Newbie with questions...
Discussion in 'Newbie Forum' started by theusc_2001, Oct 28, 2010.
  1. theusc_2001
    theusc_2001 Interested in getting a Prius
    South Carolina
    Hello all, and thanks for having in me. I am in the market for a car to help with my huge gas bill via a daily commute of 256 miles. I have been looking into the Prius, TDI, and Focus Hybrid. Does anyone on here have numbers on gas millage with the cruise control sitting on 70-75 mph? And how about maintenance cost? Are the rumors true about the high cost of the replacement batteries? etc... What year\models do you recommend? Any information would be greatly appreciated.
    Eric
  2. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Man you are the PERFECT candadiate for a Prius. I have a customer who has an 04 Prius with, by now, way over 200k. She commutes almost as bad as you LOL, her commute is only 160mi. Anyway she has nver had a breakdown and only routine maintaince. She plans on getting an 11 Prius in Jan. when she estimates her 04 will go over 300k. anyway my 10 Prius always gets at least 50mpg on our trips back and forth to Fl. on I-95 doing 70-80mph. The best tank I got so far one time was 54.6 so I'd recommend a Prius for you buddy.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I cruise at 71 MPH on the freeway, and get about 42 MPG in a 2009.
    In a 2009, I pay $46 every 5000 miles for an oil change and tire rotation, once I get to 100,000 miles I will need to buy spark plugs and replace some fluids. The 2010 uses Synthetic oil so the cost is higher but the OCI is 10,000 miles so it works out the same.
    Toyota has only been selling the Prius for 10 years, so we really don't know how long the High Voltage batteries may last. Taxis seem to exceed 250,000 miles on a HV battery. Full retail for a new replacement HV battery is $2500, but used HV batteries start at $300.
    Prius battery -ECU items - Get great deals on eBay Motors items on eBay.com!
    The 12 volt battery lasts about 4 years and is somewhat pricey, $120 to $170. My advice is to replace it every 4 years, (8 years for the Optima) jump starting a Prius is not an ideal outcome.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The Grey line represents the theoretical MPG at given speeds, the green Dots are actual MPGs at given speeds in a Gen I Prius.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Wow 256 miles a day!!!! I would almost think a small plane would be best. :)
  6. theusc_2001
    South Carolina
    Thank you all so much for your replies. Looks like this is the way to go for me. I have a dealer searching for a used Prius with low miles. Are there any major items that I should be wary of when selecting one? Beside the normal used car things? Any model I need to stay away from, or lean toward? Thanks again.... Eric
  7. dkp
    dkp New Member
    N.J.
    I thought my commute was bad at 142 miles a day! I have a 2010 and my drive is 95% highway and I'm usually doing 70-75 MPH and over 11,000 miles my avg MPG is just over 50. I don't think you will do any better than a Prius!
  8. GWhizzer
    GWhizzer not so Senior Member
    120
    24
    Winnipeg, Manitoba
    A daily commute of 256 miles? Sorry a Prius won't work for you. You need a semi-trailer so you can take the life you are leaving behind with you :):)
    OK, seriously, I get 45-55 mpg (US) city or highway. And the Prius is consistently ranked among the top 10 for reliability. Many, many drivers have posted stories of 200,000+ miles on a battery. Battery replacement (perish the thought) should it be necessary is not as much as the ridiculous rumours floating around (it's $2,500 new, $500-$1,500 used or reconditioned). I like the Prius on the highway. I find it drives well and is comfortable (although not everyone will agree as comfort/handling is highly subjective).
  9. paprius4030
    2,077
    296
    York,Pa.
    Hey if your going used, with all your highway driving, I'd really try to hold out for a 2010. You'll get at least 4 mpg's better with a Gen.3 on the highways. Sometimes I'd be a little dissapointed with my 08 when we went back and forth to Fl. Sometimes I'd only get in the low 40's where with my 2010 I nevewr get below 50mpg on the highway. But the early 2010's seem to generate more complaints of interior rattles. Seems cars made after Dec 09 don't suffer those complaints. With all the end of year deals and rebates maybe you should consider new and just drive it into the ground.
  10. mort
    mort New Member
    Los Angeles
    Hi Eric,
    I don't think you can wait for a Focus hybrid, and the 2011 Focus EV has a 100 mile range, so that won't do. The TDI is a fine car. Here in L.A. diesel is as expensive as premium, that might be a consideration. The Golf lacks some of the best Prius tech, like smart key and adaptive cruise control but otherwise is a grade above the Prius in appointments. I mean nicer seats and better materials, a nice ride and sportier, radio and nav are better but it is slightly smaller inside. Also available with a manual transmission. VW also makes diesel versions in 2 door, sedan and a wagon that might fit your style better. VW reliability does not have the same reputation as Toyota.
    The 2010 Prius will get slightly better mileage. Some people have complained about the Prius seats for long drives.
    All hybrids have expensive batteries which will be replaced under warranty for 8 or 10 years depending on where you live. But after warranty, there are battery rebuilders and crash batteries are plentiful, like on ebay.
    -mort
  11. sub3marathonman
    sub3marathonman Active Member
    557
    75
    I thought that somewhere on PriusChat there was a discussion of a dealer in either North Carolina or South Carolina that was the place to go to get a good deal on a Prius. This has been awhile back, but I know that even well into 2010 they had a 2009 left.
  12. theusc_2001
    South Carolina
    I have found one that I may buy this weekend. It is on Ebay (item #110603475884), I am newbie on here so I cant post links. It is a 2010 Prius II? 13K miles 17990 buy it now.
