I got rear-ended on my way to Toyota
Discussion in 'Gen 3 Prius Main Forum' started by seb33, Oct 14, 2010.
  1. seb33
    seb33 Junior Member
    53
    Toronto
    It was very cold in the morning yesterday and my tire pressure warning light came on. I had a funny feeling that it was related to the temperature but it didn't ever go off so I called Toyota today and they said to drop by with it and they would check it out. On the way there after work I got rear-ended. So sad. I thought it was just the bumper but the hatch won't latch properly so they said they would have to 'pull something out...". It was going to be about $800 for a new bumper but now will be more. I'm going tomorrow to see their collision guys about a quote to fix it. My poor car. I have to admit that even with a dented bumper the car still looks good!!! I don't know how I'm going to manage for the two days it takes to get it fixed. I have to re-learn how to use one of those key thingys.
    The toyota service person told me that he had 14 cars in today alone to reset the tire pressure warning lights that came on because of the cold weather. He said my tire pressure was fine. Just my bumper needs a little work.
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    The owner's manual page 443 tells you how to reset the TPMS. Use your tire pressure gauge and be sure the tires are at the pressure you want before you do the reset.
  3. seb33
    seb33 Junior Member
    53
    Toronto
    Thanks for the advice. It would have saved me my bumper today if I had just done it myself.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Major bummer. Sorry to hear about that.
  5. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Seb...,
    I would not believe that service person. If that many TPMS are trigering, its because the cold air has reduced tire pressure to a dangerous level. Low air pressure in tires results in easier hydroplaning. He should have been pumping the tires back up. I would check the pressures on your tires first thing in the morning, to be sure they are at least at the door panel pressures.
  6. seb33
    seb33 Junior Member
    53
    Toronto
    Thanks, I will do that.
  7. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Whoa hold on! There is nothing wrong with your tire pressure. I had the exact same problem last winter when I was starting at 6am. I was worried like you so called the dealership and they explained. It is absolutely sensitive to cold weather but no way are you in any danger.
  8. Tideland Prius
    16,619
    Just remember to set the tyre pressure back to the correct setting (door jamb... that's the minimum) when the tyres are cold (haven't been driven in the last 3 hours, not parked in the sun etc). Once filled, press the TPMS SET button to set the pressures.
    Hopefully people will realise that temperature affects tyre pressures and that they can't assume that the tyres are at the same pressures in the winter.
  9. timo27
    timo27 Member
    316
    52
    Baltimore, MD
    Just let me make sure I understand this--you're saying the TPMS itself reacts in some way to dropping temps, independently of the loss in tire pressure caused by said dropping temps? Seems like that bug could have been engineered out, if so... Just curious.
    ~T
    btw--this doesn't apply to the Prius (which has a temporary spare), but some other Toyotas w/ full size spares have the TPMS in the spare, which people often don't monitor, leading to much consternation and frustration come cold temps and/or time. I have a friend with a RAV4 with this issue, and it was at the dealer's for a couple of days before the Toyota Brain Trust figured it out.
  10. timo27
    timo27 Member
    316
    52
    Baltimore, MD
    deleted--double posting, sorry folks!
  11. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Maybe. Or maybe you would have stayed in your driveway longer and gone on some other trip at a different time as a result and been SLAMMED IN AN INTERSECTION BY A GUY RUNNING A RED AND YOU DIE.
    So it's very possible that you just paid $800 for your life. I think that was a good purchase :)
  12. seb33
    seb33 Junior Member
    53
    Toronto
    That's exactly how I tried to console myself after the 'bump'. Had I not been going to the dealer I might have been on a different route and suffered a more serious accident.
    Turns out the repair estimate is $4000. The latch at the back has been damaged and there is bodywork necessary on the back door. Hopefully it won't result in much of an increase in my insurance...
  13. tumbleweed
    4,067
    692
    Eastern Oregon
    I think you are OK on that score, you were rear ended which implies it was the other drivers fault. Your insurance should not go up at all. Your Prius will be as good as new when you get it back. :)
  14. seb33
    seb33 Junior Member
    53
    Toronto
    Thanks, I needed to hear that! The collision repair guy assured me of the same thing. Can't wait to get it repaired.
  15. macmaster05
    4,050
    730
    Exactly. Since cold air contracts, the height of the pressure surface will be lower and thus not picked up by the TPMS (or picked up, depending on how you see it), but you've never actually lost pressure in your tire, and is safe to drive.
    Trust me. Nothing is wrong with the car. A few minutes after driving or when the weather warms up the TPMS goes away.
  16. Penny's Dad
    Penny's Dad New Member
    421
    46
    Orlando Fla
    So sad about your car...I know it will never be quite the same but will probably be ok. I was rear ended in the Murano after 6 mo's and even though the repair was good I could always notice little things...Be sure to check quality of fit on hatch (confirm it does not rub adjacent surfaces like the bumper top). Check under the car for the condition of the exhause pipes and muffler (mine was bent and I almost didn't catch it). Feel all over the inside of the talegate and lift gate for overspray of clearcoat (it happens sometime that they leave a door or window open). I once accepted a car and did not notice until the sunlight hit the window "just right" then it was like a fog on my window.
    Why would you pay anything if you were rear ended? Didn't the other guy have insurance?
  17. docsnavely
    docsnavely Insert Custom Title Here
    66
    Ocoee, FL
    Both my wife's 2004 Nissan Quest SE and my 3 week old Prius III just had a TPMS alert on each vehicle on the same day we had a temp drop here in Central Florida.
    Air pressure will change in your tires with a change in climate. You can either trust that you have an adequate volume of air in your tires and just wait for it to warm up (and with it the pressure to increase) or you can add air like we did. Checking your pressure takes 3 minutes and can save so much money in the future.
    And I agree with everyone else that insurance should be picking up the bumper. However, just because this forum member was rear ended doesn't mean he/she isn't at fault (hoping they aren't though). I am a paramedic and see many of these instances a month where someone was rear ended and are assessed points for the incident (Florida is a no-fault state). If you come to a sudden and abrupt stop without warning or valid reason, you can be cited for the incident if others are involved. It all depends on the situation. That's why we don't call them accidents any more, we call them collisions. An accident can't be avoided while collisions are avoidable (>90% of all traffic incidents are avoidable with proper judgement and attention)
  18. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I never had a tpms warning. But i check and fill my tires about every month. I do believe if your warning is going off you need to add air.
    You need to inflate them when the tires are cold. Thats why the tpms might go off when you drive and they warm up, but this is not the right way.
    It's not smart to have low tire pressure and drive to warm up the tires to make the tpms warning go off.
  19. macmaster05
    4,050
    730
    Lol, you don't drive to warm up the tires and make the warning turn off. You drive because you need to go somewhere. The TPMS warning turning off is just a consequence of driving. Of course I've checked my tire pressures when the warning went off during cold weather and they were fine at 38 psi. You've admitted yourself you've never had a tpms warning so how can we even believe what you say?
  20. seb33
    seb33 Junior Member
    53
    Toronto
    The repair will cost $4000 but my insurance will pay. The police and my insurance both said that I was not at fault and it shouldn't have any effect on my rates.
    The warning light came on when I started the car early on a cold day but it did not go off anytime after that. For 2 days every time the car was on the warning light was there, no matter what time of day or how long I had been driving. Though to be fair, most of my driving was short trips of 10 to 15 mins. each.
    The Toyota service person told me that the pressure in the tires was fine and that the sensor was activated due to the cold weather, as if it was a mistake...
    I agree that it is best to get a gauge and check the pressure myself no matter what the temp if my warning light goes on...
