Tried to lock my Fob in the Prius.
Discussion in 'Gen 2 Prius Main Forum' started by tullynoon, Oct 18, 2005.
  1. tullynoon
    tullynoon New Member
    57
    Port Angeles, WA
    I was warm so I took off my jacket (with the keys in the pocket) and I laid it on the seat. Sure enough, I got out of the car, closed the door and tried to lock it -- no deal! It beeped loudly so I pushed the lock button again -- and another beep. That's when it dawned on me that the keys and Fob were in my jacket pocket. Wow!!! A car that's smarter than I am. I really love this thing.
    Patrick
  2. TJandGENESIS
    TJandGENESIS Are We Having Fun Yet?
    5,299
    47
    ★Lewisville, part of the Metroplex, Dallas, in the
    Yeah, the first time I did that, I was like, 'Wth? Why won't the car lock?' then it dawned on me...
    Great car.
  3. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I use that trick to show people that my car is Tony Proof.
    DO NOT TRY THIS TRICK WITH THE HATCH!!!
    The fob sensor may not see the fob when it's in the hatch and you will actually lock the key in the car. Likewise, don't put the fob in your gym bag, open the hatch, throw the bag in the back and try to start the car. I tried that one too.
    Here are some other fun things you do with Smart Key:
    1) Tell friends that the handles use biometrics to unlock when you touch the fingerprint reader. Also that the push-button reads your fingerprints and locks the door.
    2) Walk up to your car in the dark. As you approach, say something like, "Prius, recognize <yourname>" and the dome light will illuminate as you get closer.
    3) Also, tell your friends that your car likes a good petting. As you walk up, start rubbing the hood and work your way around to the door. Again, the dome light will illuminate.
  4. TJandGENESIS
    5,299
    47
    I have got to try those...Thanks!
  5. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    I'm not sure you COULD lock it in the hatch from the outside unless someone else also had a fob. I guess I'll try it, with the spare fob tested and available. But if the fob isn't close enough to the lock, and on the outside, I think pushing the button would be no different than telling your passanger to lock the car from the outside after you both closed your doors. I know it won't let you lock the car if any door or the hatch are not FULLY closed so you couldn't even push the button, throw the fob in then close the hatch.
  6. Seaside Harry
    Seaside Harry Junior Member
    79
    Chesapeake, VA
    2014 Prius v wagon
    I inadvertantly tried to lock a fob in the trunk and the car wouldn't let me. I had mine in my pocket, but we parked somewhere and my wife didn't want to carry her purse. Tossed it in the back hidden beneath cargo shade, and closed the hatch. Pressing the black button just resulted in beeps until I remembered she had the other fob in her purse.
    However, there is an outrageous tale of woe on this board, where the fob was locked in the trunk while visiting a water park. In this case, it was a bit easier because SKS was turned off.
    See: http://priuschat.com/index.php?showtopic=9...indpost&p=94198
  7. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    For what it's worth: if you want to keep an extra fob in the car, say, in a suitcase on a trip and you don't want to have to carry both fobs with you when you park the car, you can do so by putting the extra fob in an empty Altoids box, or any metal box. Altoid boxes work great and are just the right size. The metal box prevents the signal from being transmitted between car and fob.
    Bob
  8. TJandGENESIS
    5,299
    47
    Huh! What do you know. Thanks for the tip...
