When does your low fuel signal come on?
Discussion in 'Gen 2 Prius Main Forum' started by curtis0916, Nov 5, 2010.
  1. curtis0916
    curtis0916 Junior Member
    Abilene, KS
    I have a 2006 Prius and my low fuel signal comes on with around 4 gallons left in an 11.9 gallon tank, that seems like a lot of gas left to get a low signal.
    I was wondering when the light comes on in other Prius cars? Thank you for your assistance.
  2. jdenenberg
    jdenenberg EE Professor
    3,939
    1,937
    Trumbull, CT
    2020 Prius
    LE AWD-e
    don't count on having 4 gallons left. In cold weather, your gas tank capacity drops by about 2 gallons due to stiffening of the bladder in the gas tank.
    JeffD
  3. mwester
    mwester New Member
    North Carolina
    When the last tick on the gas gauge starts blinking, I can get about 8 gallons into my 2004... same as yours... I'm not sure if it gives any other warnings as it gets lower.
  4. curtis0916
    Abilene, KS
    Thanks for the help guys, I have only had my Prius for a month and thought something might be wrong, but it sounds like it is normal to have it come on at that time.
    Can anyone give any input as to where the sensor is located and how it works?
  5. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
  6. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    Mine never comes on, but that's because I'm smart enough to fill it before it is empty. ;)
