When you do a coolant flush..
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gobux, Oct 20, 2010.
  1. gobux
    gobux Junior Member
    60
    Columbus, OH
    Do you go ahead and change the inverter pump? Every time?
  2. Patrick Wong
    18,210
    6,511
    Well - the initial coolant change interval is at 100K miles. I think it would be reasonable to change the inverter coolant pump at that time (assuming it did not already fail.)
    Subsequent coolant change intervals are at 50K miles. That's probably too soon as a pump replacement interval.
    Its not clear whether current production 2G inverter coolant pumps are better or worse than older pumps.
  3. gobux
    gobux Junior Member
    60
    Columbus, OH
    What happens if the inverter pump fails during driving?
  4. jdenenberg
    jdenenberg EE Professor
    3,951
    1,946
    Trumbull, CT
    2020 Prius
    LE AWD-e
    your Prius will detect an overheated Inverter and protect itself. I replaced my Inverter coolant pump (electric) and the ICE water pump at 150,000 miles.
    The replacement electric Inverter coolant pump is an improved design so it promises to last longer than the ones in a 2004 or 2005 Prius.
    I just do drain and refills, not flushes.
    JeffD
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    No need to, but use an AirLift to bleed the system.
