My headlight mod and antenna
Discussion in 'Gen 2 Prius Accessories & Modifications' started by fluxcapacitor3000, Nov 2, 2010.
  1. fluxcapacitor3000
    fluxcapacitor3000 New Member
    24
    Socal
    Cleared my headlights today and put on an s2000 antenna. Next up is rain visors. Should I paint the wheels black?
    aaroncv3 likes this.
  2. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Hey Flux, that looks great! Love your grill, tail light tints, and especially the headlights! (Looks like the JDM prius.) I don't think you should paint your rims black - just buy new ones.
    One question about the headlights though, that bulb in the corner edge of the headlight...what light is that, and what color will it illuminate now? I also know the law requires you to have orange reflectors somewhere in the front of the car. Now that you've removed them do you plan to put them somewhere else?
    Now, if you black out your backside emblems and drop your ride, your in BIT-ness!
  3. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Looks like he installed a orange bulb which will illuminate orange. H
  4. fluxcapacitor3000
    24
    Socal
    I'm actually planning on changing the parking lights from the stock clear to an led amber and as the for turn signal bulb its amber stock so i might just leave it. I am planning on dropping it when i have extra money.
  5. Supreme
    Supreme Hypebeast
    182
    Philly
    How did you clear the light?
  6. fluxcapacitor3000
    24
    Socal
    put it in the oven and removed the amber pieces. I've done it many times to my past cars.
  7. macmaster05
    4,050
    730
    How does your light differ from the JDM headlight? Is the JDM assembly missing pieces like yours or is it replaced with some other piece of plastic/relector?
  8. fluxcapacitor3000
    24
    Socal
    i think the jdm one, instead of orange reflectors its just a silver piece.
  9. Supreme
    Supreme Hypebeast
    182
    Philly
    I did it once back when I had a civic si. How many refletors? 2? Did they just pop right out? Do they leave mounting holes in the headlights?
  10. fluxcapacitor3000
    24
    Socal
    u cant really see the holes so its clean, if u don't want that u cud always paint the reflectors silver and put em back on. i wish i had fogs like u guys :(
  11. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
  12. a_gray_prius
    2,927
    783
    IL
    How did you black out the front grille piece? I'm thinking of going the spraypaint route.
  13. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    those would look pretty much the same as the JDM lights... only difference will be the JDM headlights shape is not smooth..it has a bulge between the park lights and headlights..... (which is not noticeable when you're looking at a distance)
  14. pEEf
    pEEf Engineer - EV nut
    720
    580
    Berkeley, CA
    Nice!
    How hard was it to get the lights apart? I'm thinking of adding real LED DRL's where the "fake" ones are.
    Do you have any tips?
    Did you just paint your grille black?
  15. Supreme
    Supreme Hypebeast
    182
    Philly
    Generally you just put the lights in your oven at the lowest setting, like 200 degrees or so for 5-10-15 minutes. The light should be slightly hot to the touch. Don't worry about melting it, this is only a little hotter than leaving your car out in the sun all day. Then you'd just pull the lens apart from the housing using a flat head screwdriver and some patience.
  16. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
  17. fluxcapacitor3000
    24
    Socal
    yup the oven is the headlights best friend lol and as for the grill i just used plasti dip paint on it.
