ROUGH riding prius
Discussion in 'Gen 3 Prius Technical Discussion' started by dragman, Oct 22, 2010.
  1. dragman
    dragman New Member
    western new york
    NEWBY PRIUS 2010 SERIES 111:cheer2: SEEMS VERY HARD RIDING BAD SEATS THANKS ANY SUGGESTIONS THANKS
  2. fmi
    fmi Junior Member
    24
    Phoenix
    Uhm...more beads seat cover?
    -Seriously maybe have suspension looked at, tire pressures.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    My suggestion ... DON'T SHOUT!
  4. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    You test drove the car before you bought it right? They do tend to ride a little on the stiff side but its not that bad at all. Check tire pressure as another member suggested.
  5. Joe166
    Joe166 New Member
    720
    97
    South Florida
    I know it is all a matter of personal preferences, but I have never felt my Prius had a rough ride. Maybe get a whoopee cushion without the noise maker?
  6. dragman
    dragman New Member
    western new york
    DEALER took me for a ride on smooth street around block,my own fault i should roade out to highway and on to bumbiest street i could find tires 32psi
  7. bisco
    51,851
    You should get the pneumatic replacement seat. $75. Sears.
  8. docsnavely
    docsnavely Insert Custom Title Here
    66
    Ocoee, FL
    that's wrong. it's a good thing i know how to research stuff. people on this forum can be so conceited at times.
  9. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Keep driving it and see if it gets worn in. But don't lower your tire psi anymore. 32 psi is quite low, but ok. Any lower and you risk wearing the edges of your tires faster.
  10. pixelmixer
    pixelmixer New Member
    102
    Seal Beach CA
  11. GasSaving
    GasSaving Saves $1,000/yr on gas
    52
    Boston
    Rough compared to what? My 2010 Prius is much quieter than my 2005 CR-V. We can finally have conversations without raising our voices. If I were replacing the CR-V today, we would get a second Prius, but since the CR-V is also very reliable, I'll have to wait another 2-3yrs. Then I can get me a PHV Prius!
  12. theloop82
    theloop82 Member
    Spanaway, Wa
    Pries is not lexis. Im riding on the spase saver tier but that shouldnt make it ride this bad.
    Is my pries broken it only gets xliii miles per galen!
  13. GasSaving
    52
    Boston
    Narrow spare tires are inflated to much higher pressures, so every bump is going to crack your back. This is true for any car. You need to purchase a normal tire asap. Riding on a narrow spare isn't safe for long.
  14. bng1959
    bng1959 Junior Member
    Dallas TX
    I take my IV to dealership in the morning. It doesn't ride smooth like my 06 did. On delivery it had 25psi in three and 22psi in the othere. My rear view mirror is lose. The drive part is going to hard to explain. Feel I will be advised it's normal. Just don't understand why the ride is rough when I hit bump or anything other than smooth with no defect roads. Car appears to have set for 6 months per the inspection sticker being March. Car was dead and dealership installed new battery. I had hoped my 2nd Prius would be pleasant and running with no issus. There is some strange issue with the system. My low air pressure light comes on and stays on and sometime during the day it goes off. Nothing consistant to keep me sane. Nice to read posting on the ride. Maybe my answer will be the same
  15. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    The tire pressure is way too low. Check your driver's door for recommended pressures. In general, most drivers inflate to 38/40 PSI.
  16. 26nm
    26nm IC Desgin Engineer
    35
    Silicon Valley, CA, USA
    The springs are so darn hard, you can't push it down by pushing down on the hood.
    I can do ths easily with my 4 other non-prius cars.
    I got two 2010 Prius II and the springs behave the same on both, so Toyota must have do it this way for a reason. May be car is too heavy and afraid on over leaning at turns. Or hard spriing is cheaper?
    Sorry, look like you have to live with it.
  17. jayrider
    jayrider Member
    163
    17
    southwest illinois
    My IV rides like a light compact hatchback, which is what it is. Actually like the ride -- handles expansion joints like an audi a3 -- nicely dampened. If the road is rough is doesn't isolate you from bumps like car with larger suspension components but I find it comfortable around town or on the highway.
  18. bisco
    51,851
    sears has the pneumatic seats back in stock! no conceit, just comfyseat!:)
  19. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    Based on this thread, it seems that people who can't spell think their Prius rides rough. Go figure.
  20. 26nm
    35
    I don't thiink they aree relatedd.
