Mark gets a shot at driving the PHV Prius in and around NYC
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Paradox, Sep 30, 2010.
  1. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    TPS = TonyPSchaefer [​IMG]
    If you knew that, let me apologize, I took it to mean you didn't.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Ok all, I drove the car up on a set of scales and here's the results for its weight:
    2010 Prius PHV = 3340 pounds (Scale weighed in at 1.67 tons, so check my math)
    2010 Prius = 3042 pounds
    Difference = 298 pounds
    3 people like this.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    That is just awesome, Mark. PHV Prius is showing the benefits of both EV and HV. You were able to do short trips in EV and 350 miles trip with over 52 MPG.
    Don't feel bad about the gas engine coming on. You needed more power so it delivered, nothing wrong with that. Instances like that prevent gas stale and gas engine lube desiccation. It also maintain consistent EV range.
    When the gas engine come on, how long does it take until it shuts off? It should be about 15 seconds. I am just wondering how it is compared to a standard Gen3 Prius.
    That's probably the transition stage from EV to HV. It appears the EV propulsion threshold was lowered to warm-up the gas engine in advance.
    KrPtNk likes this.
  4. john1701a
    john1701a Prius Guru
    12,833
    5,311
    58
    You'll get a 12.5 miles of carefree EV driving, where the system doesn't even worry about emissions. Then while you're traveling that last 1.5 miles, the system will be warming up in preparation for relying on the HV pack instead.
    That last 1.5 miles is like after taking a no-plug down a mountain. There's lots of motor contribution, but the sensitivity pales in comparison to EV.
    This is a contributing reason why the PHV will achieve a PZEV emission-rating... unlike a certain other competing plug-in with an engine.
  5. DarrenG
    DarrenG Member
    138
    Hampshire, UK
    Yup, me! Read the whole thread looking for the reference, only went back and spotted my error when I read your post :rolleyes:
  6. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It great to see Toyota did not drop the ball on emission and affordability. It appears they designed the PHV Prius with everything in mind.
  7. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Sorry didn't know, my appologies.
    Back to your test drives:
    Do you think you will have a chance to check captured energy on a long down-hill stretch while still in CD mode? (as suggested in posts #5 and #18 of this thread).
    Giora.
  8. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    While the car is still in EV mode, you will regenerate power which recharges the EV pack somewhat when braking and coasting such as going down a hill. Once you use up all the charge in the EV pack, you cannot place power back into it until you physically plug in. I do not know and doubt I will be able to test if you can coast down a long enough hill to regenerate enough power to go above the original 14 mile range.
    Keep in mind that whatever this PHV does may not be indicative of what the production version will do. This is a demonstration vehicle. We can see many things change, from adding the option to turn ev mode on and off which you cannot in the demo car, maybe the pack will be bigger/smaller/or stay the same etc; much is still an unknown at this point.
  9. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I took a video going to a shopping center where I live and then to one of the parks and back home a little while ago. It was about 6+ miles and a little over 13 minutes. Most is boring with me sitting in some traffic and again me babbling but hey i gave it a try Lol. It's uploading to youtube right now so I'll post a link later tonight or tomorrow so many can be bored at work. :cool:
    Oh, and I wasn't kidding when I said I bungee corded my Canon camera to the passenger sun visor to take the video!
  10. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    TPS = those cover sheets required for faxes in "Office Space"
    No wonder it confuses some of us :p
  11. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    I am only monitoring the PHEV story as it is not yet relevant to us in
    the Middle Atlantic States. Perhaps I've missed something.
    Why would 52 MPG be a bench mark?
    Many Gen IIs see it quite often without a whole lot of work.
    I would expect that or better on a 200 mile trip, even in the winter.
    It should be a snap for the Gen III.
    I understand the PHEV offers about 14 miles of pure electric drive and
    this is a good thing.
    Does hauling around the two EV pack batteries at about 300 lbs. when
    they are discharged reduce the expected regular HSD FE/MPG by a
    significant amount...
    And therefore only 52 MPGs is seen as a good thing? :noidea:
    Need a little help here... :yo:
  12. john1701a
    12,833
    5,311
    58
    With what part?
    Overall averages are what Toyota is in the process of collecting now. I saw 84 MPG with my PHV time behind the wheel.
    75 MPG is the generic expectation. That's a big boost over the what the no-plug averages.
  13. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Awesome! Can't wait to see it. The entire 13 mins is part of the experience. It should show how long you can go in EV mode from point A to B. Traffic jams are fact of life too. That will only add the practicality of it and put a dent in the presumption of "13 miles is too short to be bothered" ideology.
  14. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Because the competition is struggling with 32 MPG in HV mode. PHV Prius' 600 miles 50+ MPG range extender simply outclass the competition.
