Article about 2010 steering column problem
Discussion in 'Fred's House of Pancakes' started by WienerMobile, Nov 7, 2010.
  1. WienerMobile
    WienerMobile Junior Member
    29
    Madison, WI
    FYI. Sounds like an assembly defect:
    Prius steering column scare pits Madison family against Toyota
    "On Interstate 90-94, near the Highway 30 exit, Meek felt the entire steering column telescope and fall. Desperate, he tried to lift the steering column and wheel."
  2. GasSaving
    GasSaving Saves $1,000/yr on gas
    52
    Boston
    Why do you post something that happened once (if true), when other carmakers have millions of recalls due to "bad wiring, etc." that has been leading to the whole cars/SUVs catching fire, etc. Just be glad far fewer parts are likely to fail on your Toyota than tip-over Explorers or burning GM Fieros / Ford Pintos.
  3. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    The article makes no sense. He may have had steering, or he may not. it fell off in his lap, but he could steer it if he held it up.
    Sounds like new owner either didn't know what they were doing or couldn't afford it, so did a Sikes.
  4. fuzzy1
    10,602
    With both hands on the wheel, mine still steers as directed even when the latch is released and the column is flopping all over the place. (Tested while stationary, ignition off.)
    Based on other comments in the article, I think I'm detecting a faint Sykes-like aroma.
  5. Politburo
    Politburo Active Member
    971
    208
    I don't think there's a Sykes going on here. Sounds like a perfectly legit manufacturing defect.
  6. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I think this article belongs in one of the Gen3 threads, not here.
