Ultimate mounting for Scangauge II.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by adric22, Nov 11, 2010.
  1. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    Took me about an hour with a dremel, but I think it came out fantastic. It is right behind the steering wheel so you look through the wheel to see the screen. Granted, it is a bit hard to press the buttons, but I generally leave it on the same screen.
  2. biff_debris
    biff_debris WOOF!
    81
    Prescott, WA
    Nicely done! Mine is still Velcro'd way down low below the radio.
  3. bisco
    52,409
    that's purdy!:)
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Nice work, how did you get the rounded edges on the opening?
  5. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    That's pretty much where I have mine velcro'd. I don't want a permanent installation as my wife has a Prius too and we use her's for LD trips. This way, I can move it from my car to her's with little trouble. It DOES look nice though.
    Yeah, pushing the buttons is a pain...I leave mine pretty much set at:
    RPM - check if/how hard the engine is running
    soc - always want to know how much charge is in the HV battery
    bta - I have an Enginer kit and I monitor how many amps go to HV battery
    fWT - Nice to know when I'm warmed up, near/in S4.
  6. adric22
    642
    146
    Fort Worth, TX
    I use 3 of the same readouts (I also have an engineer kit) but I see no point in SOC since I can see that on the center screen in the prius. So I use RPM,engine temp, bat volts, bat amps.
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    That is just some fine Dremel work!!!
    I have always considered that spot, excuse me if I borrow your idea!
    Well done!!!
  8. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    That really is slick. I assume the viewing angle is OK? How about glare problems in bright sun?
    - D
  9. Crazyhorse6901
    Crazyhorse6901 New Member
    114
    Hampton,VA
    Nice job with the install, looks great...
  10. patsparks
    10,664
    567
    Adelaide South Australia
    Where is the like button on PriusChat? I like it!
    Mine is velcroed to the top of the steering column.
  11. Azipod
    Azipod Member
    139
    NorCal
    Very nice! Are you willing to cut panels for a fee? I'm trying to find a good place to mount my SG as well -- so far I'm thinking about the CD panel.
  12. UGC
    UGC Member
    162
    39
    +1, also, how did you cut the perfect square? I have a dremel tool, but would not trust myself to get it right the first try.
    Any recommendations? Thanks.
  13. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Excellent job.
  14. NoMoShocks
    1,292
    83
    Camas, WA
    No problem, for your next dremel project, you can create a five button remote control panel to fit in one of the spare swich locations.
  15. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Nice job!
    What stops the gauge from falling into the dash ?