    On the flip side, 13 miles EV is useful to virtually eliminate those short and frequent trips.
    The competition would only have advantage in the trip lengths between 13 to 35 miles. Trips in that range are less than half of all the trips. That would raise the question if the extra ~$12k premium is worth it, assuming one can afford it.
  15. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Urgh, I messed up. I did it on the fly without knowing all the 'rules' of youtube. The video was really 20 minutes and after a 5 hour upload it was removed because you're not allowed to go over 15 minutes. I'll bungee cord it up again before I have to give it back and make one more shorter video. Again, it's just a view of the road driving around a bit but I guess I could show the display at the start of the trip and at the end showing how much I traveled and how much range is left at the end...
  16. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I'm going to post my final stats on Wednesday when the car is given back but I gave a quick look at the B trip meter which is what I am using to monitor all mileage driven since I got the car and yesterday I was at a little over 410 miles and the total mpg thus far was about 60mpg. Being able to do damn near everything I need to where I live in EV and then just using the hybrid portion of the car for road trips is just what I need as I suspect others do who live in cities such as this if they have the ability to charge.
    One annoying thing here on the east coast though: Once you get where you are going, no place around here has courtesy charging stations. I understand why for now but I really do hope that changes.
    Also, I REALLY hope they do use this pack, or even a bit of a bigger one. I understand keeping costs down and all but I really feel anything less than this would be quite unusable. Maybe is something smaller was offered with the ability to add on a second pack from the dealer for a cost to double range but something like say a 10 mile pack would only get me where I'm going. It would never get me home and for me, I just wouldn't want that.
  17. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    John1701a and usbseawolf2000,
    Thanks for your responses to my earlier question,
    (I take it that the unnamed PHEV competitor is the Chevy product due
    out, when, in Dec ''10?)
    Like so may others, I am trying to gain understanding of the new
    technologies, PHEV and EV, as they will apply to my specific needs so
    that I can make informed plans about future purchases.
    We are at the leading edge of a transportation sea-state change, just
    like when the horseless carriage, aka auto-mobile, became a
    practicable alternative to the horse and buggy. In this initial period of
    uncertainty, it sure is difficult to know what of all the hype, and
    rumors, and partial reports is meaningful for each individual user and
    their specific conditions.
    So, now I understand that overall, we might expect a combined EV/HSD
    mileage of ~75 MPG. That I could live with. But I know that YMMV,
    based on how my daily driving, ~28 mi round trip commute, "fits" with
    the PHEV range and control algorithms.
    It trying to figure this out, I can understand the cry for a new efficiency
    metric to replace MPGs. I like the idea of cost of energy/100 miles, or
    $$/100 mi.
    But even here, buyers/users would have to have foreknowledge to
    really understand the numbers, and the testing method would have to
    be devised to level the lying field for all vehicles.
    You would get a false result to test a vehicle for say 30 miles and then
    extrapolate to 100 miles, the EV contribution would be 3X too large.
    Not being in a geographic area where the PHEV and EVs will be
    introduced in the immediate future is frustrating. I suppose that there
    is a positive side in that I have more time to read, research, and learn
    from the early adopter's experiences with the new technologies in real
    world situations.
    Which means a huge THANK YOU goes out to Paradox and the
    other members who have reported their short experiences with the
    beta-test Prius PHEVs over the last months.
  18. john1701a
    12,833
    5,311
    58
    I got the distinct impression Toyota is testing minimums, finding out how small of a configuration is practical/realistic/affordable.
    In fact, I could envision a later model's pack shrinking enough to allow the floorboard to become flush again... making almost all aspects of the EV augmentation invisible... allowing the HV model to easily sell side-by-side with the PHV.
  19. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I'm with you John, they're definitely testing minimums IMO. But that's a fear, that they'll decide ok let's go smaller so the floor is not raised at all. They'll save money by getting away with a smaller pack which would bring the cost down a bit more but those lost miles in EV mode would break the deal, for me at least. I'd rather have the floor raised a bit like in this demo model and have the range...
    I guess everything will come down to what they find out is more statistically viable; That is, what range would most potential EV buyers be happy with and at what cost. I'd be all for a small pack with less EV range IF they offer a second pack option straight from Toyota to double range for those like me who would want more range... At least give us an option, don't just lock all potential Prius PHV buyers into one, low EV range model.
    2 people like this.
  20. john1701a
    12,833
    5,311
    58
    I envision a "smaller" pack being a physical improvement, not a capacity reduction. After all, Li-Ion production & chemistry is progressing forward at a decent rate and what we'll finally get to buy will be 2 years newer than what the testing models were built with.
