,511
    1. Did you hear the noise yourself?
    2. Is your AC working now?
    3. What would happen if you declined the repair?
  3. laird
    laird Junior Member
    25
    oregon
    Hi Patrick,
    I have not heard the noise myself. I'm assuming it requires a mechanics steth and a familiarity with what a good one sounds like. On max cool, I hear the electric AC pump and it sounds like it always does.
    The AC gradually lost performance over August until it was not blowing cold air any more. I've not been using it since. I took it in to get it diagnosed and they told me the compressor was making noise.
    I asked them what would happen if I did not fix it and they pulled out books to figure it out. There's no fuse to disable it but it appears that when the low pressure sensor trips it will stop engaging the compressor.
    I've had AC compressors seize before and it's not pleasant. This one runs on high voltage instead of a belt so it could be spectacular if the low pressure sensor does not disable it.
    FWIW, this car has been well maintained and driven gently by adults. It feels like the failed ahead of it's time and the price to replace it is nutty.
    Alan
  4. Patrick Wong
    18,210
    6,511
    Hi Alan,
    OK, since you know the AC doesn't work, and the diagnosis is that the compressor has to be replaced, then the price of $1,500 seems reasonable for dealer service. You may wish to call around to the various Toyota dealers in your locale to see if you can improve on the price.
  5. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Laird, I'm curious as to how many miles you have on it. These are the things that are making me consider an extended warranty.
  6. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Well, a call to the toyota customer experience center may have toyota chip in somehow.
  7. uart
    uart Senior Member
    4,220
    1,211
    Australia
    First let me say that I agree that it's failed early and the cost to fix it is pretty bad.
    As for any bad effects of not fixing it, if you leave it switched off then there will be none.
    BTW. Warm still works with the AC fully off. You can go into the MFD and make the AC off (light bar above the AC icon is off) but the fan on, and it will still (without AC) try to maintain that temperature. Obviously though it can only warm the air to achieve this.
  8. gzenitsky
    gzenitsky New Member
    I grimaced when adding the cost of a 100k mile Platinum service to the invoice for my brand new 2007 Prius in June of 2007. Last Saturday I had the car at Lee's Summit Toyota for a no a/c complaint and sure enough, the compressor is not working and diagnosed as "unresponsive". Repair cost = $1500.00! So as much as I hated the idea of purchasing an extended warranty, it has proved very valuable at this point.
    What is distressing is a major component failure at only 71k miles on a car that I thought was very reliable and would require only preventive maintenance. A/C compressors should not fail within 4 years. Now I have reason to doubt its reliability and future cost of ownership.
  9. bisco
    52,292
    reliability is based on number of complaints. doesn't mean they are all perfect. good for you on the extended warranty. i wouldn't worry about the future, but don't plan on not having more problems as you add mileage. maybe a trade in when the warranty is up is in your future?
  10. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I had always thought the weak point in the Prius A/C was the fragile aluminum AC condenser in front of the rad. Doesn't take much road debris to make a hole in it
    Also, if as some point somebody "topped off" the R-134a, special care has to be applied to the type of oil used. The Prius A/C compressor is electric and using the wrong oil can cause a short in the AC motor that drives it
  11. JAQBAUER
    JAQBAUER Junior Member
    Pembroke Pines Florida
    I recently posted here that my 2005 Prius at 115K miles the evaporator core failed, two weeks after spending a grand on a new Hybrid Battery that failed. The factory worked with me paying 75% of the battery cost, and so I opted for the repair. Now the evaporator failed and they want over $1700 to replace it, along with a new dryer and expansion valve. The Labor hit is 8 hours. I negotiated a 15% off parts , which knocked the cost down to $1300~ and change. But.....whats next ? The A/C compressor or Condensing coil ??? The information provided here has pushed me into getting rid of it, as the car has likely reached the wear out point. It would nice if a Toyota "insider" could publish historical failure rates for the major parts for the older model years-it would really help the consumer. But its probably in the Top Secret file in a cave in Toyota City Japan. Perhaps if Priuschat established a database where we could input the failures we have experienced-it would go far in helping understand the failure curves for these rare parts.
    Coast Cruiser likes this.
  12. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    You might consider advertising it on this forum. There's probably someone who will appreciate that you've just fixed everything and it's good for a long time now :)
    Seriously, I believe that on average you own one of the most reliable, long-lived vehicles on the market. I can understand that this double-whammy has been a shock, but assuming that the car's going to spontaneously fall apart from this point sounds like superstition to me.
  13. chronon
    chronon Active Member
    601
    106
    here and there aint be in frozen wasteland no mo..
    no it doesnt seem right .. well for a dealer maybe .. but you could buy a whole salvage motor, with less miles, remove and replace the thing (not through the dealer labor) and have a smaller bill than the a/c you are quoting from the dealer ...
  14. lech auto air conditionin
    830
    605
    261
    san francisco
    Yes four years is too soon, but it is the customers responsibility to make sure not to use the a/c as soon as you notice lower a/c performance. But I do understand it not always easy. It is even worse on a electric compressor because you have to cool the electric motor and winding to on top of the moving parts friction and compression. Just 30z low on refrigerant can be detrimental to the life of the compressor. Less refrigerant means less oil return, Less refrigerant means less cooling back to the compressor. Most cars lose a small amount of refrigerant every year. That was ok 10 to 20 years ago when the refrigerant capacity was 2 LB. to 4 LB. Now your Prius is less the 1 LB. = 554 g. your Prius is about 420 g. to 480 g. And looking for bubbles in the sight glass is not a good way to tell and sticking a thermometer in the dash can give you a false indicator on a cool day. On a cool 60F day and the refrigerant 1/2 empty you can still get 42f out the dash same as a full refrigerant charge, but on a hot day it will starve for refrigerant and then you will have poor cooling. Thers a lot more to it then that, but im just keeping it short and simple.
  15. Venado
    Venado New Member
    2724 S. 13, St Louis, Mo
  16. Venado
    Venado New Member
    I have a 2012 Prius c. Today the service contract co. informed me that they rejected my claim about my air conditioning condenser claiming that it was damaged by a rock impact. I paid good money for this contract. I was also told that is very easy to damage the condenser since it sits low upfront. Calculate the cost of purchasing one. For me I learned a costly lesson. But I will never purchase 1 no more. Anybody else had similar results?
