Poll - the BLUE Prius emblems
Discussion in 'Gen 3 Prius Main Forum' started by DeanFL, Jun 11, 2009.
  1. I'm happy with it and will leave it as is.
    49.0%
  2. I'd get rid of it, as long as it didn't cost me anything.
    10.0%
  3. I'd like to replace it with a BODY COLOR logo and would be happy to pay a bit to do so.
    20.0%
  4. I'd like to replace it with ANOTHER COLOR and would be happy to pay a bit to do so.
    5.0%
  5. If the only way to get rid of it would cost $100, I'd still do it.
    9.0%
  6. I really like it and feel it should be the Toyota emblem for all Hybrids.
    13.0%
  7. I'm happy with it but wish it was smaller.
    6.0%
Multiple votes are allowed.
  1. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    I'm the 'people':
    Well - didn't put much thought into it and wanted to use some of the initial choices posted by another member. This is not scientific, nor will be forwarded to Toyota. If you're indifferent - don't take part in the poll, if none of the choices apply....
  2. Pakman777
    Pakman777 New Member
    103
    Colonial Heights (Fort Lee), VA
    I agree
  3. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ooops. didnt take any pics except for after install. it was pretty easy though.
    had file for install. goes step by step...much easier to do than EV switch on SPM....
    i actually started the install at 8.30 PM, finished at 10 pm. would have been done sooner, but...it was kinda dark, so had to move the one light around to see what i was doing. only tool is pliers an 10 mm wrench if disconecting battery (keep in mind if you do this, you need to record your mileage if you are tracking it because it will reset everything except odometer)
  4. btaylor
    btaylor Junior Member
    36
    Evanston, IL USA
    As the owner over the past few years of several Apple MacBook laptops, I think it would be cool if the Toyota emblem was LED-lit (during operation of the Prius) as is the Apple logo on the cover of Apple laptops.
    But I'm fine with the Prius emblem as it is...
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Pics of process linked from this thread:
    http://priuschat.com/forums/gen-iii-2010-prius-modifications/63280-lighted-door-sill-installed.html
    I chose not to disconnect my (-) term as I didn't see the risk as high provided I was 100% certain on wires. I didn't want to lose radio settings, and it's much easier to test this way.
  6. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ya wishing i hadnt either. i filled up my tank with 2 bars left since trip A reset as well. on paper i should have been around 63.7 mpg... ended up with 53.9!! should have done about 7.2 gallons, i ended up with 8.335.
    no i seriously doubt that disconnecting the battery made a difference since i did record what the MFD said before and after... but can only refill in a few weeks and see what happens
  7. CenVal
    CenVal Member
    48
    Should be an option to match color of the car!
  8. CenVal
    CenVal Member
    48
    Looks good w/ Dodger Blue!
    Used to live on Rose! Has changed a lot!
  9. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
  10. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
  11. JoeM(GA)
    JoeM(GA) Member
    40
    35
    Atlanta,GA
    Body color!
  12. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    IIRC, in Japan, blue is their "ecological" color, much like green is here in the states, hence the blue badging. Notice that on all Toyota hybrids, the "Hybrid" badge has a blue stripe on it.
    As previously mentioned, I'm indifferent about the color, and I have a Sandy Beach Metallic car.
  13. Psych_Prof
    Psych_Prof New Member
    53
    Southwestern Illinois
    definitely body color!
  14. Blue Prius Texan
    Blue Prius Texan Crazy? Nah...just humorous!
    78
    Fort Worth, Texas
    Body color....but since I have a blue Prius, it works for me.
  15. macmaster05
    macmaster05 Senor Member
    4,050
    730
    I'd rather have the red glow.
  16. a1rjumpman23
    a1rjumpman23 Junior Member
    75
    Carbon is the way to go
