Fuses?
Discussion in 'Gen 2 Prius Audio and Electronics' started by hawkjm73, Aug 16, 2005.
  1. hawkjm73
    hawkjm73 New Member
    258
    Phoenix, Arizona
    Does anybody know a source for the cute little side-bladed fuses in the 2005 Prius? (I mean besides the$1.38 a piece at the dealer :cussing: )
  2. talonts
    talonts VFAQman
    468
    76
    If you want ones just like stock, you're stuck with the dealer.
    If you remove the cover, you can use standard mini-ATC fuses available at most auto parts stores.
  3. OthisS
    OthisS New Member
    Albuquerque, NM
    So replacing original fuses with longer prong fuses, will work
  4. ChapmanF
    18,046
    #4 ChapmanF, Jul 21, 2025
  5. RRxing
    RRxing Senior Member
    2,544
    1,818
    NEPA
    Some fuse info:
