Modify This!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by BMcGraw, Aug 17, 2005.
  1. BMcGraw
    BMcGraw Member
    230
    Southern California
    I got a good deal on the lights so of course I had to install them. This Prius looks "electrified" now I'll tell ya....
    And before anybody says anything, I've already done the research. For those of you in California worried about the legality check out VC25400 @ dmv.ca.gov. It states:
    Lighting Requirements
    25400. (a) Any vehicle may be equipped with a lamp or device on the exterior of the vehicle that emits a diffused nonglaring light of not more than 0.05 candela per square inch of area.
    (B) Any diffused nonglaring light shall not display red to the front, but may display other colors. A diffused nonglaring light shall not resemble nor be installed within 12 inches or in such position as to interfere with the visibility or effectiveness of any required lamp, reflector, or other device upon the vehicle.
    © A diffused nonglaring lamp or device, other than a display sign authorized by subdivision (d), shall be limited in size to an area of 720 square inches and where any lease, rental, or donation is involved the installation of the lamp or device shall be limited to those vehicles operated either primarily within business or residential districts or municipalities, or between business districts, residential districts, and municipalities in close proximity.
    (d) An internally illuminated sign emitting not more than 0.25 candela per square inch and possessing copy which does not contain a white background may be displayed on each side, but not on the front or rear, of a trolley coach or of a bus being operated in urban or suburban service as described in Section 35107 of this code.
    Amended Ch. 582, Stats. 1968. Effective July 16, 1968. Supersedes Ch. 144.
    So there...... :mrgreen:
  2. Tideland Prius
    16,623
    Woot!
    nice. Didn't an Australian here do that too? I always wondered, how do you stuff it under there? won't it crack or damage if the car scrapes something underneath?
    How do you hook it up?
  3. TJandGENESIS
    TJandGENESIS Are We Having Fun Yet?
    5,299
    47
    ★Lewisville, part of the Metroplex, Dallas, in the
    Hey, that looks nice. I was told by my TOYOTA mod guy, that lights could not be installed on this car, that it would mess with the electronics. I guess that is not true!
  4. djasonw
    djasonw Active Member
    962
    123
    Coconut Creek, FL
    Isn't that Neon stuff soooooooo 90's????????
  5. getdul981
    getdul981 Junior Member
    So where are the pictures?
    Greg
  6. BMcGraw
    BMcGraw Member
    230
    Southern California
    They were attached to the original thread in mid-August. Must have been deleted in the "website mishap".
    Here they are again in "collage" format.
    (Since the original post I've also added CCFL interior lighting - see photos.)
