recommend a good forum for laundry?
Discussion in 'Fred's House of Pancakes' started by fortheanimals, Mar 29, 2009.
  1. fortheanimals
    fortheanimals Junior Member
    87
    portland, or
    i've found a couple in the past, but my current googles are fruitless for some reason.
    what are the popular forum sites for various housekeeping?
    i only come across gardenweb (not what i'm looking for) and various non-forum sites with articles and tips... also some smaller forums that aren't very active.
    for those interested:
    i have coin-op washer/dryer in my apartment. coin-ops always have the prewash cycle. i add a bit of detergent for the prewash, wait for it to drain, then add some more detergent for the main wash cycle. this usually results in too much soap, but the obsessive/compulsive in me can't stop adding more detergent!
    does anyone know how much of the prewash detergent gets drained out?
    cheers!
  2. daniel
    14,487
    1,518
    Spokane, WA
    Forget the prewash and use half the recommended amount of detergent for the main cycle. If the machine has a pre-wash cycle, it will have separate compartments to put the prewash and main wash detergent. Based on your user name, you probably want to get one of the environmentally friendly detergents. It won't get your whites as white or your colors as bright, but it will get your clothes perfectly clean. My philosophy is that anything that does not come out with normal washing won't hurt me.
    You might be able to set the dial so it skips the prewash entirely. That will save water.
    Best are the front-loaders, which use much less water, and require much less soap. Like about a teaspoon of it.
  3. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Better yet, get yourself a supply of Soap Nuts. Throw the "nut sack" in at the beginning, and it just stays for the whole cycle.
  4. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    I kinda thought we already had enough dirty laundry around here. :rolleyes:
  5. daniel
    14,487
    1,518
    Spokane, WA
    If it stays in for the whole cycle, how does it get rinsed out? I don't care how natural it is, I want it rinsed out after it's done its cleaning.
  6. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    May I direct your attention to this article: Soap Nuts article
    In practice, the soap nuts work as both cleaner and softener. I'm particularly allergic to soap, myself, and I am not in the least bothered by soap nuts, as they aren't soap, either... it's a natural saponification in the nut rinds. If you have a top loader, you can pluck the nut sack out before the rinse cycle, if you like. If you use a front loader, as I do, you will discover that there is no "soapiness" left after the first rinse cycle! Since front loaders change the water so many times, the nuts run out of soapiness.
    Soap nuts, if used for just the wash cycle in top loaders, can be reused 3 or 4 times. In a front loader, just the once. It's STILL incredibly effective, and less costly, than synthetic detergents.
  7. daniel
    14,487
    1,518
    Spokane, WA
    They must be awfully cheap if they cost less than detergent and you only use them once. A box of detergent lasts me about six months with a top-loader, and with a front loader you use about a teaspoonful. A box would last me two years.
    And BTW I never use fabric softener. I hate the stuff. The tumble dryer leaves my laundry plenty soft.
    Okay, I checked out the earlier link you gave, 16 to 20 loads, ten bucks (plus shipping, I suppose), cheaper in larger quantities. I'm going to try them. But I cannot order them until after my trip, or the package would sit outside my door until my neighbor picks it up for me.
  8. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    As a suggestion, instead order from here: Maggies Soap Nuts
    These are the original, and they work better than the ones that are talked about in the article. Just sayin'. :)
  9. daniel
    14,487
    1,518
    Spokane, WA
    Yep. That's the page I was looking at. You cited that page in your first post in this thread. That's where I'll get them. Thanks.
  10. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    If its a commercial front loader, eg ASKO, Electrolux, etc, usually only a quick drain is done, no rinse and minor spin.
    I have a Kenmore Elite front loading pair, about 5 years old. The washer itself is actually made in Germany by Miele, a very well respected appliance maker in Europe
    I rarely use the prewash option. The few times I have, it's important to ensure the *total* detergent added does not exceed what you'd normally put into the main dispenser cup
    Options I always select: extra rinse, and extra high speed spin
    With front loaders, its also really important to use detergents - liquid or powder - marked "HE." If you attempt to use regular laundry detergent in a front loader, expect a Mt St Helens of suds
    A final word about detergent: more is NOT better! The detergent scoop for HE detergent is MUCH smaller than for regular detergent. I have hard water, with a good water softener, and use barely half the little scoop.
    Any hint of sudsing, I'd cut WAY back. In your case, I'd cut back to 50% the detergent you're now using
  11. jayman
    13,439
    640
    Winnipeg Manitoba
    :tape2:
    MMMMMPPPHHHHH! MMMMMMMMMMMMMMMMPPPPPH!
  12. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    Jayman, you would love it around here...
    Occasionally, I have to put a note on the whiteboard that says:
    "Where are the balls and nut sack?"
    It usually gets a chuckle from someone. :p
    [I use "dryer balls" in the dryer, and occasionally they, and the soap nut sack, end up going with our son's laundry when he takes it upstairs]
  13. jayman
    13,439
    640
    Winnipeg Manitoba
    :rolleyes:
    MMMMMMPPPHHHH! MMMMMPPPPPPPPHHHHHHHHHHH!!
  14. bb0wn
    bb0wn New Member
    Florida, US
    I thought this was a Prius forum oO
  15. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    Welcome to Fred's House of Pancakes. :welcome:
