Can 2010 Prius read Gen5 navigation DVD?
Discussion in 'Gen 3 Prius Audio and Electronics' started by hvanwersch, Nov 27, 2009.
  1. hvanwersch
    hvanwersch Junior Member
    When taking a US model Prius to Europe the navigation system won't work. One fellow has worked a way around this but only for navigation system disks through Generation 5 (U32 or U33).
    Since I have a 2010 Prius with generation 6 navigation, I would want to know whether my Prius will read an older say Gen5 DVD. That way I would able to get European map disks suitable to be read in a US model Prius.
    Thanks.
  2. patsparks
    10,664
    567
    Adelaide South Australia
  3. Tideland Prius
    16,598
    Not sure. Usually the newer disc will disallow the older disc to be used on that vehicle.
  4. Damon
    Damon New Member
    Switzerland
    Did you ever figure out a solution for getting the navigation to work in Europe? I just moved to Europe and am in the same situation.
    Thanks
  5. Torpedo
    Torpedo New Member
    Anyone have more information about this issue?
    I'm thinking abut taking a 2010 Prius from US to Sweden. Is there an other way to make the navigation work in Europe?
    What is causing the Nav not to work? Is there a difference in the GPS system or is it simply the regions in the DVD player that don't read the European disc?
  6. jayvee
    jayvee Member
    341
    89
    WA
    Sorry, I don't believe you can use a Gen 5 disk in a Gen 6 Nav. The disks contain not only map data, but also operating software, and the Gen 6 requires different software than the Gen 5. But it wouldn't break anything to try it! The nav probably just won't boot.
  7. Torpedo
    Torpedo New Member
    What about if you burn a European Map disk, Gen 6 disk, on a US version DVD (PAL vs NTSC) would that work you think?
  8. jayvee
    jayvee Member
    341
    89
    WA
    I know that some European Navs on the Gen III Prius use a hard drive for map data, not a DVD. Not sure if that's true for all of Europe.
    Also, I don't believe PAL vs. NTSC comes into play - this is map data, not television/video signals. It's just a DVD data disk.
    But theoretically, if a Gen 6 European disk exists, you might have a chance that it would work. There may not be much difference between the different countries' Navs that use a DVD - so the European disk (if one exists) may work in a US player.
