Parking Brake vs Parking Button
Discussion in 'Gen 2 Prius Main Forum' started by Kablooie, Apr 20, 2004.
  1. Kablooie
    Kablooie Member
    273
    La Canada
    I know that the pedal parking brake is useful when you park on a hill but is there any advantage to using it on your average flat surface?
  2. DaWebGuy
    DaWebGuy New Member
    Houston
    Yes. Manufacturers, police, & driving instructors all recommend that you set your parking brake so that if someone or something hits your car, it won't be pushed out of the parking space or driveway and into another car, moving traffic, a tree, a pedestrian, etc., etc. It's a real good idea!
  3. Joel
    Joel New Member
    108
    Houston, TX
    I use parking break as force of habit and hardly ever hit the "P" unless I intend to stay in the car while it's running - otherwise I just hit the power button and it does the same thing.
  4. RobertO
    RobertO New Member
    215
    Renton, WA
    Always use the Parking Prake in conjunction with Park. Best to set it before you select Park to avoid "rocking" the drivetrain.
    Bob
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,195
    Nixa, MO
    There probably are some really good theoretical reasons to use the parking brake all the time, and maybe I'm a bad citizen for not always doing it, but I rarely use mine. I haven't had any issues yet with someone hitting my car and knocking it into traffic from either my garage or any other standard parking place. I rarely, if ever park in a place where, even if someone hit me, I could be pushed into traffic. I do, of course, use it when I'm on inclines/hills.
    I think some reasoning and logic can come into play with a very minor issue like this. I go for big things...like bike helmets on kids, encouraging the non-use of trampolines, things that lead to real injuries to real people almost every single day.
    In 10 years as an ER doctor I've never once seen an injury due to a parked car being hit and pushed into someone b/c the parking brake wasn't set...ask me how many broken arms I've seen from backyard trampolines!
    2 people like this.
  6. mdacmeis
    mdacmeis Member
    133
    Michigan
    2018 Prius Prime
    Surveys have shown that nearly 90% of Americans do not user their parking brake. As a result, loss of function often occurs due to corrosion of the cable assembly and parking brake components. Several OEM's have stated they recommend setting the parking brake at least once a month to counteract the corrosion effects and to insure functionality. This can be critical as several rear brake designs rely on use of the parking brake to perform the self adjustment feature. In these cases, not using the parking brake results in a gradual loss of rear brakes.
  7. ammiels
    ammiels New Member
    121
    brewster, ny
    The theoretical reason to set the PB is to use the brake pads to protect the pawl in the transmission which might be damaged by forcing the car to move if only in Park. That said I only use PB on hills, or in City parked next to hydrant.
  8. fred
    fred New Member
    235
    nashville
    as always being in the minority i always use the parking brake. i put the car in park and put the brake on. one reason of cours is habit but the other reason is to relieve pressur on the tranny.. notice in general that unless the ground is really flat that your car will have a slight tendency to roll. i like to have the p brake take up the slack instead of good ole many thosand dollar tranny.
    fred in nashville enjoying smiley my 04 black prius
  9. efusco
    19,891
    1,195
    Nixa, MO
    Well, I've head that logic too, but the deal is this, you put hundreds of times more force on that tranny in normal driving than the static force exerted while parked...I just don't think that logic washes. Again, I'm NOT being critical of anyone who does this, and it's probably a good idea, I see no harm that can come from it, but it can become one of those issues that people become religious about and start condemning others for not doing it when the reality of it is that there are much bigger fish to fry and it's an extraordinarily minor issue.
    Also, the corrosion arguement...I'd like some proof or even a good explaination of that one. How does stretching or tensioning a cable prevent or reduce the risk of corrosion?
  10. bigal
    bigal Junior Member
    28
    Hamburg NY
    I seldom use the parking brake, mostly on hills. But maybe I should.
    In the "good old days" when I was first driving, setting my father's car parking brake in one of those Western New York winters, it was common that the parking brake cable froze in the set position. Since those days I have been parking my manual transmission cars by putting the transmission in reverse and my automatic transmission cars in park. I really don't believe the parking brake is anywhere as effective as setting the automatic transmission in park. If you have ever taken off in a car with the parking brake set, you'll know that its not all that effective. I don't think bumping a car set in park would cause it to roll off.
