will 18" aftermarket wheels affect MPG ?
Discussion in 'Gen 3 Prius Fuel Economy' started by VIP hybrid, Oct 15, 2010.
  1. VIP hybrid
    VIP hybrid New Member
    california
    assuming the average 18" cast wheel is about 23 lbs, do u think it will affect mpg...if so by how much ?
  2. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    Yeah, unsprung weight and increased drag will both contribute to lower mpgs...looking around the boards, the 17" scion tc wheels some people are using on their prius' report a 3-5 mpg drop. Tc wheel weight is in the same range as what you're considering
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    Additionally, You will have trouble finding low rolling resistance tires. Most 17" and larger tires tend to be performance oriented and thus emphasis traction over ease of rolling. While the weight of the wheel will indeed lower your MPG, I feel the tire choice is even more crucial. After the debut of the 2010 Prius there are a few decent 17" fuel efficient tires available but I have not seen any really good ones in a 17" or 18" size yet. :(
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  5. Former Member 68813
    3,524
    983
    US
    In addition to what is mentioned above, wider tire will increase friction regardles of LRR rating.
  6. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    You also have to consider the RPM, (Rotations Per Mile) from factory OEM tire/wheel combo vs what you want to now put on your car. That pecentage of difference will also affect MPG.....
