Is it worth is to buy a used Prius?
Discussion in 'Gen 2 Prius Main Forum' started by bdaisy, Oct 29, 2010.
  1. bdaisy
    bdaisy New Member
    Palm Beach, Florida
    Hello all!
    I am in the processing of getting a car and I have my heart set on the Prius for many, many reasons, such as the low mpg, the reliability of Toyota (esp the Prius) and the general good feeling I get from helping the environment.
    Unfortunately, for me to able able to afford a new Prius, I would have to buy used, since I am not interested in leasing and cannot afford to buy new.
    The Prius that I'm looking at is a 2007 Touring with 60,274 miles. I have read the carfax and the car was very well maintained by the previous owner. It is being sold by a dealership and the asking price is $13,900.
    My question is: is it "worth" buying a used high mileage Prius? What, in general is the cost of maintaining a used hybrid (any special maintenance needed)?
    My main concern is reliability. How reliable is a used high mileage Prius in general? Should I buy used or just wait until I can buy new?
  2. macmaster05
    macmaster05 Senor Member
    4,050
    730
    There are people with over 200,000 miles on their Gen II Prius. Reliability is not an issue. Maintenance is the same as any other car, if not less. Around 100k miles you may need to look into replacing the standard 12V battery.
    $13k is a good to great price for that car.
  3. mike lipke
    mike lipke New Member
    89
    MN
    Bought a 2005 last year with 82k for $12,000.
    Bought a 2008 this year with 74K for $14,700.
    Cream puffs, no issues with either.
    (the '08 stickered for $26,000)
    Save money, buy used.
  4. bdaisy
    bdaisy New Member
    Palm Beach, Florida
    Dealer is now offering me $12,000 for the car. I plan on test driving it tomorrow and moving forward from there.
    What are some common issues for an older Prius?
  5. caffeinekid
    caffeinekid Duct Tape Extraordinaire
    334
    44
    Houston
    Now, $13.9K is too high, but the miles are right and it having only been a one-owner vehicle- at $12K, if it were me, I wouldn't wait until tomorrow. The Prius is probably "the" best used car you can buy.
  6. bdaisy
    bdaisy New Member
    Palm Beach, Florida
    Funny, I spent today taking my mom's 00 Sienna to get new tire rods. I mentioned to one of the mechanics that I'm interested in an 07 Prius and he told me it would cost about $700 to get my battery replaced in the Prius.
    I just smiled.
  7. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    Hal is a 2008 Gen II (not touring).
    He had about 31,000 miles when I bought him for $14000 a couple months ago. Best car purchase ever.
    Depending on how your Prius was used (mainly, did it ever sit for extended periods or did the owner ever leave stuff turned on when it wasn't running) you may need a 12V battery any time. Hal's was borderline so I went ahead and swapped it out. If the 12 volt battery goes dead, you are pretty much stuck -- you do not want to wait until it fails.
    Here's how to check your battery using the cars self-diagnostic system.
    Test the 2004-2009 12V battery using this procedure, no tools required (thanks to jdenenberg):
    - Without brake pedal, press the Power button once and release to enter ACC mode
    - Press and hold the MFD Info button, then turn the headlights on and off three times to enter Maintenance mode; release Info button
    - Press “Menu†(on screen)
    - Press “Display Checkâ€
    - Press “Vehicle Signal Check†- the battery voltage is shown and should be about 12.4 to 12.8 Volts (normal for an unloaded battery)
    - Again without brake pedal, press Power button and release to put a current load on the battery - the voltage should stay above 12.0V (if less than 12.0V the battery is not well, or there is a fault or unusual load somewhere)
    - Press brake pedal and press Power button once to enter "Ready" mode - the battery is now charging at about 14V (if less than 13.6V or more than 14.4 there may be a problem with the charging circuit)
    - Turn car OFF to leave Maintenance mode
    If these procedures cannot be started then the battery is either dead or there is some more serious problem.
    If you need one, you can get a much better battery with installation kit on this site. Took me about an hour to install on Hal.
    12 Volt (12v) Toyota Prius Auxilary Battery for 2004, 2005, 2006, 2007, 2008, 2009 and 2010 with installation kit
  8. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    bdaisy, get them to throw in the longest used car extended warranty available(make sure it's a Toyota warranty), then pat yourself on the back for getting a great car and a great deal
  9. PhazonPhobe
    PhazonPhobe His name is Sora
    221
    26
    28
    Fontana, CA
    I found my 2004 "Sora" on CraigsList.
    Bought it with 92k miles, clean title, great condition for $8,800 back in June.
    Hasn't given me any problems, runs great.
  10. priusevo
    priusevo Junior Member
    46
    Just got my 05 with 82k for 10K runs perfect I put in some Amsoil and it gets easily over 50mpg with my best of 64.09 on my 3rd tank but there is a learning curve to get 60mpg but 50 is no problem.
  11. milazotes
    milazotes New Member
    22
    York, PA
    Seems like a fair price point. As for problems, have you seen if this has Autoleveling Headlights? My '05 has a bit of a glitch from time to time. To replace, they are over $700. I've got 203k on mine and have only ever done plug replacement (and I didn't even need to do that!!!) Check Tranny fluid and radiator fluid changes, the CVT itself, if neglected or in poor condition, could be a major cost issue. That's it. Drive it, love it.
  12. johnong
    johnong Junior Member
    Maryland
    I didn't want to pay for new Prius, so just got '08 Prius, Nav, leather, 43K miles, dark grey, looked great - $14.2K. Driven for 2 weeks - no problem (minus taking a while to figure out the proper way to start a Prius (I don't like reading directions!)). MPG seems to be in the mid 40's. Overall, very pleased with quality of car.