    In defense of using the parking brake; I have had the experience (not in the Prius) of having the transmission "lock" in park. I couldn't get the transmission out of park without getting out and rocking the car, I could only guess that since I parked on a slight grade, the car was "leaning heavily" on the transmission.
    Well it can't hurt to set the parking brake always. It will hold the car from starting to roll and possibly prolong the life of the transmission that is if the parking brake is set before releasing the regular brakes.
    Al
  11. Danny
    Danny Admin/Founder
    7,093
    2,117
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    That's still true, or at least that's how I was taught.
    Whenever a freeze is coming, I always park my manual transmission in first gear and don't use the parking brake.
  12. paulisme
    paulisme New Member
    179
    Charleston, SC
    I've seen it happen in a parking lot before. An elderly woman in her Cadillac hit the gas pedal instead of the brake, and when she put the car in drive, she slammed into the parked car in the space in front of her. That car came out of park and rolled across the parking lot into another parked car. It was quite interesting to see the whole thing go down.
  13. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Parking brakes should always be used because:
    1 You can remember to release it better if you always use it.
    2 You can check that it works, and I have had brakes fail even with dual hydraulic braking systems, so that the parking brake was my only way to stop.
    3 There have been many cars with auto transmissions that had recalls due to the park position not holding and the car popping back into neutral. Some cars may work fine when new but become less safe as they wear. Same for manual transmissions as I have seen worn gear boxes that can pop out of gear by themselves.
    4 If the parking brake is separate as in my current car, the drum will corrode if not usee so I have to use the parking brake to stop the car with periodically as well.
    5 Parking brakes operate on both rear wheels. A car in park could slide if parked on ice or sand so only one wheel had traction, if using just park, and the car got bumped.
    This is critical too if you are changing a tire!
    I have to admit that freeze ups are a problem for my present vehicle in winter, so I do use the transmission in gear only, when not on a hill, till summer, when I park.
  14. Kablooie
    Kablooie Member
    273
    La Canada
    Hmm. Do you think the if the car had the parking brake on it would have made a difference? It seems pretty easy to drive with it on. I often forget if I set it and start driving with the brake on.
    Anyone know what the consequences are of driving with the brake set? [/quote]
  15. fred
    fred New Member
    235
    nashville
    ok guys ive got it! this is a " isay tomato you say tamahto deal." however us shy car guys will always use the parking brake. its no fun watching my little benz rolling down a hill wihout me in it! can you imagine our poor little priuses(?) getting moving without us in it.
    fred in nasville with over 40 yrs driving experience and 0 tickets or accidents(not that i didnt deserve them) if anyone wants to ask me the most important safety tips ican pass on im glad to run my mouth.
  16. fred
    fred New Member
    235
    nashville
    ooops just read my own post. sounded rather pretentious. didnt mean to but i do like talking about driving.
  17. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    Hmm... the domino theory in action.
  18. SpartanPrius
    SpartanPrius New Member
    107
    As mentioned above, the transmission "pawl" is a relatively small piece of metal that "locks" the transmission in Park. Please note, I am not referring to the transmission shifter lock on non-Prius cars. The pawl is easily overwhelmed by a traumatic shock (e.g., parking lot bumper bashing). Once the pawl is severed, you are faced with a very expensive transmission repair, and the possibility of your car traveling without you. Therefore, for non-Prius cars, use it as a matter of habit. It will protect your tranny, and add a margin of safety whenever you could potentially roll off. For the CVT equipped Prius cars I will defer advice to someone who actually has one.
    (Still waiting)
    Oh yeah, on actual slopes, always remember to lock your steering wheel so it is pointed away from school bus drop offs, old folks homes, and nuns crossing an intersection... I'm sure Efusco see enough carnage.
  19. Danny
    Danny Admin/Founder
    7,093
    2,117
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Away from old folks homes??? Ahh man, where am I gonna get my daily humor from now?
    Watching those old people dodge my car while it's careening out of control is a lunch-time tradition!!
    :lol:
  20. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    Yes, point it towards me instead:
    "Oh, look! A Prius heading towards me! God has sent me the thing I want the most!
    "Now, if I can only jump inside it as it goes by.... %$@!, stupid Smart Entry!"
