Fuel gauge never goes to 9/10ths, anyone know what's wrong?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by richard13, Nov 5, 2010.
  1. richard13
    richard13 Junior Member
    65
    Mill Creek, WA
    I have had my Prius for about 9 months now and I'm pretty consistent with fill ups. I let the gauge go to 1 or 2 pips and refill. However, I notice that a few days after refilling the fuel gauge goes directly from full (10/10) bars to 8/10 bars without stepping to 9/10 bars first.
    Has anyone else seen this? Know why this is happening or how i can be fixed? It's kind of annoying.
    Thanks!
  2. fuzzy1
    10,482
    The 9th bar is the shortest on my gauge, but it still goes roughly 60% of the distance of the other bars.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I have not seen this on mine. I have not really paid attention to how long it stays on each bar but mine does step through each bar.
  4. SmogSlide
    SmogSlide Member
    128
    17
    Melbourne
    Well, mine goes up and down when it is at the 9th bar. Whenever I restart the car, it goes back to 10/10 bars, and after some driving, it goes back down to 9th bar. Funny enough this behavioud does not occur at any other levels, only on the 9th.
  5. fuzzy1
    10,482
    Mine does this from nearly any bar. It can even climb two bars, but the vast majority of them are from 8 to 10.
  6. richard13
    65
    Mill Creek, WA
    Hmm... I've never seen mine go back up again, just down. Although, if these are similar to analog fuel gauges in other cars you'd think that would happen all the time.
    I am already planning on taking my Prius in for "rattle" service. I'll ask them about the fuel gauge too.
  7. fuzzy1
    10,482
    Everything I've heard indicates that the sender unit in the gas tank is the same.
  8. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    I usually get less on that bar as well. But I get more on full and usually have about a couple of gallons left on fill up. Wouldn't worry to much about it....
  9. richard13
    65
    Mill Creek, WA
    Update:
    The dealer hooked my Prius up to the computer and it's not showing any faults and there's no software updates for my vehicle. That's ok, but when I asked about the float possibly being defective he said there wasn't one and started talking about a bladder in the gas tank. This made me wonder because I heard there was no bladder in the Gen IIIs. Can anyone confirm this with some documentation?
    Anyway, I filled my tank up again and low and behold my gauge dropped to 9/10 today at 65.8 miles (this sounds a little late). It stayed there until I got off the freeway about 8 miles later when it popped back up to 10/10. Maybe it's been doing this all along and I just haven't noticed? I'll have to see what it does tomorrow. I bet it will stick at 10/10 and drop down to 8/10 again. :mad:
  10. qbee42
    3,079
    The Gen III Prius has a sender unit, but no bladder. Your dealer is wrong, as they often are.
  11. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    Mine kind-of does what you're describing. Sometimes I'll be on 8 bars, then after a long down-hill deceleration, it'll be back up to 10 bars.
    I can understand the fuel sloshing around and moving the sender up.
    But, it then stays at 10 bars for a long time. Then it drops back to 8 at once. This isn't the behavior I'd expect from dampening of the sender signal.
    I think the sender sticks a little bit. Not enough for me to complain about though.
    I use the 10x rule to fill up. I reset tripA at each refill. When the miles traveled = 10 x the average mileage, I fill up.
  12. richard13
    65
    Mill Creek, WA
    So today when I started up my car I was surprised to find the gauge at 9/10 once again and after a while it went down to 8/10 (at 90 miles). I then toggled a bit back and forth from 8/10 to 9/10 and back. At 120 miles it first tapped 7/10 after which it toggled with 8/10s.
    I'll probably monitor the gauge and take note of the mileage the rest of this tank.
    I guess the bottom line here is that, after being more observant, my gauge is just like many others' who have participated in this thread. :) BTW, thanks to all of you.
