2005 used Prius help needed quickly!
Discussion in 'Gen 2 Prius Main Forum' started by jpgoody123, Oct 4, 2010.
  1. jpgoody123
    jpgoody123 New Member
    maryland
    I am looking at 2005 Prius Pk 6 with 36k miles for $13k.
    I am not sure about the difference between this generation and 2007 model, I am also looking at. Is the battery very different? How much does it cost to replace both batteries? What should I be worried about from the different years.
    I hope to make the purchase this afternoon. :eek:
  2. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Very low miles, nat'l average is 12K/year.
    Price is maybe a little high, not a real deal.
    No substantive difference between the '05 and '07.
    Both the High Voltage, "traction," battery and 12V batteries
    are identical in the two years.
    If "they" say its a Touring model, they're lying.
    You really should have either car looked at by a qualified
    Prius tech -- at a different dealer if that's where they are --
    before signing anything/buying.
    And see a CarFax report, and get a service printout on the car
    from a dealer.
    Take it for a long test drive; surface roads and highway.
    Be certain. Don't be bullied or rushed. CYA. You can always
    walk away if there's anything that you don't like.
    You haven't said anything to cause doubt as to the HV battery.
    It is reasonable to expect it to last for 150K - 200K miles.
    However, a used-but-good one can go for as little as $1K on eBay,
    maybe $2,500 new from a dealer.
    Typical service life on the 12V battery is ~4 years. The low
    mileage suggests it was driven for shortish trips and/or sat
    for longish periods unused. Both can lead to reduced 12V battery
    capacity over a long period.
    All in all, a new 12V battery is an anticipatable expense; about $160
    from the dealer and $100 to install. It's an easy DIY install. You can
    find a number of threads on doing it using the search function.
    Good luck. Be careful out there. Let us know how this turns out. :)
  3. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    The traction battery should still be under toyota warranty (8years/100,000miles) as is the rest of the hybrid drive system maybe 150,000 miles in some states,
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    The 2007 has a higher reolution MFD (screen). This only applies if the car has NAV. The 2007 also has a backup camera.
  5. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I just purchased a 2006 with 19,500 kilometers on it. What a car! If your happy with the deal then go for it.I would not worry about the pack. Hasn't been a issue with the Prius. :DH
  6. ravenmaniac
    ravenmaniac Senior Executive VP of Nothing
    156
    DC Metro Area
    Did you get the 05 Package 6? I have the same package on my 05. The only difference between the 05 and 07 is leather was not offered in 05 or back up camera. Also, the nav update on the 07 will show roads that may not be visible on the 05. I need to update mine as well (another topic though). Good Luck!
    Where are you in MD? I am in the same state. Is this a dealer? The traction battery (the big one) shoudl last you a loooonggg time! I have 210,000 on mine right now. If the 12V battery hasn't been replaced, it should be done soon on your terms instead of a cold morning in December.
  7. qbee42
    3,079
    The 2007 also has less sensitive traction control. Earlier Prius were known for being stopped by traction control on slippery surfaces. It's likely the 2007 will do better in snow than the 2005.
