Warning Lights
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dkp, Oct 25, 2010.
  1. dkp
    dkp New Member
    N.J.
    First off I have a 2010 with about 11,000 miles and it has been running great since I got it. This morning I was greeted with the "Yellow triangle" and the "check hybrid system warning". The car started fine and I pulled out of the garage under battery as usual and then the engine kicked in also as usual, everything seemed normal except for the warning lights. Since I have a long commute I just took my wifes car and got to work and did a forum search on this issue. I called my wife and had her turn the car on and off three times and she said it cleared the yellow triangle and check hybrid system but it still had the check engine light on. She also said the car seemed to be running fine and shes driving around town in it. I couldn't find anything on the check engine light so anyone have any suggestions? Is it ok to drive it? Thanks to all for any help or advice you can give.
  2. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    I would bring it into the dealer ASAP. After all, isn't that what the warranty is for?
  3. dkp
    dkp New Member
    N.J.
    Update. I had my wife check the gas cap and it wasn't on all the way, once she closed it properly the check engine light went off. I'm not sure if this was all related but it does make me a bit nervous. As of now the car is back to running great. Fingers crossed....
  4. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    Actually, a loose gas cap can cause the check engine light to go on, so you probably found the problem.
    Good luck.
